12-30-2012, 03:32 PM | #1 |
Rep 1,907
Damaged weather strip
I'm not even sure what to search for to find out if there are any diy on how to replace this peice of weather strip. Looks like it might be a pita to replace.
12-30-2012, 03:57 PM | #2 | |
Car Geek
3615
Rep 3,585
12-30-2012, 06:10 PM | #3 |
Retired Paratrooper
Rep 146
It's easy to replace. 5 - 10 minute job.
Carefully pull up the plastic interior piece (part A on pic) that overlaps it and simply pull off the weatherstripping. Start at the middle and work your way to the ends (B and C on the pic). It's just tucked under the other pieces of weatherstrip at the top of the pillars. (labeled B&C on pic) Tuck one end and work your way to the other snapping it firmly in place and tuck the other end in before snapping the last few inches then put the plastic interior trim back on. The hardest part is tucking the last end and if you don't tuck the first end you do far enough you need to pull it back off and start over.
Retired US Army 82nd Airborne Division.
- There's no such thing as a perfectly good aircraft. I have the option to get out while you have the pleasure of riding it in. |
12-30-2012, 08:17 PM | #5 |
Rep 2,138
Drives: Me
Yes, it is very easy. Does this picture help at all:
12-31-2012, 05:41 AM | #6 | |
Rep 439
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS |
12-31-2012, 09:08 AM | #7 |
Rep 1,907
Thanks guys I will definitely be giving this a shot as soon as I get the parts in. Seems simple enough now that I've seen how its installed. Slowly but surely I am restoring her back to brand new condition.
The next thing I have to replace is the rubber trim around the windshield since mine is cracking and falling apart. Already did the windshield cover as that was all worn and cracking also. Thanks again! |
12-31-2012, 09:56 AM | #8 |
Rep 1,543
Sweet! Good info in case any of the door seal by the window starts cracking/crumbing again. Had to get the passenger side seal replaced just before the warranty was up. I'm figuring the driver's side will go at some point.
- Jeff
bosstones' flickr |
01-03-2013, 12:58 PM | #9 |
Rep 238
My driver's side is already gone and has been since shortly after I bought the car. The first thing I noticed is about the weather stripping is that it is virtually identical to the stuff that put in MGB's. I've got an MGB and have had to replace them several times. Not terribly expensive.
By the way, the MGB parts people have an "upmarket" version of the stuff that has a black velvety cloth cover where the rubber part is that looks much nicer than the rubber. One day I will investigate to see if it would be a replacement for ours. |
03-21-2013, 07:03 PM | #10 |
Rep 615
Drives: 08 SG/IR Z4MR | 07 AW/Blk Z4MC
Funny,
Couple days ago just noticed my weather stripping that covers the windshield to the roof is cracking.. Car is a 07, garaged for 4 years. Park outside SOCAL sun for my work and thats it. Part #1 http://realoem.com/bmw/showparts.do?...12&hg=51&fg=20 Anyone have a DIY? Or could it be just peel and stick?
08 Z4MR | Space gray on Imola red, carbon trim
BC racing coilovers | Titan TS7 07 Z4MC | Alpine white on black, aluminum trim KWV3 | CCW LM20 | Eventuri | Rogue Engineering short shifter, mounts and exhaust | BMW Motorsports shift knob | mudflaps | stubby antennas |
03-21-2013, 07:18 PM | #11 |
Rep 1,990
That is a very common issue as well as the plastic at the base of the windshield. Seems to be very cheap plastic. The strip you asked about is easy to DIY from what I have read. I know there are write ups as well. You have to take the old one out, use a non marring tool to remove glue residue from the channel and replace with a new one by pressing into place.
03-22-2013, 09:53 AM | #12 |
Rep 384
The strip around the windshield gets replaced with new glass. If your insurance has a glass replacement option like mine does, get new glass and kill 2 birds with one stone.
The Internet said it. I believe it. That settles it!
Kazansky12.50 |
03-22-2013, 11:08 AM | #13 |
Rep 615
Did some research for people that will inevitably run into this problem:
BMW windshield glass is held to the body via urethane, the stripping or the "windshield cover" as bmw states it is simply there to block excess weather out of the grooves. Windshield does NOT have to be removed for my trim job. I'm sure dealers will tell you otherwise. There is also no adhesive, just a snug fit. What causes the accelerated cracking could be wax exposure to the rubber pieces which causes it to be more sensitive to weather changes. 303 aerospace protectant will help protect / elongate its life. Part #1 51317210011 costs 30$ from my online searches. Will reply when i do attempt this diy. Seems easy enough. http://blog.bavauto.com/6971/bmw-win...n-windshields/
03-23-2013, 09:19 AM | #14 |
Rep 1,907
I did the windshield trim a couple of weeks ago. Honestly I actually liked the way it looked without it better but didn't want to risk causing any weather damage to the windshield seal or something. My old one just pretty much pealed off and the new one was squeezed in. My friend did his but failed to remove the old one cleanly so he has pieces of it still in the grooves and now cant get the new on in. So make sure to take your time removing the old one.
