02-10-2012, 03:59 PM | #2 |
instagram 997turbotom
279
Rep 7,376
common issue, you most likely have a bad seal. Here's what I did:
-remove bumper, then remove headlight -remove bulbs from the headlight -set the headlight down, and blast it with a space heater or hair dryer from the front (glass) side until all moisture is gone -buy some gasket sealer, or silicone, and you can use your fingers to go over the cracks in the area where the black of the headlight is attached to the glass. You know... the part that manufacturers seal up with glue or some shit thats it. Doesn't have to be super clean, its all hidden
02-10-2012, 04:18 PM | #3 |
Rep 11,667
it's usually just the gasket for the access cover on the back of the light.
I just cleaned it up & the moisture went away ......and hasn't returned
02-10-2012, 06:00 PM | #4 |
Rep 987
Like these guys have stated you have to dry it then clean/reseal it. I had to do that on my previous BMW. I even had BMW replace some parts and it still got moisture inside. After I sealed it myself the problem went away.
02-18-2012, 01:36 AM | #5 |
Rep 308
I had same problem, just remove the back access cover and use dryer to heat up inside to get rid of the moisture. take a vasaline and go over the gasket on the back cover. put it back in.
02-18-2012, 04:16 AM | #6 |
Rep 518
I have the same problem when rains
2005 z4 2.5i/// Aero front bumper, m rear bumper,08 rear lights, custom quad exhaust, matte black front grill, OEM alarm, llumar security film,m wheels, HID lights, LED interior and trunk light,Ipod integration, stubby antenna,tein s-tech springsx
