Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > Canada
      04-19-2011, 06:47 PM   #23
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Finnegan View Post
I suspected as much. Crawling around on your back under the car loses its charm at some point. I'll still do it, but I'm not happy about it, and the older I get the more my shoulders are unhappy about it as well. "Say sonny, can you crawl under there an loosen up that there bolt for me?"
      04-19-2011, 06:48 PM   #24
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Got the gear all set up.
Play time this weekend, we'll be setting up Caddy's new GCs.
Just loaded the car up! Your GC's have not arrived yet?
2006 Z4MC - #LL93158
      04-19-2011, 06:58 PM   #25
Shipkiller
Shipkiller's Avatar
Drives: Me
Which makes basic mechanical repair and maintenance a picnic in comparison I'll bet and explains your knowledge of tools, fastening methods, and so on.
You do learn things. By trade, I am an Electrical Engineer..
My unofficial title is Geek.
My official title is Submarine Combat Systems Electrical/Computer Engineer... which is way too long to say.. I normally use my unofficial title...
      04-19-2011, 07:41 PM   #26
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
I've learned a hell of a lot hanging around here, and I'm "smart enough" now to know just how little I really know. I have to say I learn something new just about every time I'm over here.
My unofficial title is Data Geek. I have a nice corporate title that includes Analytics and a bunch of other things in it, but I usually just go with my first name. I'm not a big fan of titles and prefer to look at what people produce/deliver and the means by which they do so (e.g. character).
Man, less that two pages to take this thread off on some tangent! Meh, that's what I like about it here, lots of good info and some interesting discussion as well.
      05-01-2011, 07:27 AM   #27
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
We had our inaugural corner balance session yesterday with Caddyshks car.
It was a very interesting session that yielded some great results.
Here is the 'before' data.
(...not sure that we read the 'before' ride heights exactly)
And the final data
      05-01-2011, 11:59 AM   #28
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
      05-01-2011, 02:44 PM   #29
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
me next please
should i get an alignment done before or after we corner balance?
///M - Some Mods 'N Stuff
      05-01-2011, 03:11 PM   #30
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Originally Posted by VinnieAces View Post
me next please
After...
      05-01-2011, 04:14 PM   #31
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^WHS
Just get your ride heights where you want them.
Then just ball park the camber & caster.
Do you have your COs in already?
      05-01-2011, 06:36 PM   #32
VinnieAces
VinnieAces's Avatar
^WHS
yep had em in for about a week so far but only actually drove her yesterday
      05-03-2011, 01:10 PM   #33
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
Did you disconnect the swaybars when scaling the car?
Usually you need adjustable SB end links to proper scale/adjust the car.
If not you end up loading up the swaybars.
      05-03-2011, 01:18 PM   #34
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
That's a good point about the sways.
Since they aren't adj. sways, are you better to leave them connected or not? (car sitting dead nuts level)
When you hook 'em up again, won't you shift things?
We'll probably end up with aftermarket sways & adj links eventually, but not this year.
We're going to set the alignment then run it on the scales again.
It will be interesting to see if the alignment shifts things at all.
      05-03-2011, 01:36 PM   #35
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
I found alignment can have a noticeable affect on corner weights, it all
depends on how much the alignment is changed. (even tire pressures affect
results - if you track you car you should set your tire pressures to your hot pressures)
As for the SB - you need only one adjustable link in the front and back to
properly set up your car. If not the car will not handle the same in left turns
as in right turns. Having the car behaive the same way in both directions is the
purpose of corner balancing your car with a 50/50 diagonal split.
In short to do it right and get the benefits you really need to set your corner
weights with the bars disconnected and then reconnect them and adjust the
endlink til to achieve the same readings.
Hope this helps...
      05-03-2011, 02:07 PM   #36
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks for your help on this.
...there's nothing like experience.
      05-03-2011, 09:43 PM   #37
VinnieAces
VinnieAces's Avatar
PM replied
      10-01-2011, 05:25 PM   #38
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
This died already?
Played with the scales lately? How were Vinnie's results?
need moar! lol
      10-01-2011, 06:18 PM   #39
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yeah, I use them every time I tweek the suspension.
Vinnie's car was MIA most of the summer, AFAIK it hasn't been done.
      10-01-2011, 07:33 PM   #40
VinnieAces
VinnieAces's Avatar
yep my car hadnt a chance at it yet, infact i still havent even gotten an alignment done yet lol
