      09-14-2011, 09:58 PM   #1
suprtran
suprtran's Avatar
111
Drives: BMWs
Question Widest rear wheel for M Roadster??
Does anyone know what the widest wheel the E85 M Roadsters can handle at the rear? Or, will this fitment work?
19x10.5 ET25
My car is lowered on H&R coilovers.
Also, if it DOES work size tire would you recommend 265 or 275? I don't want to have run into rubbing issues or fender modifications.
THANKS
      09-15-2011, 06:55 AM   #2
j03chu
Drives: 08 SG/IR Z4MR | 07 AW/Blk Z4MC
19 30 275 is what id go with. Check pics of my car, roughly -2.7 degrees of camber in the rear.
08 Z4MR | Space gray on Imola red, carbon trim
BC racing coilovers | Titan TS7
07 Z4MC | Alpine white on black, aluminum trim
KWV3 | CCW LM20 | Eventuri | Rogue Engineering short shifter, mounts and exhaust | BMW Motorsports shift knob | mudflaps | stubby antennas
      09-15-2011, 10:00 AM   #3
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
you got the max recommended size right, width depends on the tires.. Most can fit 275s or 285s with minor rubbing
      09-15-2011, 07:35 PM   #4
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Yeah you could probably go wider than 10.5" in the back, but you'll only be able to fit 275s, or 285s AT MOST (unless you do some hardcore fender flaring, or something to that extent etc.)
With only a slight drop from stock, I could only fit 275s in the back without rubbing. And that's with the rear fenders rolled I might add.
      09-15-2011, 07:37 PM   #5
suprtran
suprtran's Avatar
111
Drives: BMWs
So...
Having coilovers dropped 1.5" all around, 10.5 wrapped in 275 will guarantee me rubbing?
      09-15-2011, 07:49 PM   #6
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
no, you shouldnt rub with that setup....considering your offsets will be 25
here is my 19x9.5 et23 with 275/30's dropped about 1.5"
      09-16-2011, 12:20 AM   #7
mfanatic325
///M-fanatic
Taiwan
193
Originally Posted by suprtran View Post
So...
It depends on the tires you use, alignment specs, and possibly even coilover settings. But I'm willing to bet you will NOT rub.
Though I do suggest a fender roll regardless.
      09-16-2011, 12:35 AM   #8
suprtran
suprtran's Avatar
111
Drives: BMWs
but the width of my rim would be 1" wider at 10.5"
      09-16-2011, 12:39 AM   #9
mfanatic325
///M-fanatic
Taiwan
193
Yeah, the 10.5" (one inch extra width), at 20's offsets are a different story. You have to trust me on this one.
Especially with coilovers, lowered, and 275s. It's safer if you get your rear fenders rolled (at least slightly). And run some negative camber in the rear. AND get tires that aren't too bulky.
I'm using Nitto NT05's for example. 275/30/19. The only time it ever rubs the fender liner (black plastic inner wheel arch piece), is @ Laguna Seca turn 6. It's a mid-speed left-hander, with a dip right at the apex. So it rubs on the passenger side just ever so slightly.
      09-16-2011, 12:41 AM   #10
suprtran
suprtran's Avatar
111
Drives: BMWs
Thanks
      09-16-2011, 05:46 AM   #11
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6332
but comparing offsets, your setup would only stick out around 10mm more. you would obvioulsy have less inner clearance as well. i would recommend rolling the fender as well, and you should be fine
      09-27-2011, 07:38 AM   #12
shimmy09
Drives: 2008 BMW Z4M Coupe, 2011 BMW E
Dont mean to thread jack but would 19x9 +20 19x11+32 fit??
      09-27-2011, 12:49 PM   #13
mfanatic325
///M-fanatic
Taiwan
193
I think 19x9 +20 fronts have already been shown to work up front, with up to 265-width tire (depending on tire brand and/or model).
However, I'm willing to bet my car on the fact that 11" rear will NOT clear.
My 10.5" +22 rear is technically already sticking out the fender by a tiny bit. And I can't fit anything wider than 275s in the back without rubbing. And that's with rolled fenders and -2.2* camber in the rear, and Nitto NT05 tires sized 275/30/19.
      09-27-2011, 05:55 PM   #14
shimmy09
Even with fender rolling? Damn I really want that wide aggressive stance...
      09-27-2011, 06:06 PM   #15
gcochard
Drives: 2011.5 E90 M3
2011 BMW M3  [0.00]
These cars already have a wide aggressive stance, you don't need to blow it out of proportions with 11 inch rears.
Just sayin'
      09-28-2011, 12:56 AM   #16
l4zy
l4zy's Avatar
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
2017 BMW M3  [0.00]
2015 BMW i3 REX  [0.00]
1995 BMW M3  [10.00]
2013 BMW X3 xDrive35i  [7.00]
when you say wide aggressive stance do you mean thick rubber just barely clearing the fenders? or do you mean stretch and poke? because if you stretch your tires and add some camber and maybe do some fender work you should be able to pull it off. just depends what you are lookin to do and how much work you can put up with =D
my current setup is 18x9 et12 with 235/35/18 front and 18x10 et15 with 275/35/18 rear. my rear fender is shaved and im running about -3.5 camber front with maxed out caster and -2 rear.
will be swapping to 255/35/18 front and 285/35/18 rear soon. spacers will have to come off
oh and with that 11" rear you will actually have 30mm less inside clearance and 4mm MORE outside clearance than my current setup. hope all that info helps
      09-28-2011, 12:49 PM   #17
ZStig
279
is there room for 30mm less clearance on the inside?
      09-28-2011, 01:29 PM   #18
l4zy
l4zy's Avatar
2017 BMW M3  [0.00]
1995 BMW M3  [10.00]
not sure, i had a 20x10.5 et26 in the rear at one point and it was fine. but thats 12mm more inside clearance and same outside clearance as a 19x11 et32. probably gonna have to do a stretch and poke with the 11" wheels
      09-28-2011, 02:19 PM   #19
ZStig
279
someone needs to make reasonably priced rear fender flares for this car. I want 315s in the rear
      09-28-2011, 02:56 PM   #20
l4zy
l4zy's Avatar
2017 BMW M3  [0.00]
1995 BMW M3  [10.00]
haha +1 on that one. i bet you do with that SC
      09-28-2011, 04:19 PM   #21
ZStig
279
1st gear laughs at me
      10-02-2011, 02:12 AM   #22
shimmy09
19x10.5 offset 25 with 285/35/19 re11s would this fit without rubbing?
