      03-20-2013, 08:50 AM   #1
ludoZ4
Drives: Z4 3.0si
3.0si lack of power
Hi buddies, last saturday, i had my car on the dyno, and i pulled out only 215 horsepower ( at the wheel). So, i wondering what is going wrong... i was with some friends, and they all pulled out what they should, or what their chiptuner promise them.
what can i do to get my horses back ?
      03-20-2013, 09:06 AM   #2
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
255hp is BMW's spec at the crank.
assume 16% loss in driveline...
255 (.84) = 214.2
your 215 is accurate.
      03-20-2013, 09:09 AM   #3
3002 tii
3002 tii's Avatar
2282
^^ whs, are you driving auto or manual?
I would expect max 225 at wheels with a 6mt, exhaust and tune.
Follow for latest mods
      03-20-2013, 09:54 AM   #4
ludoZ4
Drives: Z4 3.0si
it's an automatic.
but i should have 270NM at the wheels...and not 320, something is weird
      03-20-2013, 11:23 AM   #5
v3.2mc
Not a New Member
v3.2mc's Avatar
wiki page shows...
3.0si | 2006–2008 | N52B30 | 2,996 cc (2.996 L; 182.8 cu in) I6
POWER = 265 PS (195 kW; 261 hp)@6600
TORQUE = 315 N·m (232 lb·ft)@2750
i'm not seeing a problem here...
      03-20-2013, 11:44 AM   #6
ludoZ4
Drives: Z4 3.0si
Yes, i agree,
But i should expect 270 at the wheel, and not 320
      03-20-2013, 12:34 PM   #7
v3.2mc
Not a New Member
v3.2mc's Avatar
ok... so your concern is that the graph is reporting for rwhp, while simultaniously reporting for crank tq.
you'll have to ask the guy who was running the test. it's possible that the outputs for the graph were incorrectly selected.
      03-21-2013, 10:28 AM   #8
vachss
Drives: Z4 Coupe
A number of years ago I got an ECU tune for my 3.0si. Attached is the before/after dyno which seems very much in line with the OP's. Unless he knows the dyno on which his car was tested used some unusual correction factor I wouldn't worry about those results.
      03-21-2013, 10:54 AM   #9
ludoZ4
Drives: Z4 3.0si
thanks for your comment buddy. But the torque looks strange
      03-21-2013, 11:01 AM   #10
ludoZ4
Drives: Z4 3.0si
      03-21-2013, 12:50 PM   #11
vachss
Drives: Z4 Coupe
Do you mean my torque or yours? Both of them show a peak at relatively low rpm followed by a very slow decrease as is characteristic of the N52. If you mean because of the dips 3250 and 4500 rpm that's exactly what you expect from a 3.0si with its 3-stage intake (econo-mode from idle to 3250, mid-range from 3250-4500 and wide open above 4500). I'm somewhat surprised your dyno doesn't show this as much as I've seen it in dynos from other si's, but I'd still think that's within the range of variation you'd expect to see.
Also the 255 hp spec for the 3.0si is crank power not rwhp. About 215 rwhp is to be expected.
      03-21-2013, 03:25 PM   #12
ludoZ4
Drives: Z4 3.0si
Vachss, i'm talking about my torque, it doesn't have to be so high
      03-28-2013, 04:29 PM   #13
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Something's weird with that graph... shouldn't HP/TQ crossover at 5252RPM?
      03-28-2013, 05:05 PM   #14
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
I drove an SI once and those things dont fuck around lol I used the paddles and I was like F yeah! Si ftw
      03-28-2013, 06:07 PM   #15
Beedub
Lovely engine , I had 130i and LOved it.... Fabulous motor.
      03-28-2013, 07:23 PM   #16
aerobod
Car Geek
aerobod's Avatar
3615
Drives: Caterham R500, M2-G87, Macan S
The torque on that graph is in Newton metres (power is in horsepower), so the crossover point is 7121RPM. If a fully metric measurement is taken with power in kW and torque in Nm, then crossover point is 9549RPM.
      03-28-2013, 08:56 PM   #17
intoflatlines
Ah, thanks for the info!
