      05-27-2010, 11:53 AM   #45
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by MakoBimmer1 View Post
I am considering going with 235/40-18 on the front 18x8.5 and 265/35-18 on the rear 18x10. This should be ok for just street driving, right? Tire Rack shows me a warning message when I go to purchase these tires in this size as it is not considered the right size.
Tire rack is suggesting 225/14-18 and 255/40-18.
What differences would I see and feel between the two sizes if anything?
TIA for all your wheel/tire guru expertise!
--Chad
The OE size should be 225/45-18 and 255/40-18
But the ones you're looking at will most likely be my choice as well.
They will reduce your diameter by ~0.6" from OE spec.
I think thats fine as long as you do both front & rear. (should keep DSC happy)
Also, a benefit is a minor total gearing advantage.
Negative is that the car will record a few extra miles on the ODO & speedo will read slightly faster.
      05-27-2010, 12:46 PM   #46
nlink720
Drives: 2004 BMW Z4 Roadster
I have a 2004 Z4 3.0i with 18x8.5 square at a 30mm offset with 255/35-18 tires all around. The front is close, but there is no rubbing. The rear has plenty of space. Just make sure your offsets are ok, and you should be fine -up to about a 10" rear wheel. You could also just run the wider rear tires on a 9" wheel since 10" should not net you much, if any, performance advantage with only a 265 rear tire. I would go with a 9" rear wheel or perhaps 9.5" rear wheel, or even skate by with 8.5" square.
      05-27-2010, 01:44 PM   #47
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
The ODO will still read accurate since the ECU has the real speed from other variables. The speedo will read slightly faster tho.
      05-27-2010, 01:46 PM   #48
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ thanks... wasn't sure where the ODO picked up it's source.
      05-27-2010, 03:12 PM   #49
GP20
Tire rack is suggesting 225/45-18 and 255/40-18.
--Chad
Aside from the speedometer being a little more off, you'll be okay. Less unsprung weight, better gas mileage, and less tramlining. I might go with those sizes for my next set of tires, too.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      05-27-2010, 03:16 PM   #50
GP20
Actually, inTgr8r is right. The odometer will record a few extra miles when reducing the tire diameters.
2016 BMW M3
2008 BMW Z4M coupe
      05-27-2010, 03:37 PM   #51
Blind32
Blind32's Avatar
Drives: '07 Z4MC
My appologizes then. I'll go do my homework
      05-27-2010, 05:04 PM   #52
MakoBimmer1
Booyakasha!
MakoBimmer1's Avatar
Drives: '13 Mini Cooper S Coupe'
By how much you think? I dont want to rack up false miles!
'08 M Coupe--AW/IR--SOLD!--My M Coupe Obsession
'13 Mini Cooper S Coupe - My Maui Mobile
'13 Mini Cooper S Paceman- My Maui 'Stuff Hauler'
      05-27-2010, 05:34 PM   #53
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
For every 1000 miles you will rack up 1027 miles.
Data sheet
      05-27-2010, 07:36 PM   #54
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
Originally Posted by GothM View Post
IMHO 236/265 set up would be adequate. You would save a little weight, get less tire "pooch" and the car would be more fun to drive if you like to chuck it around. Like I said though I have not got to explore the 245/275 set ups full potential yet.
yea, i've been doing some research on tire traction and it seems tire width is much less important than sidewall flex and tire compound. but ya gotta admit a wide set of tires look mean!
could also save ourselves some worries about hydroplaning with a little smaller tire
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      05-27-2010, 08:00 PM   #55
GothM
Oversteer Enthusiast
GothM's Avatar
Drives: '06 M Coupe, Black Sapphire
With my 245/40 275/35 set up on Nitto Invos I was surprised the sidewall actually ended up being taller than the stock 45/40 set up. I ran into a similar issue on my M3 between Advan Neovas and Hoosier A6s both identical size but the Hoosiers being taller. That is typical from my experience with race rubber though. So between brands you may find that the side-walls vary slightly.
Depending on the tire you might get a little pooch effect but unless it is substantial, you are really one with your car or driving competitively and keeping a data log you probably wont notice if the diameter is slightly off.
If your time/budget allows it is fun hit the track or auto-x to experiment with tires to see how they effect your car.
