07-25-2013, 04:44 PM | #67 | |
Rep 5,327
are you struggling for traction in 2nd gear???
07-25-2013, 05:03 PM | #68 |
Rep 2,782
6 and 8 are very different. Boost varies based on temperature, but not by that much.
07-25-2013, 07:29 PM | #69 | ||
enthusiast
48
Rep 1,695
I will calibrate gauge again after it sits all night. |
07-26-2013, 01:33 AM | #70 | |
Rep 5,327
althought not your temps.... its a good 34 deg C over here and has been for about a month now... still can light up second at will...... wonder if your getting belt slip???
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 07-26-2013 at 01:16 PM.. |
07-26-2013, 06:52 PM | #71 |
enthusiast
48
Rep 1,695
What size super charger pulley is on the 525? I want to check to make sure I have the correct size. There were a few additional parts, as well as some missing. I want to make sure someone didn't put the incorrect size in the box.
07-27-2013, 02:27 AM | #72 | |
Rep 5,327
525 should make 8lbs yes??
07-27-2013, 09:53 AM | #73 |
instagram 997turbotom
279
Rep 7,377
07-27-2013, 01:54 PM | #74 |
Rep 5,327
500 uses 7lbs or is supposed to....
525 is 8lbs 550 m3 kits use 9lbs... so it looks like each psi of boost gives 25hp basically... note boost level at the bottom.... http://www.esstuning.com/products/Z4...er-System.html i should have searched earlier.... my bad...
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 07-27-2013 at 02:53 PM.. |
07-27-2013, 05:19 PM | #76 | |
Rep 5,327
have you asked ess what size the pulley should be???
07-27-2013, 10:08 PM | #77 |
enthusiast
48
Rep 1,695
No, trying to trouble shoot everything that they will ask when I contact them. So, I can let them know I tested it.
07-28-2013, 07:31 AM | #78 |
Rep 5,327
Can't quite get a proper reading on the pulley size due to my large digital caliper... Appears to be around 3.2" .... Will try again when it's not so hot in the engine bay....
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 07-28-2013 at 07:45 AM.. |
07-28-2013, 07:45 AM | #79 |
Rep 5,327
from a quick few pulls up my street.... alot cooler today outside.... back to normal uk weather... peak recall shows...
07-28-2013, 12:56 PM | #80 |
enthusiast
48
Rep 1,695
I did another pull in 3rd after making sure that everything was very tight. It was 75 degrees if that makes a difference which is pretty cool. I got 5.8 on the digital P3 gauge. The highest have ever seen is 6.5.
It may be hard to read the actual inside diameter with the belt on. We could just read the outside, just to make sure I have the correct size. I also double checked that 2 pulleys were changed out. |
07-28-2013, 01:05 PM | #81 | |
Rep 5,327
is the boost gauge accurate?? consider ghetto rigging a mecanical unit and just run the lines through the hood/windshield way... i then held the unit in my hand and did a long 3rd gear pull as it climbs slower....
07-28-2013, 01:15 PM | #82 |
enthusiast
48
Rep 1,695
Belt tension is excellent. I have also thought about moving the T just below the bypass valve. I kinda suspect air intake because it seems to build up and then goes flat. Upon install, it seemed that the air filter was on the small side.
08-02-2013, 11:02 PM | #83 |
enthusiast
48
Rep 1,695
To update the thread:
Well, I emailed AJ at ESS. He said that I had a boost leak or air intake restrictions based on my issue. I opened up the area around the air intake ( I made a wall that covered 1 inch of the back half of the filter to create high pressure area). I pulled 7.3 psi in 3rd and did a pull on a nearly deserted freeway in 4th and got 9.3psi on peak recall. The car nearly scared the hell out of me. I will fabricate something to increase the air to the filter. |
08-03-2013, 05:18 AM | #84 |
Rep 2,176
Ahh , interesting , I still don't see how your filter isn't exposed to enough air , I'd be more concerned about the cheap connector kinking off.
George |
08-03-2013, 11:40 AM | #86 |
Rep 441
I was excited when this kit came out....now it seems there isn't a single car with it that is running properly....my buddy with his e39 m5 had a bunch of parts missing out of his ess kit when he bought it too...seems to me to be a business issue
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
08-03-2013, 02:21 PM | #87 |
Rep 2,782
Parts missing or incorrect parts are a standard issue with all manufacturers it seems. I'm not saying they shouldn't be held accountable. However, it's common.
The bigger issue is the end product requiring modification. The "BMWness" of a car gets lost when things are missed during R&D process, and you end up with quirks, annoyances, and limitations that weren't there previously. The goal should be to get the car to drive exactly as it drove before the install, just with more power. Unfortunately, many use a "power increase to cost" ratio as the sole factor in determining a kit's value. There are many things that ratio doesn't tell you. If a manufacturer spends extra time tweaking a kit, that's time he hasn't spent selling kits. And, a better tuning staff costs more money. If a kit is released too early, the customer ends up doing the R&D, with "excellent" customer support from the manufacturer. This isn't a knock on ESS, as they tend to spend some time on a kit before releasing it. Others do more, and others do less. ESS seems to have been good at helping customers sort through issues in the past. Hopefully everything will be right shortly.
08-03-2013, 02:58 PM | #88 | |
279
Rep 7,377
