09-15-2014, 09:49 AM | #1 |
Rep 1,107
While drying my car yesterday...
...I was drying the doors/mirrors, closing the doors a few times to get any water out of the doors and mirrors. It struck me that since our mirrors fold upwards, maybe I can drain any water out of them by folding them. Eureka....or more like "why didn't I think of that sooner".
Any other car rinsing/drying tips out there specific to our cars? |
09-15-2014, 10:01 AM | #2 |
Rep 247
I use a backpack plower to blow the water out of all the crevices, makes drying a little bit easier..
| 2008 Interlagos Blue Z4MC | | AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust | |
09-15-2014, 11:38 AM | #3 |
Rep 501
Drives: 2015 M4
Wash it, take it for a high speed burn, then do a final wipe off - may not work too well on darker colors (possible streaks), but certainly works well for Space gray!
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily) 2021 Alfa Stelvio - Red/Black 2013 135is - LeMans Blue/Gray 2003 M5 (56k miles) - CB/Black |
09-15-2014, 02:21 PM | #4 |
Rep 1,991
09-15-2014, 02:32 PM | #5 |
Rep 204
elerner- I'm intrigued cause the mirrors always hold water which later drip and dry, but won't the folder mirror act like a cup? or does the water have a way to pass through to the other side (ground)?
and Seattle - you don't get any swirlies when you come back later to dry? I'm worried the dust that will glue itself on during the drive will then scratch the finish when you wipe down later... maybe swirls aren't as apparent in silver! -gc |
09-15-2014, 02:58 PM | #6 |
Rep 10,662
After washing my car, I always take it for a 1-2 mile trip around the block. This blows all the water out of the cracks, and only takes a minute or two to wipe the car down one last time. Good tip. ;P
09-15-2014, 03:56 PM | #7 |
Rep 1,134
Drives: '07 M Roadster
I wash the car with the mirrors down then while drying I rotate the mirrors to drip the water out.
I also do a final rise by taking any attachments off of the hose and just let the water flow out of the hose at normal pressue. For the hood I have the hode at the front of the car and have it push water up over the hood so a thick layer of water is there and found that I have less water to dry up because the bigger mass of water pulls almost all of the water off of the car. A little hard to explain, but basically a more gentle and thicker flow of rise water leaves less water drops/spots than spraying the car.
09-16-2014, 08:16 AM | #8 | |
Mechanical Engineer
96
Rep 1,025
09-16-2014, 08:22 AM | #9 |
Rep 1,107
Yes, when folded up the trapped water drains out from around where the mirror is hinged.
09-18-2014, 12:17 AM | #12 |
636
Rep 3,124
Yep. "The Absorber".
Maybe it's not the best thing for the finish, or preserving the wax, but I have hard water, Interlagos Blue, and the humidity here rarely gets above the teens. You want to see a guy move fast. You should see me drying it before it dries itself and gets spotted.
09-18-2014, 05:23 AM | #13 |
Rep 104
Drives: 3.0si Roadster
My Z is black and it will spot very easily, I mostly wash the car at night or early morning. I dry it with two Microfiber Towels. (One in each hand) wringing them at every section.
09-18-2014, 07:38 AM | #14 | |
Rep 4,057
Huz-Z
09-18-2014, 08:04 AM | #15 |
Rep 247
I bought like 40 micro fiber towels, after blowing off the car...I probably use 20+ drying off the rest..then use quick detail while drying sometimes..when dirty toss them in a bucket and wash them to use again next week...
09-18-2014, 11:14 AM | #16 |
Rep 1,107
I've got two of the waffle texture drying towels that I use. One is from Meguiars that is very thin that I use for the first drying pass, the second is a really thick one from Autogeek.net (http://www.autogeek.net/cobra-guzzler-hd-towel.html).
09-18-2014, 02:45 PM | #17 |
Rep 1,909
I finally got my retractable compressor hose installed on the ceiling in my garage so I now use that for everything. Drying the car, detailing the interior, tires, sweeping the garage etc. It's a great easy upgrade to the garage.
09-18-2014, 05:44 PM | #18 |
Rep 876
And the debris that get stuck on the car will get rubbed into the paint and might cause micro scratches. No thanks...
09-21-2014, 06:07 PM | #19 |
Rep 204
elerner I just tried your tip today and it worked brilliantly.
The residual water that used to creep out of the mirrors slowly after drying the car always bugged the hell out of me. Quick flip and all of it drained out like a charm. If you were down here, I'd buy you a beer!! Thanks again, -gc |
09-22-2014, 07:08 AM | #20 |
Rep 145
When I wash the car I use the backpack blower to dry it.
Recently I've started using Chadwick's triple play, I wash the car far less often now. It's great stuff, highly suggest it if you haven't tried it. |
09-22-2014, 02:24 PM | #21 |
Retrograde
18
Rep 390
Genius tip OP! Don't know why I never thought of that haha.
I have an air hose connected to my tank in the trunk and usually use that to blow out water from the crevices.
09-22-2014, 10:04 PM | #22 |
Rep 413
Drives: Z4 3.0, CLS63 AMG
I have soft water running to the hose that the cars are washed, so that's the first step that helps. Second, only if you wax your car regularly: This will cut your dry time in 1/2. Take the attachment off of the hose and let the water run over each panel and depending on the wax you've used (I've been on a Blackfire Black Ice kick) you'll need very little drying (30-45 sec tops).
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG |
