      10-14-2023, 09:53 PM   #1
rho123
Drives: 2013 128i - sold, 2007 Z4C
got electrical gremlins
My Z4C has the following gremlins:
I've read various threads on similar issues but exactly the same.
1. no turn signal sounds when the car is warm
2. wiper will turn on once after starting the car - intermittent but it happens on warm weather
things I done:
1. changed ignition switch due to intermittent non starting - usually in warm weather
2. disconnected the battery for one minute
Other possible causes I've read:
1. bad LCM - it will need to be replaced
Any suggestion is greatly appreciated.
Got I.C.E.?
      10-15-2023, 05:30 AM   #2
Huz-Z
Huz-Z's Avatar
Sometimes an older battery causes stuff like this.
      10-15-2023, 07:16 AM   #3
Steeler
Steeler's Avatar
2429
things I done:
Check that battery is good.
After that I would look into the GM5 body module that resides behind the glovebox.
