      10-25-2013, 01:15 PM   #1
abashoe
Drives: 2008 335xi
17" winter wheels for MCoupe
Hi All
So it's going to be my first winter with my Z4 MCoupe and im looking to buy a winter set. Is anyone here knowledgeable about 17" fitment on a MCoupe/Roadster?
I found a used set of 17x8.5 et 38 square. Any idea if that will fit?
Thanks,
-al
      10-31-2013, 11:45 AM   #2
Expert@ApexWheels
Expert@ApexWheels's Avatar
3522
Drives: M3
The 17x8.5" ET38 square set will definitely work for a winter setup, but most would use a large spacer in the rear (~12mm or more) to push the wheels out so it is not so tucked in. You can use 225 or 235 width winter tires with those wheels.
