      01-01-2012, 09:53 PM   #23
habitat412
Drives: 2008 Z4 M Coupe
Man this kit looks serious. I've been waiting for HPF's Z4M turbo kit to be released, but this one just seems to look better, it's probably that twinscroll turbo manifold that's just a beauty!
      01-02-2012, 03:25 AM   #24
Beedub
Originally Posted by ZooyorQ View Post
Hey Beedub! Its Marcus from E46F.
There is definitely a bunch of knowledge that could be replicated. I would call Shawn/Andrew at Lutz Performance in Tampa. They build some amazing BMW's down there and thats why we brought it there.. even though its the FURTHEST spot from Nor Cal possible.
Tell them I (Marcus) sent ya. They'll hook you up with a Turbo Z4M, or anything really for that matter.. Shawn is an incredible fabricator!
hey marcus!! glad to have you over here!!! BTW love that video..... thats the type of video that makes me make cake to watch!! pro-efi is the real deal imo...... i just love what it does!! This z4m is serious and im loving all the tuned z4m's coming out, its a perfect base to mod imo..... marcus, thanks for making this post and make sure you stick around ;-) love your m3 btw..... flex fuel makes me seriously consider pro-efi, but im not sure how it works with supercharged setups....
      01-02-2012, 07:29 AM   #25
JB 007
JB 007's Avatar
Cyprus
44
Drives: Z4MC RRS MINI...
Wow..This is what I waiting for..Amazing
Subscribed..
Z4MC_Black Sapphire/Imola-_-DMS ECU ll H&S cat-back ll H&R coilovers ll CF Lip ll Lamin-X ll Matte black kidneys ll Afe drop in ll Afe intake elbow ll RPi scoop ll LeatherZ imola shift boot ll ZHP knob...
      01-02-2012, 10:29 AM   #26
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
It will be running a ProEFI 128 EMS, not sure on the PSI yet.. somewhere likely between 13-17 I'm guessing, its going to be a flex fuel car though, so it will run a mixture of E85 (Ethanol) and Gas.. or just straight Ethanol. It is having a surge tank built as well.
The Z4M uses a ZF Transmission and my E46 M3 uses a Getrag.. the Getrag has held up to 1000rwhp without breaking a sweat.. only time will tell how the ZF holds 600rwhp.. but I'm willing to bet it will do just fine.
Please excuse my lack of experience and knowledge, but what additional components must be added or modified (aside from a proper tune) in order to run stuff like E85?
Also, do you maybe have a ballpark price range for a setup like this? How much did your buddy dish out for a one-off build @ Lutz Performance?
      01-02-2012, 11:09 AM   #27
txz4
txz4's Avatar
59
Drives: 2006 M coupe
I believe you would need new lines and filters if im not mistaken...
      01-02-2012, 09:03 PM   #28
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
sell a kidney
      01-02-2012, 09:09 PM   #29
ZooyorQ
Drives: BMW M3
For an E85 conversion you need to flow 40% (roughly) more fuel, and its recommended (but not required) that you have teflon coated lines.. most 2003ish+fuel systems have something other than rubber for the fuel lines/etc so you'd probably be fine with just an uprated intank fuel pump. You'll also need bigger injectors to flow that additional fuel and a flex fuel sensor as well as a ECU that supports flex fuel. If you wanted flex fuel capabilities that is. If you're fine with just straight e85 (meaning you can't mix the two fuels) you'd just need a tune, injectors and an uprated pump.
You'd see gains on a s/c setup with E85 but not as dramatic as a turbo being your s/c is belt driven and our turbos are exhaust driven. E85 is 40% more fuel, which means more exhaust volume, which means a faster spool.. its also capable on our S54's to make 900rwhp+ on just E85. So if you had a meth setup running E85 would be similar results as your meth setup, but 100% of the time, and with less safety/reliability issues.
      01-02-2012, 09:12 PM   #30
ZooyorQ
Drives: BMW M3
Originally Posted by Z4-Villalona View Post
what with the Wii controller thingy?
Thats a sound decibel meter. I was just showing how loud my car is.. my car has no mufflers or cats and is 4" in diameter from the turbo back.. I do have one large resonator though.
      01-02-2012, 09:44 PM   #31
Z4-VILLA
Afghanistan
111
dude
      01-02-2012, 10:35 PM   #32
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
any chance of Lutz making this more than just a one-off and making it a production kit?
///M - Some Mods 'N Stuff
      01-02-2012, 10:46 PM   #33
ZooyorQ
Drives: BMW M3
Theres always the possibility. I'd call Andrew at Lutz.
      01-03-2012, 02:16 AM   #34
mfanatic325
///M-fanatic
Taiwan
193
I wonder how much a setup like this would push out with just plain old 91 octane?
      01-03-2012, 03:14 AM   #35
ZooyorQ
Drives: BMW M3
I'm guessing around 400rwhp.
      01-03-2012, 11:43 AM   #36
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
On 91 octane with no modifiers for fuel.....most turbo systems add 50% HP if efficient.
So...330hp divided x2 = 165hp added to 330hp = 495hp.
Thats a low boost estimate at best.
Larger intercooler system + more boost equals more HP and so on...........
      01-03-2012, 12:03 PM   #37
ZooyorQ
Drives: BMW M3
I feel silly even saying this but some people aren't aware of what the difference between hp and rwhp is..
hp is rated at the crank
rwhp is rated at the rear wheels (aka on a wheel driven dyno)
Most say that a manual car loses about 10%-15% of its hp through the driveline. So a car like a Z4M which makes roughly 330hp at the crank or so would make around 290rwhp.. Most s/c kit companies (ess/etc) rate their kits at the crank. So I believe the VT-500 is rated for 500 at the crank, and likely makes about 425-450rwhp.
Our goal would be (on E85, not pump) to make about 650rwhp with this setup, so roughly 750hp+ to the crank.
The S54 on stock internals is good to high 700rwhp.. not a good idea.. and likely not to last to long, but its been done. 600-650rwhp on the stock internals has been proven to be very reliable, hence that being our goal.
      01-03-2012, 01:21 PM   #38
claritycheck
Rolling Republic
claritycheck's Avatar
Drives: M Coupe
Very informative stuff here. Subscribed for epic pony powers.
      01-03-2012, 02:36 PM   #39
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
600rwhp sounds like a very fun goal!
I'd suggest custom (longer) gears though
      01-03-2012, 04:19 PM   #40
ZooyorQ
Drives: BMW M3
My M3 (e46) Getrag tranny and the Z4M ZF tranny aren't geared all that different and I think the final ratios are pretty close as well. The gearing up top is perfect but the gearing down in 1st/2nd is way to aggressive..
Changing the final drive would probably net you better results in 1st and 2nd but you'd be sacraficing 3rd-6th.. the ultimate thing would be to find out a way to gear 1st and 2nd to be a bit longer.. especially 1st.. M cars have always had a notoriously low first gear.. which creates the impression that the car is quickier then it really is.. soon as you add F/I that 1st gear is absolutely worthless.
      01-03-2012, 04:34 PM   #41
ZStig
279
yeah, I was specifically referring to the first 2 gears
      01-03-2012, 11:16 PM   #42
Twisted Six
Drives: Z4si-coupe
Red above ^
One thing for sure.....you'll want to find the gearing that allows to match the sweet spot where your choice of turbo breathes the hardest and lives there the longest for the most torque and drive-ability.....but I'd bet your already schooled on those points.
      01-03-2012, 11:43 PM   #43
ZooyorQ
Drives: BMW M3
Originally Posted by Dark Schnitzer View Post
Red above ^
In a perfect world, or with a power glide tranny that could be acomplished... but with our ZF/Getrag trannys the only thing we can really do is adjust our final drive.. we could likely take a 2.9x final drive from something like an E46 (non-M) and maybe get 5-7mph more out of 1st.. but still with 650rwhp first, with any ratio.. will be pretty worthless.
      01-04-2012, 12:31 AM   #44
FerRrari
FerRrari's Avatar
19
Drives: Catrinel Menghia
You can always modulate your throttle inputs to alleviate traction issues, smoothness is key to driving fast
'12 Nero/Rosso 500 Abarth
'07 IR/SBL ///M Roadster (GONE), '08 Tornado Red Triumph Daytona (GONE), '09 BRG/Cloth 6MT MINI Cooper S (Spontaneously Combusted), '06 IR/IR ///M3 Convertible 6MT (GONE), '04 JB/CR Z4 2.5i SMG (GONE)
