01-21-2012, 12:07 PM | #2 |
MPOWERD
15
Rep 338
Drives: 2010 M6
Yes as you will also have to bleed the clutch.
2010 Dinan M6 Coupe--2006 Z4MC--1994 E36/M3 Track Prepped
BMWCCA #442445 YouTube Channel: http://www.youtube.com/user/Randy23185 |
01-22-2012, 04:21 PM | #3 |
Rep 219
Drives: 2007 BMW Z4 M Coupe
Garage List 2000 Volve S70 se [0.00]
2000 Triumph Dayton ... [0.00] 2007 Husqvarna TE250 [0.00] 2002 Ducati Monster ... [0.00] 2007 BMW [0.00] |
Curious: what does bleeding the clutch have to do with changing brake fluid? Why is is significantly easier to do them at the same time? Not familiar with the specific procedure on the Z4, but I'm curious, as I do plan on doing the CDV delete this spring.
01-22-2012, 05:18 PM | #4 |
Rep 2,541
My guess is the brake fluid reservoir doubles as the clutch fluid reservoir so, when bleeding the clutch you'll have to top off the brake reservoir.
01-22-2012, 05:25 PM | #5 |
MPOWERD
15
Rep 338
Drives: 2010 M6
The clutch is pressurized utilizing the brake fluid reservoir, it has a bleed nipple the same as the brakes, just a little hard to reach. If you plan on flushing your system then you want to flush/bleed that out as well. Search is your friend as there are a lot of write ups about this. I did the CDV delete and changed out to SS brake lines at the same time. Figured since I had the car up on the Jack stands I might as well get it all done.
