      05-23-2012, 03:50 PM   #265
beta
Drives: 2006 M Roadster
Originally Posted by v3.2mc View Post
this is excellent information! what a great starting point... i've got some ideas on how to make this data user friendly for the odd onlooker. point taken about the round numbers given; i'll do proper measurements this weekend.
safe journey!
Have you had a chance to measure yet? I think we need a stock setup to measure properly I think.
      05-23-2012, 10:03 PM   #266
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
yes! crap! sorry!
now, keep in mind all-a-yoos-guys that these are not EXACT measurements. i do not have the proper tools for that. that being said there is some variability and therefore leeway i'm awarding myself. in general, i believe these measurements are reasonably accurate to +/- 2mm. READ... that's a possible 4mm margin of error.
ok... stock suspension, stock alignment, stock wheels, stock tires...
Ty = 522mm
Tz = 769mm
By = 696mm
Bz = 186mm
Cy = 743mm
courtesy of aerobod, S=(Cy-By)-{((By-Ty)*Bz)/(Tz-Bz)}
S(stock) = (743-696)-{((696-522)*186)/(769-186)} = -9mm [sig figs]
-9mm obviously translates to a negative scrub radius, which is quite well suited to mcstrut suspension setups. this number is no surprise then, especially on a BMW.
now... on to my current setup... stock suspension, stock alignment, 19.0" x 8.5" et35, 245/35r19
Ty = 522mm
Tz = 766mm
By = 696mm
Bz = 183mm
Cy = 750mm
S(v3.2mc) = (750-696)-{((696-522)*183)/(766-183)} = -1mm [sig figs]
-1mm is way better than i thought it would be! i half expected to find some seriously wonky and positive SR and totally start second guessing myself on whether or not i should consider getting some track wheels, or just run what i brung. turns out the only real PITA is going to be the weight of the wheels.
it is also worth noting that adding the shim kit makes sense for me at this point. it may cut down on tire life, but it will also fool the car into thinking i have a close-to-stock SR, and add neg camber at the same time.
and please... somebody... by all means check my math. i'm human and make mistakes.
also, if somebody wants me to start a new thread with this info, just let me know.
      05-26-2012, 09:32 PM   #267
IWantAnE92
Drives: 2008 E90 M3 6MT
Will these work on stock height without any rubbing?
Wheel size: 19x8.5 and 19x9.5
Offset: ET20 front and 22 rear
Tire Size: 245/35 and 265/35
Thanks in advance!
      05-29-2012, 11:06 AM   #268
jrainlay
jrainlay's Avatar
Drives: 07 Z4 M Coupe
I'm about to order the following setup for my 07 Z4 M Coupe and would appreciate any thoughts you may have on possible fitment/rubbing issues:
Front: 19x8.5 et 35 with Michelin Pilot SS 235/35
Rear; 19x10 et 26 with Michelin Pilot SS 275/30
Currently the car has stock suspension, but I would like to add some lowering in the future.
Thanks in advance for your replies and I apologize if this spec has already been discussed.
      05-29-2012, 02:41 PM   #269
v3.2mc
Not a New Member
v3.2mc's Avatar
Thanks in advance!
nope.
the front offsets are too aggressive. you'll need camber plates to get them to turn free, and maybe shorter sidewalls.
the rears are fine.
      05-29-2012, 02:43 PM   #270
v3.2mc
Not a New Member
v3.2mc's Avatar
that's a great setup (very similar to my own specs), but you may need an alignment to make the rear feel less squirelly.
      05-29-2012, 03:06 PM   #271
jrainlay
jrainlay's Avatar
Thanks for the reply v3.2mc. Are you lowered? Any rubbing?
      05-29-2012, 03:38 PM   #272
v3.2mc
Not a New Member
v3.2mc's Avatar
frt = 245/35r19 on 8.5" et35
rear = 275/30r19 on 9.5" et20
stock suspension.
absolutely zero rubbing.
      06-04-2012, 06:15 AM   #273
CloudyLP640
Drives: RS
Front wheels are 18x9 + 42 with a 245/40/18 tire.
Car has to be slammed on KW V3 coilovers.
Whats is the smallest spacers that will allow me to clear the coilover perch without poking too much in front.
Basically, I wanna run low, So I need the perfect compromise between clearing the perch and the fender...
No camber plates involved.
      07-03-2012, 11:47 AM   #274
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
I know some of this depends on the specific tire, but say for questionn Hankook V12 in 275/30/19 is there going to be any problem rubbing on the rears with a 19x9.5 et 20 wheel? All on stock suspension for now
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      07-03-2012, 11:50 AM   #275
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
also depends on how much - camber
      07-03-2012, 11:59 AM   #276
RADRACR
RADRACR's Avatar
I had this exact setup (Hankooks, sizes) on stock height for a long time with no issues. Now dropped .8" with -1.5mm camber and still no issues.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      07-13-2012, 12:56 PM   #277
HamiltonSeth
Drives: GTC4/M2/930/LP640Perf/GT4CS/X7
A friend of mine has some VB3s he is willing to sell me for a fair price. 18" et 22 squared. Will this fit my Z4M? I am running eibach springs. I will have the opportunity to purchase whatever tire would be needed. Thanks for any advice.
      07-22-2012, 08:57 AM   #278
nwflbimmer
Drives: 2007 MCoupe (Interlagos Blue)
I love the look of wheels with lots of lip on them. I have just bought my MZ4 coupe not long ago but I want to exchange the wheels. I want to go with some serious wide wheels. I would love to put some 8.5-9.5" on the front and maybe some 9.5-10.5" on the rear. I would like to keep the original suspension and 18" wheels. (More rubber the nicer the ride!) Please give me a guideline as to what offset I need to keep the rubber under the car? I really don't like the tires sticking out from the car. Any suggestions? I want no rub.
Thanks
Paul
      07-22-2012, 12:38 PM   #279
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Thanks
Paul
8.5 x 18 ET35 and 9.5 x 18 ET22 is a perfect offset IMO for coming right to the edge without sticking out AND having no rubbing issues on either side of the wheel. I just put that size on my M Roadster and I'm very happy with the look and ride. Finding an old school wheel with a deep lip in those sizes might pose a little challenge, but I would guess something is out there
John
      07-22-2012, 03:04 PM   #280
nwflbimmer
Can I see a picture of your car with the new wheels?
      07-22-2012, 03:35 PM   #281
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
8.5 x 18 ET32 and 9.5 x 18 ET25 on mine
2006 Z4MC - #LL93158
      07-22-2012, 04:05 PM   #282
antennahead
Not sure if you were asking me or another poster, but here they are:
      07-22-2012, 05:15 PM   #283
nwflbimmer
Your offsets wont work with what I want. I looking for 2-3" lip on my rears.
      07-24-2012, 10:08 AM   #284
aerobod
Car Geek
aerobod's Avatar
3621
Drives: Caterham R500, M2-G87, Macan S
The OZ Racing Tuner System wheel is about the only wheel that will fit our cars and give a lip of any depth: http://www.tirerack.com/wheels/resul...rSpecial=false
      07-24-2012, 11:41 AM   #285
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
i dont think so. many rims with lip fit our cars. especially custom fit ones like dpe, hre, adv1, forged1.....not to mention work and bbs.
instagram: @ dubsesd
      07-24-2012, 11:58 AM   #286
RADRACR
RADRACR's Avatar
The craziest lip I've seen yet is Thatcher's old ride with Work Meisters. If that doesn't work for you, you're too crazy for me
