      01-15-2013, 04:06 PM   #1
GP20
Drives: Z4M, F80 M3, 991.2 GTS
Headlight not working intermittently. Need new bulb?
My passenger side headlight has been acting up.
When the car's cold (or somewhat cold), I start the car and turn on the headlights, no issue. But if I turn off the car, and then immediately start the car again and turn on the headlights, the passenger side headlight would not go on intermittently, and there's the bulb warning light in the instrument cluster. If I wait another 5~10 minutes or so, the issue would go away.
Has anyone else experienced the same? Is it something a new bulb will fix? Or is it possibly the wirings or connectors or a software issue?
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      01-15-2013, 04:11 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
most likely the bulb but could be ballast
To check ballast, switch the R/L ballasts & see if the problem changes sides
      01-15-2013, 04:20 PM   #3
GP20
Good idea! Thanks for the quick reply.
The ballast is the number 3 item in the diagram?
http://realoem.com/bmw/showparts.do?...66&hg=63&fg=05
2016 BMW M3
2008 BMW Z4M coupe
      01-15-2013, 06:09 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
      01-16-2013, 08:18 AM   #5
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
Had the same experience when the car was still under warranty. Dealer fixed it, did not elaborate, but it has been 35k miles since and no further problems.
      01-17-2013, 10:39 AM   #6
tommiegun57
tommiegun57's Avatar
Drives: Stratus Gray z4 i 07
Similar problem. Blub replacement fixed. Try switching bulbs( L-R).
