      03-19-2013, 02:20 PM   #23
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Originally Posted by drbvac View Post
I am no expert but the R +45 may be out too far ? Most used here in 9'5 are 22 or around there ? Gee those wheels are not cheap are they ?
is this the spreadsheet you were referring to >
https://docs.google.com/spreadsheet/...WeUg1b2c#gid=0
That's one; there's slightly modified and more sortable version I have been working on, but I can't link to it on my phone (or add the right "share" rights to it). Will try to post later in OP.
      03-20-2013, 03:31 PM   #24
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
What wheels
Originally Posted by Jony722si View Post
so I did this check, is inner clearance 14mm less mean like it will appear like i put on a 14mm spacer on my OEM wheels?
whats outer position means?
Are the wheels on your car 8" with a 50mm offset?
The stock on an M are 8-42 AND 9 -30 The change may not be as drastic as this looks
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
      03-20-2013, 06:50 PM   #25
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2006 BMW z4  [0.00]
2009 Bmw 135I  [0.00]
2022 BMW M4C  [0.00]
2009 335i  [0.00]
my rear rims is spec actually 8.5 with +50. mistake while I doing the spec check.
no Z I/SI guys here to provide any information @?
here is the look of the wheels!!!! want to get them now!!!
      03-22-2013, 03:44 AM   #26
StigJ
StigJ's Avatar
Norway
333
Drives: '06 Z4 Coupe & '14 F30
My z is lowered by h&r spring, does this spec apply to it as well? I phoned BC racing in Taiwan and ready to get HB 09s. They recommend about the same spec F +35 8.5 j. R +45 9.5j. Any suggestion ? Thanks!
You need to go lower with the offset in the rear. 8.5 ET35 in the front is good.
Here is mine with different wheels and offsets. Lowered with H&R springs on M-Tech shocks.
9x19 ET44 front and rear. 235/35 and 255/30
8,5x19 ET34 front and 10x19 ET41 rear. 235/35 and 265/30.
Here I have added camber plates.
Rubs like hell without the plates.
This is both my daily and track setup.
Ive had 3mm spacers in the rear to get ET 38. Fender barely touched the outside of the tire.
And 8,5x19 ET35 w/235/35 and 9.5x19 w/ 275/30
      03-24-2013, 03:14 AM   #27
Jony722si
The Wrapgician
Jony722si's Avatar
Drives: z4si
2006 BMW z4  [0.00]
2022 BMW M4C  [0.00]
2009 335i  [0.00]
i love this set up tho, look flash and clean!!!
similar to the spec I would go for
is the rear wheel ET 35 as well?
not sure what is M suspension...does it makes different even we use the same spring?
[/QUOTE]
      03-24-2013, 06:05 PM   #28
Finnegan
Finnegan's Avatar
Link to fitment spreadsheet added to OP. Please add your specs and notes.
