04-18-2016, 01:40 PM | #1 |
Rep 688
Vanos Replacement
Just thought I'd give some info. At 76k miles I started to noticed a noise that was not normal. Most of the noise was from around the timing chain tensioner area or a little higher. A repair to replace a throw-out bearing(did not stop the rattle)along with a clutch and pressure plate(because I am in there anyway). I then replaced the water pump and all the tensioner pulleys (still have the rattle)
The only thing left is the Vanos. Next week the car will go under the knife to have a rebuilt DR. Vanos upgraded unit, new cryo exhaust cam gear, an anti-rattle kit, and new cam gear bolts. Nice to drop about $3k in the past 6 months on the car. I just can't sell the car AS-IS, because with that noise it would not bring the right amount of money. AND honestly there really isn't anything else out there that impresses me enough to go buy, well without spending $85k. This is more of a heads-up guys post. The vanos is the S54 weak point and around 80k miles you all need to start listening to you engine. Yes $3000 isn't fun to spend on repairs, but its far cheaper than another S54 engine for the car!
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor |
04-18-2016, 02:51 PM | #2 |
Hug the road... Carpe Asphalt
105
Rep 722
Thanks for sharing. What year & Month is your M? Didn't they introduce a Vanos upgrade on the assembly line sometime in 2007 - meaning some cars are affected and some are not?
2007 BMW ///M Coupe
04-18-2016, 03:05 PM | #3 |
Rep 688
My build is a August 2006
I think there was something changed later about the cam gear bolts shearing off, but I'm not sure about the vanos changing
04-18-2016, 03:10 PM | #4 | |
Rep 11,667
That happened part way through MY07.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 04-18-2016 at 09:17 PM.. |
04-18-2016, 06:09 PM | #5 |
salty cowboys fan
6158
Rep 3,406
Overhauling mine too this weekend with the Beisan pieces. No symptoms, taking care of it before it blows rented the tools online, can't wait!
04-24-2016, 09:13 AM | #6 |
Rep 400
I did all of the Beisan upgrades last year to take care of this before it became a problem. If you are getting the rebuilt vanos assembly with the smaller oil pump holes you shouldn't need their cryo hub unless yours has a broken tab (my opinion). I also got the Lang Racing upgraded hub and sprocket bolts. After this the only thing your vanos might eventually need would be an upgraded solenoid unit. Beisan is the only people resoldering those things.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500 |
04-24-2016, 11:14 AM | #7 |
Rep 2,866
OP,
Did the Vanos Overhauled fixed your noises? Curious to hear what would cause such thing. Why did you decide to go cryo exhaust cam gear instead of the less expensive drilled disc solution? Did you have a broken tab? I did a similar overhauled about a month ago => http://www.zpost.com/forums/showpost...&postcount=730 I couldn't believed how much quieter just a few tighter tolerance pieces would make such a dramatic difference. The car ran fine and it didn't have any issues prior to the Vanos rebuild, I needed to do a valve adjustment at the time and decided that "while I was in there" kinda thing. It's just one thing that I can cross off the list that I have to worry about. Now I have to start saving for the inevitable bearing job Last edited by XMetal; 04-24-2016 at 11:19 AM.. |
04-24-2016, 02:17 PM | #8 |
salty cowboys fan
6158
Rep 3,406
Just wrapped up my vanos overhaul a few minutes ago, I also was impressed with the Beisan pieces. Tons of play with the OE pump disk, lots of rattles... Beisan disk is a perfect fit. I was trying to get it to rattle (on the bench) and couldn't!
04-24-2016, 09:59 PM | #9 |
Rep 632
Haven't been around here much in quite a while so if this is common knowledge, I apologize. Are y'all having to lift the engine or shift it rearward to get the necessary clearance to remove the vanos unit? Seems very close to the rad support compared to the M3, as I recall.
Mine is a real rattler, but always has been. After all the positive info about the Beisan stuff, been thinking about doing the job preemptively as well. |
04-25-2016, 08:14 AM | #10 | |
Rep 400
04-25-2016, 08:47 AM | #11 |
Rep 632
Thanks for the link to your write up. Very helpful. Nice work with the repair too.
Between your write up and Kapt's write up, plus the Beisan info, there really is no guesswork to it. This seems like a good opportunity to swap cams if one was looking to install hotter cams, no? It doesn't seem like there would be much more to do since with this vanos job you are pulling cam gears as well. Any thoughts on this? Last edited by onebluemcm; 04-25-2016 at 08:58 AM.. |
04-26-2016, 08:13 AM | #12 |
Rep 688
Ill update after I get the car back at the end of the week
04-26-2016, 11:03 AM | #13 | |
salty cowboys fan
6158
Rep 3,406
04-26-2016, 02:01 PM | #14 | |
Rep 2,866
04-26-2016, 06:13 PM | #15 |
salty cowboys fan
6158
Rep 3,406
^^ you know I'm not so sure it does, I'm looking at some pics I took while the valve cover was off and I see a series of caps running down the camshafts, 2 bolts apiece. If you have all the front interference off, maybe they can be lifted out? Just guessing
Not sure how the springs come out or if you need anything to relieve the tension Last edited by yousefnjr; 04-26-2016 at 06:36 PM.. |
04-26-2016, 07:33 PM | #16 |
636
Rep 3,124
I'm no expert, but I'm pretty sure you can get the camshafts out if you take the hubs/sprockets off.
That said, I don't think you can just remove the journal bolts, pop 'em off, and pop new ones on. Pretty sure there's a clamp fixture that you'll need to hold them in place and gently decompress/recompress the valve springs. The camshafts are hollow, and can be bent if not evenly stressed, and the journal bolts are not long enough to decompress/recompress the valve springs on their own. But you may have already known all that.
04-26-2016, 10:06 PM | #17 | |
Rep 632
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
04-28-2016, 09:49 AM | #19 |
Rep 1,107
At 56K miles my engine has some VANOS noise between 3,000-3,200 that doesn't go away until the oil temp has been at full operating temp for about 10 minutes. I did a C300 hub last year when during my valve adjustment my indy found a broken tab. I'm thinking I'll wait until my next valve adjustment at around 75K until I do what the OP has done (new VANOS unit and rattle kit).
Gotta pay to play. |
04-28-2016, 10:47 AM | #20 |
Rep 688
UPDATE- Well some good and some ??? news
Vanos did need replacing, nothing broken on the vanos or gears but was showing a great deal of age. During the Vanos replacement it was found that my upper right timing chain guide lower tab had broken off. I now have to have the oil pan removed to check and see if any damage was done because of a piece of plastic flying around all over the engine This engine is really making me want my E30 M3 back with that little S14 engine.
04-28-2016, 11:11 AM | #21 |
salty cowboys fan
6158
Rep 3,406
Bummer. I wouldn't be surprised if the noise you were hearing was just the broken guide, and your vanos unit is OK. Did you see it yourself, or get any more detail from them on what's wrong with it? Expensive piece to replace needlessly
04-28-2016, 04:23 PM | #22 | |
Rep 400
That part doesn't usually fall into the engine when it breaks. It is still held in place by the timing chain. It might have if they weren't careful while removing the tensioner though. I'm pretty sure your old vanos unit is/was just fine. I would bet that replacing the tensioner alone fixes your rattle. Are you getting a core refund for your old vanos unit? If not I would ask for it back. I don't trust companies that sell "remanufactured" parts to tell me mine was bad without any specifics. I tend to think they just want to maintain their inventory. I'm sure they'll just clean up your unit and put it in somebody else's car. I'm not an expert by any means, I'm just stating what I've read on the internet and what I've seen rebuilding my vanos. If something dropped into the oil pan, then it definitely needs to be retrieved. Rant over. This makes me frustrated and I'm not the one dishing out the money!
