      10-02-2011, 02:20 AM   #23
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
im pretty sure you will need to have your fenders rolled and pulled.
im about to put some 285/35/18 r-s3's on my 18x10 et20 rears so i'll let you know how it goes.
btw shimmy you still have the HRE's fs?
      10-02-2011, 04:33 AM   #24
shimmy09
Drives: 2008 BMW Z4M Coupe, 2011 BMW E
Still have it.. I might sell it if I manage to get a deal for some bbs chrs..
      10-02-2011, 11:28 AM   #25
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
luckily, if you ruin your rear fenders with rolling and pulling, they're easy to take off and replace
      10-02-2011, 11:52 AM   #26
The HACK
The HACK's Avatar
1821
Problem is not the fenders. Problem is the trailing arm. Even at 18"x9.5" et 26 on 275/35/18s, on hard corner the tires (R-Comps) deflect enough to touch the trailing arm. Anything wider than that foot-print (typical of Nitto, the 275s probably run about 10mm wider than equivalent street tires) with offset one way or another will rub either on the trailing arm, or fender if no additional camber is added. So for example, a 285/XX/?? tire will likely either rub the trailing arm if the wheel is wider than 10" with et in the 25 or more range, or it will rub the fender if et is in the 20 or less range. And you can forget running anything like an extreme summer or R-Comps, since those tend to run wider than typical street tires. 285 on 10" with 25mm may clear with the rear camber maxed out, but will still likely rub the trailing arm when suspension is loaded at high G for extended time (high speed sweepers).
      10-02-2011, 12:47 PM   #27
l4zy
l4zy's Avatar
2017 BMW M3  [0.00]
1995 BMW M3  [10.00]
hah if sh!t hits the fan you'll have an excuse for fender flares or widebody... lets hope it never comes to that
i havent really considered the trailing arm. took a look just now and it looks like i have about an inch of clearance and no signs of contact. i'll keep an eye out for any rubbing on that spot. ty
      10-02-2011, 07:05 PM   #28
shimmy09
Fender roll required for 19x9 et 20 19x10.5 et 25 with 275/35/19 rear tires?
      10-03-2011, 03:50 AM   #29
l4zy
l4zy's Avatar
2017 BMW M3  [0.00]
1995 BMW M3  [10.00]
just noticed your HRE's are 18x10 et20. what size tires do you have on them? an easy way to test your clearance is just drive half way up a driveway at an angle to put more load on the rear. the 19x10.5 et25 just sticks out 1mm more so if you are running 275 already you will probably be fine. just gotta be sure you can spare 11mm on the inside.
      10-03-2011, 04:51 AM   #30
SmartBastard
Stupid as shit
SmartBastard's Avatar
Austria
25
Drives: '08 M Coupe
Slight OT, but didn't want to start another thread.
Can I fit front 245/40/18 on stock rims with stock suspension (no camber kit)? I know it's no problem with the kit and/or camber plates, but what about stock?
      10-03-2011, 09:32 AM   #31
ZStig
279
I'm gonna try to run 285s RE-11s or AD08s on a 18x9" rear. 40 initial offset, but I'll space it out for a better fit. Probably 15mm...
      10-03-2011, 11:42 AM   #32
The HACK
The HACK's Avatar
1821
285s won't fit on 9" rims, both Yokohama's and Bridgestones will require a MINIMUM of a 9.5" to mount 285s in 18" and 19" diameters.
      10-03-2011, 12:05 PM   #33
ZStig
279
hmm. Someone here ran 285s on stock rims, thats why I was planning it. 275s should hopefully offer enough grip with the tires I want
      10-03-2011, 12:29 PM   #34
The HACK
The HACK's Avatar
1821
Let me rephrase that. It will fit, but it won't work. When manufacturers suggest a specific rim width for a tire, it means they've tested the load placed on the sidewalls and the cords for that specific sidewall size and design and deemed that anything outside of that range of tires will end up placing unfavorable stress on the carcass and generate too much heat, resulting in unpredictable outcome. If you're familiar with the process in which tires are built, the "cords" in the tire's carcass is placed under tremendous stress as they're wound around on the base belt and sidewall, and placing the tire on wheels too small or too large for the intended use will "stretch" those nylon cords beyond their design parameters.
Even for a set of tires used ONLY for track, it's not a favorable solution because that 10mm extra width won't make up the difference in excess and constant load on the sidewall. And once the sidewalls start to get squeezed in, you may actually LOSE available contact patch instead of gain it from a wider tire.
This is a case where just because you can, doesn't mean you SHOULD, IMO.
      10-03-2011, 01:25 PM   #35
ZStig
279
thx for the breakdown!
      10-04-2011, 02:09 PM   #36
ZStig
279
wonder how much work these would need to fit
http://cgi.ebay.com/ebaymotors/BMW-E...item2a0b2f020e
      10-04-2011, 02:15 PM   #37
l4zy
l4zy's Avatar
2017 BMW M3  [0.00]
1995 BMW M3  [10.00]
lol there are these too http://www.ebay.com/sch/i.html?_nkw=...+fender+flares
      10-04-2011, 02:26 PM   #38
ZStig
279
not wide enough
      10-17-2011, 10:27 AM   #39
funkyman
Drives: 2008 BMW Z4M COUPE
You want to fit fat tires?
If you want fat tires and ultra aggressive looks then you have no option but to get a wide body kit.Check out the thread here.
http://www.z4-forum.com/forum/viewto...=9350&start=15
      10-17-2011, 11:08 AM   #40
ZStig
279
link not working for me, probably because I'm at work
I think you're talking about the silver one with BBS LMs, and I THINK thats a custom one-off
      10-17-2011, 01:15 PM   #41
l4zy
l4zy's Avatar
2017 BMW M3  [0.00]
1995 BMW M3  [10.00]
its the old school technik z4...their cars are always so
      10-17-2011, 01:19 PM   #42
ZStig
279
yeah... custom job
      10-21-2011, 03:54 AM   #43
wrose
Drives: 2007 Z4MC
2006 Z4M Roadster  [8.50]
2007 Z4MC  [0.00]
2005 X3  [0.00]
Wheel/tire fitment
I have been using Apex Arc 8 wheels this summer- 18x10rear with 25mm
offset / 18x9 front with 42 mm offset. I have been using Hankook RS-3 tires-
245/40/18 ft and 285/35/18 rear. I have stock suspension and have camber set to -2.5 front and -1.5 rear . the only issue has been the left rear fender liner has rubbed through in 1 spot at top and very slight rub on inside of rt. rear liner. No issues on front . This is after running over 20 track days this summer .
These tires are still on wheels but will need replaced before next season
(storage time here)
RS-3 has been great and will buy again
Hope this helps
      10-21-2011, 10:40 AM   #44
jra
Drives: 2005 z4
that kit was for sale awhile back...the seller disappeared though
