08-15-2011, 10:15 PM | #1 |
M addicted
136
Rep 342
Tire pressure
Couple of questions forum members:
1. What tire pressure do you run? (I have stock setup on z4mc) 2. Got the tire pressure warning light flash at me for a few moments then stay on. Cycled the engine and went off. Tires are at 32 psi back and about 35 psi front. One stem cap just got stolen two days ago. What do you think is up? Thanks to all with thoughts. -Rob |
08-15-2011, 10:42 PM | #2 |
Rep 4,531
31 PSI all around.
Press and hold the Tire Light Button next to your heated seats while stopped until the light comes on. Once it comes on drive and it will trigger off. It will then reset to those pressures. |
08-15-2011, 11:45 PM | #3 |
Viper Driver
36
Rep 1,311
32 psi fronts and 30 psi rears cold. ^+1 on resetting the ftm/tpms immediately after inflating to desired cold pressures. press and hold the tire looking button on the center console and u should see the tpms light come on and stay on. drive for about 10 seconds and the light should extinguish indicating that the system has reset the baseline to the current detected tire pressures.
08-16-2011, 07:37 AM | #4 |
Rep 11,667
If you are trying to decrease understeer, you have your pressures backwards.
General rule of thumb; to decrease understeer, set..... Front Tire Pressure Higher Rear Tire Pressure Lower Also, I find our TPMS system is a little finicky at times. Mine has triggered once this summer for no apparent reason. I just reset it as per above & it has been fine.
08-16-2011, 10:57 AM | #5 | |
M addicted
136
Rep 342
Thanks for tip about understeer. |
08-16-2011, 11:01 PM | #7 |
Rep 4,531
08-16-2011, 11:13 PM | #8 | |
DHS
203
Rep 4,010
Drives: 2023 M4, 2020 Land Rover
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
08-17-2011, 08:57 AM | #9 |
Rep 144
You don't mention what tires you're running. I'm daily driving on Yokohama Neova AD08s and I typically have the pressures 28-30 psi cold all around.
2013 BMW M3 Coupe : Interlagos Blue : Silver Norvillo : 6MT : Competition Package : ACM exhaust - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - pics of M3 |
