      04-19-2015, 10:53 AM   #1
BGR
Drives: C7 GS 7MT; e90 M3 6MT
Z4 Trailer Transport/Tiedown Questions
For those of you that trailer your Z to the track, how do you secure the vehicle to the trailer? What tie-down points do you use (or do you just go through the wheels?)?
My Z4c is lowered so not a lot of clearance to get under the car.
      04-20-2015, 01:08 PM   #2
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
I can't say that this is the best method, but I have been using straps through all wheels. It's said that this could pull the car out of alignment, but I can't imagine this is putting any more stress on the wheels than hard cornering on the track. The only issue is though that if coming in from the track you have to let the wheels cool down a bit before threading the straps through or you may melt the nylon (or whatever synthetic fabric they use)
      04-20-2015, 01:14 PM   #3
The HACK
The HACK's Avatar
1821
If you pop out those square pucks where the lift points are, there are horizontal slots cut for you to loop a tie-hook to.
      04-21-2015, 07:54 AM   #4
BGR
Good call.
      04-24-2015, 12:36 PM   #5
joelselman
Drives: 2005 Z4, 2001 530
Probably not "factory approved" but I've been using the standard tow hooks with a tie down to each side in my closed trailer for quite some time with no ill effects.
      04-24-2015, 02:26 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Tie down hooks $6
      04-10-2016, 10:42 PM   #7
longress
longress's Avatar
Drives: 2007 Z4M Coupe
Ian, where does the tie down hook connect to the car at? I'm trying to figure out the best way to strap the back of the car down. I've thought about tire straps but wondering what others do when they haul their cars.
      04-11-2016, 07:00 AM   #8
BGR
FYI, this is what I ended up going with. Works quite well. Mac's Tie Downs with the wheel savers.
      04-11-2016, 07:59 AM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
You have to remove the rubber jacking blocks, then the hook takes its place.
The other thing I've seen guys use are over the tire web/slings.
They seem to like them a lot.
Easy to place on top of the tires and eliminates rubbing from looping through the wheel.
      04-11-2016, 02:05 PM   #10
longress
longress's Avatar
Thanks gents. Picking up an enclosed tonight
      04-11-2016, 03:39 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Very nice!!
