      10-22-2013, 08:55 AM   #23
Huz-Z
Huz-Z's Avatar
Originally Posted by i2ichal2dZ4M View Post
The car can have two washer pumps, so if I understand correctly, Part #4 is for the headlamp washer system for cars equipped with that and Part #6 is for the windshield washer system - Per this site: http://realoem.com/bmw/showparts.do?...83&hg=61&fg=45 .
So the one on eBay is just the windshield pump, which is all I would ever need. Cheap - I may grab a couple!
Huz-Z
      10-24-2013, 02:52 PM   #24
chickdr
Drives: 2006 M Roadster
One more question- I should be getting the new pump today and took the old one out in anticipation. It doesn't seem to be leaking so I may have bought the wrong part(although the reservoir was wet only below the pump). In removing the gasket from the bottle it appears to be one with the strainer. I assume the new "gasket" which comes with the pump I ordered will also have the strainer attached?
      10-24-2013, 05:33 PM   #25
StickMon
StickMon's Avatar
Drives: 2006 MR
I believe it does. My pump didn't come with one, I ordered it separately.
The pump leaks up the shaft seal, and out a little weep hole on the side near the bottom of the motor. It may not be obvious that it's leaking.
      10-24-2013, 06:22 PM   #26
chickdr
Thanks! That would make sense about the leak. I don't see/feel a crack in the reservoir so hopefully that will solve it.
      10-24-2013, 07:44 PM   #27
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
from the outside it looks normal. inside is where you see i posted all the rust and damage
      10-25-2013, 10:10 AM   #28
chickdr
One more comment- the part listed above is what I purchased for $6.88. I realized later that the grommet included is not what you need as we need the one with the strainer attached. Buy the same pump without the grommet for $4.97 here: http://www.ebay.com/itm/BMW-3-M-X-Z-...fff2d9&vxp=mtr then buy the grommet with the strainer attached if needed. I bought one for $3.80 shipped(kind of funny the pump and grommet/strainer are almost the same price.) Too bad this place doesn't supply the grommet we actually need with the pump for 6.88...
      10-25-2013, 11:46 AM   #29
Huz-Z
Huz-Z's Avatar
Thanks! Where did you get the grommet strainer?
Cheers!!
Huz-Z
      10-25-2013, 01:42 PM   #30
chickdr
Cheers!!
I bought it on EBay as well, here is the listing : http://www.ebay.com/itm/BMW-OEM-6166...42c614&vxp=mtr The part # is 61667006063
