      08-21-2011, 07:49 PM   #1
Stilweezy
Not new, not old
Drives: 2003 Z4 3.0i Sterling Gray
Driver door makes more noises???
I bought a 03 z4 convertible recently. i test drove other z4's they all seems to have a bit more noises when closing the door compare to passenger door. do you guys experience this? is it fixable?
      08-21-2011, 10:46 PM   #2
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
Yep, they do, you can get a piece of sound deadening material like Dyanmat or BMW P/N 51481923969 to help with the sound.
I added the BMW part to an order from tischer because it was cheap, when I had the door apart for something else I pealed the back and stuck it to the inside of the door, helped quite a bit.
      08-22-2011, 09:41 AM   #3
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Some early models had issues with the bowden cable and the fix was some sort of insulation or rubber bumper. It could also be the majority of these 2 seaters have a single occupant, so that door is slammed more often than the passenger door. Make sure the weatherstripping is well cared for and soft.
