      11-09-2022, 12:19 PM   #1
Ascanio
Drives: Mazda MX-5, BMW Z4 M Roadster
M Roadster starter motor, Valeo or Bosch?
Hi! On FCPEuro they have a Valeo remanufactured starter for 700+ dollars, and a Bosch remanufactured for 200. They both are stated to fit.
Any reason why I should spend the extra 500 dolla?
      11-09-2022, 03:28 PM   #2
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
They have both a Valeo and a Bosch rebuilt for $200 each and a BMW rebuilt for $700.
The $500 extra is so you can say, "Genuine BMW."
2008 E86 M coupe
      11-09-2022, 03:35 PM   #3
Ascanio
It’s like when I got the coil packs. Genuine BMW 70 online (167 dollars each at a ritz BMW dealership in Savannah, just to illustrate what a ripoff that place is), while the coils sporting just the Bosch brand, same part, 30 dollars (or 137 dollars less than at the dealer).
      11-09-2022, 06:25 PM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Valeo is the manufacturer of the "OEM" starter. I would stick with Valeo if possible... not because it's better, but the ECU is very sensitive to electrical changes. The programming is over-engineered to model the alternator's output and response, and any deviations in hardware *could* cause odd behavior. I will caveat that I have not tested the Bosch alternator. I can confirm that cheaper Autozone alternatives WILL cause issues.
      11-09-2022, 06:48 PM   #5
Ascanio
Thanks! Good to know! Yes Valeo and Bosch are both OE suppliers and respectable, and I wouldn’t be surprised to discover that some models or MY have one and others have the other
      11-10-2022, 02:08 AM   #6
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
I can confirm that the OE one is a Valeo as I have changed mine a few years ago, still have it laying around since the starter wasn't the problem.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      11-10-2022, 06:32 AM   #7
Ascanio
What symptoms did the car have? And what was the problem?
      11-10-2022, 10:08 AM   #8
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Problems to start, especially when it was cold and wet (autum) or when the car hadn't been driven for a couple of weeks. When it didn't start it didn't engage the starter enough on the flywheel and grind the gears. Turned out that the brand new battery was a 63 amp one, got one for a regular Z4 and not a Z4 M.
      11-10-2022, 10:12 AM   #9
Ascanio
I put a DieHard H7 battery. It does have SOMETIMES extremely slow cranking on a cold engine, even 5 hours after a drive, so slow that it will fail to start. Will try 4-6 times. Then all of a sudden fast cranking and engine starting fine.
A German mechanic inspected it, held the car for a couple days, told me the starter motor is going bust.
Then told me the part is 1500 dollars, refused to install one I would provide.
      11-11-2022, 10:09 AM   #10
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Have you changed the ignition switch? When I had starting problems I did it in this order:
1. Ignition switch
2. Starter
3. Battery
If I only knew the hack that works only with batteries gave me the wrong one.
      11-11-2022, 10:11 AM   #11
Ascanio
I do have a replacement ignition switch in my drawer. Have forgotten about that!!!
Yup will have to get to it and replace it to see if it helps
