      09-27-2020, 02:52 PM   #177
CrazyOneToo
1999 E46, 2002 E53, 2007 E85....all in progress
Drives: 2007 Z4 3.0Si Roadster
Intake parts???
Hello again.....I am confused on the intake options. I am trying to swap my 2007 Z4 3.0i with an N52 and 6 speed trans into a 3.0 Si version.
Below is a photo of what I have on my car now and one of an intake listed as a Si version. The first one shows the hose my car uses since the CCV is "as I understand it" on or part of the valve cover. In the second photo it shows 3 things I dont have with the intake I bought online. It did come with the Disa valves. I know I will need the one shown in green but the other two are for what? I ordered a new hose like in the top photo because better safe than sorry but now it may have been a waste of effort. I was told my intake came off of a 2006 330i.
Thanks
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress.....
      09-27-2020, 05:28 PM   #178
FrenchieTacoZ4
Drives: 2006 Z4 3.0i 6spd manual
2006 BMW Z4  [0.00]
2004 BMW Z4  [0.00]
Originally Posted by CrazyOneToo View Post
Wow thats cheap. The place I contacted wants $459 for the tune and $225 for a cable if I do the flashing myself.
What car tune did you use? I dont see an E85/E86 listed anywhere on their site.
I went with the stage3 performance tune. Type N52 In the search on their site, its at the bottom of the page. Call them and ask for Jim, he makes the tunes, he will explain what parameters are changed.
      09-27-2020, 05:46 PM   #179
FrenchieTacoZ4
2006 BMW Z4  [0.00]
2004 BMW Z4  [0.00]
Thanks
I used the hose (in yellow) and the piece (in red) which i had on my stock intake manifold. I sent you a message.
      09-28-2020, 12:37 PM   #180
CrazyOneToo
My car stock only has the yellow hose and the green sensor.
The red is not on my car at all and I dont see anything even close to the blue part.
The yellow hose hooks directly into the valve cover.
I did not get any message.
      09-28-2020, 08:06 PM   #181
FrenchieTacoZ4
2006 BMW Z4  [0.00]
2004 BMW Z4  [0.00]
I got the stock yellow hose to connect to the red and green on the 3stage manifold. I deleted all my before pics. There was one sensor i had to turn 180.
      09-29-2020, 11:33 PM   #182
CrazyOneToo
What is the red part?
      09-30-2020, 07:01 PM   #183
FrenchieTacoZ4
2006 BMW Z4  [0.00]
2004 BMW Z4  [0.00]
https://youtu.be/xym5-XgQCbY
      10-03-2020, 06:30 PM   #184
CrazyOneToo
Thanks. That cleared it up nicely.
      01-03-2021, 05:57 PM   #185
CrazyOneToo
Hello all,
I'm trying to test the DISA valves that came with the 3 stage intake I bought a while back. Would the DISA part number matter? The ones that came in the intake (11617560538, 11617560537) are a different number than the ones listed for a 2007 Z4 3.0Si. I have had the Si tune put on my ECU but having problems testing the DISA valves before installing the intake on the car. I tried my Foxwell 14020SCH but it stops working when I try to activate the DISAs. I have Inpa but it has scripting errors every time I use it. So I'm not sure if its even working or worse may cause a problem from the errors. I have BMW Scanner 1.4 but not sure if it can do anything like this. Ugh!?!?!?!?!
      04-17-2021, 10:28 AM   #186
CrazyOneToo
Originally Posted by -c- View Post
256HP and 228 ft-lbs of torque at the flywheel
here is the finished job
How do you tell which DISA cable goes to which DISA?
Mine are exactly the same and NOT "keyed" in any way.
Thanks
_
      04-17-2021, 12:03 PM   #187
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
[COLOR="Red"][SIZE="4"]256HP and 228 ft-lbs of torque[/SIZE][/COLOR] at the flywheel
Thanks
_
From memory, the cables are too short to mix up. They will only connect one way.
      04-20-2021, 12:44 PM   #188
CrazyOneToo
I hope you are right. I imagine its going to run pretty badly if they are hooked up backwards.
I was hoping they were keyed so that this wasn't possible but its not that way on mine. Ugh!
      03-31-2022, 02:55 PM   #189
Marscommander
Marscommander's Avatar
Drives: 2008 Z4 3.0i / 2007 M Coupe
Hello all,
I successfully completed the si conversion using the bimmerlabs tune a few months back and thought I'd ask about fuel economy. Not really talking about in-town since I do drive pretty spirited, but I noticed I'm missing a few mpg out on the highway at cruise. Used to get 32-34 and now get around 29 peak. Combined has dropped by about 5 as well.
Car is running great and pulls strong, no errors or dirty filter or anything like that, just wondering if the tune is less efficient. Noticing it with gas prices lately :P
Thanks!
      03-31-2022, 05:00 PM   #190
wdb
dances with roads
wdb's Avatar
4732
I can't speak to the conversion but my 3.0si coupe 6-speed got 30+ highway/trip MPG. In fact it was hard to get below 20MPG even when I was romping in the mountains. Crazy good on gas, considering.
      04-19-2022, 03:03 PM   #191
mike_ols
Drives: z4 3.0i
Originally Posted by Marscommander View Post
Hello all,
Thanks!
After driving for a few more weeks have you noticed any improvement in your fuel mileage?
      10-25-2022, 12:07 PM   #192
nmcmill1
Drives: z4 e85 3.0i 2007
Hey, I've read through this whole thread but can't figure out how to find the tune, I checked the active autowerke website and tried to find the user to message but can't find the tune or the user. does anyone have a link for this?
      10-25-2022, 12:17 PM   #193
CrazyOneToo
They are probably just pretty busy. You can tune it yourself for free. I used the company below.
      10-25-2022, 01:50 PM   #194
nmcmill1
Trying to access the bimmerlabs site as many said it worked for them but it seems to be down? any idea of this is just temporary or are they no longer around?
      10-26-2022, 11:41 AM   #195
CrazyOneToo
Nope. I am not associated with them just knew about it.
      11-11-2022, 09:49 PM   #196
nmcmill1
The site is back up and I got the tune downloaded just need to do that actual swap now, thanks for all the help.
