      02-04-2013, 03:22 PM   #155
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Originally Posted by dre99gsx View Post
I understand VF designed this kit for the average Joe
lol
Still, another 3 or 4 more psi could net you some more torque through the usable range
We know, but you have to build the motor to do this reliably. This is still my daily driver.
Originally Posted by Geauxkart View Post
Before you tweak the setup any more, can you please give us a dyno / AFR charts after the tune update?
You are the guinea pig, we need data!!
And the flames are awesome.
Thanks, I will do runs on the dyno with the meth turned on and off.
      02-04-2013, 05:43 PM   #156
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
wondering how much power you gained with those resonators
      02-04-2013, 06:01 PM   #157
Rated M Roadster
160
I'm curious as well. I want to get this meth kit ordered and installed quick so I can do both comparisons while I'm there.
      02-04-2013, 06:45 PM   #158
dre99gsx
Drives: 1994 Toyota Supra
Entire kit weighs 113lbs (Vac Motorsports). This sound about right?
      02-05-2013, 01:25 AM   #159
Rated M Roadster
160
I'd say about 80-85 lbs taking into account the parts that were removed.
      02-07-2013, 02:07 PM   #160
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
trying to be sure i know what the 570 bas over the 480 kit....bigger injectors, mafless tune, smaller pulley, spring tensioner upgrade, and requires headers.....is that it?
      02-07-2013, 03:18 PM   #161
Rated M Roadster
160
I'm using the oem hydraulic tensioner, but yes that's basically it. Maybe a larger air filter as well, but I'm not sure. I have 1600+ miles on the kit now with no complaints. I would definitely recommend it.
      02-07-2013, 09:19 PM   #162
DRedman45
DRedman45's Avatar
35
thanks...I literally just signed the papers on my m coupe today, so I am still a ways off from pulling the trigger on it haha...just want to be informed
      02-08-2013, 07:04 AM   #163
dre99gsx
RatedM: Can you verify the diameter of your supercharger pulley? And I assume it is 6-rib...
      03-05-2013, 12:11 AM   #164
Rated M Roadster
160
No real updates as I've been pretty busy, but I did order some parts to get it ready for track season.
Ordered some PFC 08 pads and Motul 600 (last time at the track I boiled my brakes every session). I also order a Setrab oil cooler with all Setrab fittings, black SS lines, and the VAC adapter. I haven't had any cooling issues with the stock oil cooler, but I don't like how the oil cooler and intercooler are arranged. I'm going to put the new oil cooler behind the kidney grills like the ESS kits and move the intercooler forward to get all the air from the lower grill.
I'll also be getting the P3 vent gauge so I can monitor IAT (without having my laptop in the passenger seat) before dropping another $1100 on an aquamist meth kit.
      04-04-2013, 11:55 AM   #165
Rated M Roadster
160
Forgot to post an update from the track day. Oil temps stayed right at 230 degrees with the new Setrab. The only problem I had was a little oil coming out of the vent plug of the SC, though it was still at the max level when I checked. Also, the new PFC pads still started to fade after 20 minutes; going to have to look at some form of ducting.
The kit has 3k miles on it now and is running strong.
I also took out and bypassed the water reservoir for the air-to-water system; saving about 25lbs off the front end. Now I'm just waiting on the P3 gauge to ship.
      04-04-2013, 12:10 PM   #166
BMW Maniac
Drives: Former Z4M coupe owner
Arent you worried about heak soak by removing the aftercooler? Seems the power lost and weight savings would be worse than sustaining power and an additional 25 pounds, no?
      04-04-2013, 12:44 PM   #167
Rated M Roadster
160
I should have clarified. The system has an additional ~2 gallons of coolant in a reservoir under the car (E46 M3 setup). I just removed the reservoir and ran the lines straight to the intercooler (E9X M3 setup). The system still works the same way (just with half the fluid in the system) and should provide the same cooling.
      04-05-2013, 05:25 PM   #168
Rated M Roadster
160
Bimmer Magazine article: http://www.bimmer-mag.com/issues/115...black-and-bold
      04-05-2013, 07:07 PM   #169
VF-Engineering
VF-Engineering's Avatar
1009
Drives: F82 M4
Congrats Andrew!
Great read!
      04-05-2013, 08:26 PM   #170
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
Great read and beautiful car
      04-06-2013, 03:56 PM   #171
pandusr
pandusr's Avatar
Italy
Drives: BMW Z4M Roadster ESS CFR 525
Catless is lost too.
Red line: cat oem, Oem Xpipe, terminals Supersprint Race
Green line: catless, Xpipe Supersprint, terminals Supersprint Race
Black line: how the green line with 50% meth 50% water (start 2psi, full pression 6 psi)
The gain (6000-8000) not compensates for the loss (4000-6000).
      04-06-2013, 05:25 PM   #172
Rated M Roadster
160
Originally Posted by VF-Engineering View Post
Congrats Andrew!
Great read!
Thanks guys!
Not sure why this is here...
      04-06-2013, 06:33 PM   #173
GuidoK
#buildnotbought
GuidoK's Avatar
10844
Drives: Z4 3.0i ESS TS2+
That's a nice story about your z4m
      04-06-2013, 09:02 PM   #174
pandusr
pandusr's Avatar
Italy
For this reason.
Catless effectiveness depends on DME (crossing valves time). I hope that your DME is in tune.
mine is not.
I don't want to belittle your car.
If I'm wrong, I request that be deleted.
Write a thread.
      04-06-2013, 09:39 PM   #175
Rated M Roadster
160
For this reason.
mine is not.
Oh, ok; didn't know you were comparing catless. Interesting results. I wonder what mine is putting out now.
      04-06-2013, 09:47 PM   #176
pandusr
pandusr's Avatar
Italy
Ok !!!
Z4M E85/2006 || ESS CFR525 || AEM Water / Methanol Injection Kits || Supersprint Exhaust (catless,XPipe,rear exhaust race) || 4.10 || front brake AP Racing 6 piston kit (cp5575-1010) || K-Sport suspension with camber plates || Sparco Pro2000 seat || 6 pti Sparco belts -|| Hankook S1 EVO 1 (front 245/35 19 - rear 275/35 19) || OZ Racing Ultraleggera HLT 19"
