      08-01-2010, 06:04 PM   #45
jmillet
jmillet's Avatar
64
Originally Posted by silversprint View Post
^^proper camber will also depend on stiffness of suspension. What spring rates and swaybars on the car?
Stock sway bars and 500# front, 600# rear.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      08-01-2010, 08:51 PM   #46
Shereef_Osman
Drives: 06 Z4MC & 89 325is
I run 265/35R18s all round on Apex Arc8 9.5" rims. No issues with rubbing. Mind you I have the camber plates in the front with max camber (~3.5). Strictly a track setup.
      02-18-2011, 04:04 PM   #47
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
Originally Posted by The HACK View Post
In my NOT SO HUMBLE opinion, the MZ4 Coupe does not like a non-staggered setup. Unless you can shove 265s or wider up front (you can't without some significant modification) going non-staggered has more drawbacks than rewards.
And while going non-staggered appear to save you a few bucks on tire cost, all it's doing is shifting the cost of replacing 2 tires sooner to replacing 4 tires later...I'm sure if I'm some sort of math wiz, or if I'm REALLY asian, I'd be able to explain to you that over the long haul, your cost is the same between being able to rotate the wheels/tires and replacing them 2 at a time instead of 4 at a time.
The REAL cost saving comes from having the right alignment so your tires wears evenly inside AND out, not front and back. Again, in my NOT SO HUMBLE opinion.
I like this reply
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
