      01-01-2010, 06:21 PM   #1
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
19" question. offset+tires experience
Anyone using 245/35/19x8.5 with wheel et 22 front
and 275/30/19x9.5 et 20 rear???
please post pictures and any ideas about problems etc..
I will run them in a 2008 Z4MC with GC coilovers
      01-03-2010, 02:41 AM   #2
laidback
Drives: M's
Fronts will stick out...or run negative camber to fit but will wear the tires fast...
Live as if you will die tomorrow, but learn as if you will live forever." M.G
<img src=http://i251.photobucket.com/albums/gg289/l8dback/2012/ff8d7019.png border=0 alt= />
      01-03-2010, 02:46 AM   #3
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
22 is way too aggressive for the front. Even with significant camber I doubt you'll be able to get them to tuck behind the fender wall and, even then, it'll probably look goofy. The rears can work with a reasonable amount of camber, though.
      01-03-2010, 04:56 AM   #4
Diokaef
Engineer
Diokaef's Avatar
Thank you guys, and how about +35 for front keeping the rest of the setup??
      01-03-2010, 09:59 AM   #5
JCz04Bimmer
32
Drives: 06 Z4MC
That'll be better. Definitely doable with camber dialed in.
      01-04-2010, 05:53 AM   #6
Diokaef
Engineer
Diokaef's Avatar
Thank's
      01-27-2010, 02:03 AM   #7
Diokaef
Engineer
Diokaef's Avatar
I will be ordering this week my new wheels and I really hope they fit.
Going with 19x8.5 et35 front and 19x9.5 et 25 rear,
A bit of concern about rear ones but I will see it
      01-27-2010, 11:19 PM   #8
VitaminT
Drives: 2006 M Roadster
That setup looks pretty good. It seems most run a 8.5 et35 in front and 10 et25 in rear.
      01-28-2010, 12:29 AM   #9
Diokaef
Engineer
Diokaef's Avatar
they only have in 10 et20 so I can't go that way
      01-28-2010, 01:18 PM   #10
Diokaef
Engineer
Diokaef's Avatar
Originally Posted by shift@red View Post
heres a questions for all the guys who have done aftermarket.
I dont plan to lower my M coupe, but its possible with just springs. But lets just say no lowering for now.
What are my optimal (read: agressive but wont rub at all) offsets. I want them to sit pretty flush without too much negative camber.
8.5 front
9.5 rear
10.0 rear
depend of the offset
I would not go with more then 19" wheels and a good offset to have no problems would be 8.5 et 37 or 38 front and 9.5 et 28 maybe 27. I would not go with 10's in your case.
Tags
offset, rims, tires, wheels
