      01-27-2010, 03:35 AM   #23
GP20
Originally Posted by DarkstarZero View Post
What do you guys think of the EAS VMR CSL Replicas? I was thinking about getting them in 19" Jet Antracite. They're about $1,000 and 25lbs, same weight as stock 18s.
I had a set of 19". The weight was about 27~28lbs front and 29~30lbs back. I hated them every mile I had them. Killed the acceleration and steering response, and made the car feel heavy and no longer agile.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      01-27-2010, 03:28 PM   #24
Starscream
Starscream's Avatar
Originally Posted by shift@red View Post
why not just get these? will be lighter than oem zcps and seem to have just as much if not more concavity to them...and at $899 you cant beat that.
http://www.m3post.com/forums/showthread.php?t=330710
Wow they are actually very nice,
Imola Red Roadster
      02-09-2010, 05:12 PM   #25
Starscream
Starscream's Avatar
Just bumping this again,
Do we need to run spacers on these or are they good to go out of the box?
Imola Red Roadster
      02-09-2010, 06:41 PM   #26
epbrown
epbrown's Avatar
Finally spotted a pic:
      02-09-2010, 07:10 PM   #27
Starscream
Starscream's Avatar
Stunning,
BTW do you run any spacers with yours?
Imola Red Roadster
      02-09-2010, 08:07 PM   #28
03BeastCharmer
03BeastCharmer's Avatar
257
Drives: '13 M3
On my ZCP I don't run spacers, but to run stock front track width you would need a 5mm spacer. Without spacers, the fronts look a little sunken.
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      02-10-2010, 08:04 AM   #29
F360C
Drives: E86 S54
Yu can run them just fine with out spacers but the front ZCP wheel is not the same offset as the OEM Z4M front wheel so it is a little sunken in. I think a 10mm spacer makes it look good but I went with a 15mm based on the recommendations from Rogue Engineering. I think the 15mm makes it look perfect but you couldn't run the 15mm with a stock alignment. It needs extra front camber so the wheel doesn't rub which is not a problem for me since I run -2.5ish. As far as the rear goes they look fine with out spacers but a 5mm spacer would make it look perfect. I was going to buy a 5mm spacer for the rear but I ended up picking up a set of 285 rear tires for stupid cheap to replace my worn 275s and I think the 285 will fill the arch just perfect with out the spacer
07 Z4 M Coupe AW/IR
      02-10-2010, 08:52 AM   #30
Starscream
Starscream's Avatar
Thanks Guys,
Have to decide if I should get these or a new exhaust,
then begs the question on what exhaust to get!
I don't want too loud so from research I'm thinking Remus, or SS powerloop,
I just really have a thing for the CSL's
Imola Red Roadster
      02-10-2010, 10:23 AM   #31
Beedub
starsscream ive got genuine CSLs on mine with the 8.5 up front instead of the 8 and they sit pretty much flush like the rears with no spacers at all, they look perfect, ill get some pics of the front, i personally wouldnt run spacers on any of my cars, ive got a pet hate for them!! like i originally said try and source csls if you can.
      02-10-2010, 11:32 AM   #32
Starscream
Starscream's Avatar
I looked into genuine CSL's and BMWNA can't order them,
Only the ZCP's
Imola Red Roadster
      02-11-2010, 01:09 AM   #33
epbrown
epbrown's Avatar
I looked into genuine CSL's and BMWNA can't order them, Only the ZCP's
Yep, the CSLs work without them (I thought your spacer question was about reps), but you can't get them here new. Cruise the E46 M3 forums and you'll likely find some for sale used. I snagged mine via Ebay.uk, but it was about a grand more expensive than ZCPs.
      02-13-2010, 08:31 AM   #34
F360C
Drives: E86 S54
Only the ZCP's
Found a set of zcps for sale....
http://www.m3forum.net/m3forum/showthread.php?t=307100
07 Z4 M Coupe AW/IR
      02-13-2010, 03:41 PM   #35
E86M
E86M's Avatar
Drives: E86 Z4 M Coupe
Yes, they look good on the car. I'd recommend looking around E46 M3 forums. Since I change back and forth between these any my stock wheels about every 3-4 weeks, I can tell you they are noticeably lighter. Stock wheels have Dunlop Star Specs, and these have worn Sumitomo.
wow these wheels looks great on your car Gerald
      03-02-2010, 08:08 PM   #36
Starscream
Starscream's Avatar
Ok got my CSL's today from Evan at Tischer,
God they are beautiful, there is no new, Like brand new lol
now guys who have these wheels,
I'll be running 245/35/19's up front, I see there have been a few sizes of spacers thrown up,
Are they really needed? and those who have them can anyone give me any links to buy them?
and what about bolts? stock ones fit or you need new ones?
Imola Red Roadster
      03-02-2010, 08:13 PM   #37
F360C
Drives: E86 S54
Are you lowered? If you are I would go with 10mm's but if you not lowered you can def go with 15mm's. I am running the 15mm's but then again I run alot of camber in the front and now have some really stiff suspension. For buying spacers I would look no further then Rogue Engineering! Those guys are great and you can drive to the shop to pick them up... I am going to heading there to pick up a short shifter once they get them back in stock. You will need new bolts but the Rogue spacers come with them and the best part is you can get the bolts in black! They also carry silver and chrome if you want.
07 Z4 M Coupe AW/IR
      03-02-2010, 08:34 PM   #38
Starscream
Starscream's Avatar
Stock ride height and suspension 15mm not too much?
Imola Red Roadster
