      07-04-2017, 10:36 AM   #1
3002 tii
3002 tii's Avatar
2288
Need a Thin Walled 17mm Socket
My current one isn't getting the job done and still leaves nicks on my lugholes. Seems like Sunex is the popular choice but I've read mixed reviews. Can anyone recommend a quality piece that has protective coating on the outside with 1/2" drive?
Follow for latest mods
      07-04-2017, 11:06 AM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I just get a good quality socket then add shrink tube to the outside.
      07-04-2017, 11:45 AM   #3
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
interested as well
      07-04-2017, 12:39 PM   #4
conceptautogroupla
Drives: Z4MC
Check these out!
https://www.matcotools.com/catalog/p...NWALL-IMP-SKT/
https://www.ecstuning.com/b-schwaben...eces/pps-1721/
      07-04-2017, 12:45 PM   #5
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Bought these. Works fine.
ABN 3 Piece Lug Nut Impact Socket Set ½ Inch Drive Metric 17mm, 19mm, 21mm, 5 Inch Extension Bar https://www.amazon.com/dp/B01BUI5XYS..._qGLsjvYYu1WZT
      07-04-2017, 03:53 PM   #6
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Good idea. In a pinch blue painter's tape works well too.
      07-04-2017, 06:04 PM   #7
m5m3mc
Drives: M-B C63
I was in the same predicament as you and bought a sleeved socket like those mentioned above which ended up being too thick. I searched hard on eBay and found a super-thin-walled socket that worked great. It might even have been a spark plug socket as some applications require that type of thin-walled socket for the plugs. GL....
      07-07-2017, 12:44 PM   #8
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
I have this one that has the extension integral to it. It's fit OEM BMW wheels so far with no issue, and the protective sleeve can be slipped off if you find you're in an extra tight lug hole.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Top Down 365
      08-15-2017, 02:39 PM   #9
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
deleted
      08-15-2017, 03:47 PM   #10
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
I did the exact same thing. Shrink tube. I also don't let the power tool spin too much. I put my hand on the socket and stop the socket from spinning after it has loosened the lug nut. Then I use my left hand to support the socket and my right hand to unscrew the lug nut the rest of the way. It's ridiculous but it works.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      08-15-2017, 05:09 PM   #11
The HACK
The HACK's Avatar
1821
I used to use a set of Griot's Garage thin-walled deep sockets:
Worked great, except there's a plastic/rubber lining on the inside. When I switched over to studs it prevents the nuts from fully seating in the socket (the studs interfere with he plastic/rubber lining on the inside of the socket). I tried a couple of impact sockets and it would rub against the holes in the aftermarket wheel. This is the one I use now (in conjunction with a small 1/2" extension):
https://sktools.com/shop/34267-17-mm...ct-socket.html
Seems to clear both the Apex wheel and OE wheel lug holes fine. With the shortest 1/2" extension attached it gives the torque wrench plenty of clearance from the wheel's spokes. One of the thinnest walled impact socket I've seen.
86Zed932.00
      09-02-2017, 02:50 PM   #12
Uncle Russ
Rocket Scientist
Uncle Russ's Avatar
Drives: '08 M Roadster
I bought Home Depot's house brand, Husky, 3-piece wheel protector impact socket set (17 mm, 19 mm, 21 mm) for $30. The 17 mm socket fits the wheel studs on my stock ///M wheels just fine.
2008 ///M Roadster
      02-02-2018, 09:13 PM   #13
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
I have electrical tape wrapped around mine. Literally lasts years with very frequent tire changes (3 cars with track and winter and summer tire swaps).
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      02-15-2018, 01:03 PM   #14
Mannymux
Drives: 2007 BMW Z4M Coupe
Can you use an extension for an torque wrench?
      02-15-2018, 04:53 PM   #15
3798j
3798j's Avatar
11426
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
Yep. Just be certain you keep the wrench perpendicular to the socket.
