      07-14-2010, 04:27 PM   #45
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by Roffle Waffle View Post
hmmm. I def wanna go with something that'll fit 285s in the back. I guess I'll stick to 19 x 10s
You can get away with 19X10's and 285/30/19's. Because you are fitting the maximum width, the offset is very important.
      08-20-2010, 10:42 AM   #46
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Update:
The RAC Monolites RG63s are on
18 x 9 +38, Continental ExtremeContact DW 255/40
18 x 10 +27, Conti EC-DW 285/35
Stock suspension as of now
Not a ton of miles on them so far. Just today, during a spirited drive, I encountered a good dip in the road at a small bridge over a creek. Back country road, your typical down hill to a small creek bridge then right back up hill again. I was doing a descent clip through there and under that kind of hard compression I got rubbing up front - inner fender right where it attaches to the bumper cover.
My concern is that I would like to go to some Dinan springs and I'm worried that it will rub more often than just under really hard compression as in the scenario above.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      08-23-2010, 10:13 AM   #47
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by onebluemcm View Post
Update:
Great looking set-up.
-255/40/18 is going to be too tall for the front. You can run 255/35/18 or 245/40/18
-With the more agressive wheel and tire fit up front, you will also want more negative camber.
-The front wheel size you are running will fit with the right size tire and camber adjustment.
      09-29-2010, 02:54 AM   #48
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
F: 245/35-19 w/ 19x8.5 ET35
R: 275/30-19 w/ 19x9.5 ET 35
Will this fit my 07 Z4MR? or do I need spacer at the back with longer bolts?
thanks,
      09-29-2010, 03:54 AM   #49
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
rears will fit w/o spacer but you can add a 10mm
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      09-29-2010, 01:26 PM   #50
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
if i want a more flush look, would i need to add 5mm spacer or 10 mm spacer to apex arc 8 18x8.5" et38 front wheels and 18x9.5" et35 rear wheels? also would i need longer studs?
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      09-30-2010, 02:00 AM   #51
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
How about the fronts?
I don't think I'd bother with the spacer for the rears, longer bolts. ET35 is more inset than stock ET30 from my understanding and increase the width from 8.5 to 9.5; I'm affraid it might rub the strut. Thanks in advance..
      10-07-2010, 07:38 PM   #52
Z4Murder
Z4Murder's Avatar
anyone got an answer for me?
2007 TiAg ///MCoupe
      11-06-2010, 05:00 PM   #53
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
So stock in Z4M is:
F 18 x 8 ET 42 225/45
R 18 x 9 ET 30 255/40
I can get a great deal on a set of e9x M3 rims Style 220M, they are the following specs (with these size tires already mounted on them):
F 19 x 8.5 ET 29 245/35
R 19 x 9.5 ET 23 265/35
Online Calculators showing:
Up front rim would stick out 19mm more.
In the back rim would stick out 13mm more.
I don't think the rears would be a problem but i am worried about the fronts sticking out too much and rubbing. Currently i'm on bone stock suspension and camber.
Am i going to rub or is it a safe set up ? anyone else running these specs for their 19s ?
      11-06-2010, 07:13 PM   #54
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I'd be worried about the fronts. Just take a ruler, and measure how much room you got between the stock wheel's edge and the fender
      11-06-2010, 07:37 PM   #55
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Just measured it, looks like i got 17mm between stock wheel lip and the fender, which is less than what i need ... but the wheel tucks in under the car slightly when the suspension is compressed right ? so it just MIGHT fit without rubbing .... or am i just dreaming ?
      11-27-2010, 07:58 AM   #56
pal
pal's Avatar
433
Drives: Z4 M Coupe
I am running 19x8.5 et42 with a 5mm spacer up front and -1.9 camber. To get a more "flush" look, I think another 5 would do it. So another 5 for you should get to to the same effective offset. Not sure what camber you are running- may want to look into that for rubbing issues.
      11-27-2010, 10:43 AM   #57
ZStig
279
what wheels are those?>
      11-27-2010, 01:26 PM   #58
pal
pal's Avatar
433
Drives: Z4 M Coupe
SSR GT2-H (Semi Solid Forged)
19x8.5 et42, 21.2 lbs
19x10 et25, 22.9 lbs
Tires : 245/35/19 F, 275/30/19 R
      11-28-2010, 06:08 PM   #59
Z4Murder
Z4Murder's Avatar
awesome wheels. thanks for the answer
2007 TiAg ///MCoupe
      11-30-2010, 09:57 AM   #60
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
19 x 9 ET 43
19 x 10.5 ET 30
will those fit?
Nikki
      11-30-2010, 10:31 AM   #61
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Fronts are definitely no problem
You would be 1mm more than those wheels above^ on the rear.
You will be 19mm extend more than OE
      11-30-2010, 11:22 AM   #62
nemex12
Drives: e60,z4
9x19 ET:31, 10x19 ET:25? m3 e92 gts offset
if you want perfection buy a mercedes, or marry an accountant
      11-30-2010, 06:39 PM   #63
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Originally Posted by Nikki View Post
19 x 9 ET 43
19 x 10.5 ET 30
will those fit?
I have an 18x9 +38 on the front and it's pretty close to the strut tube. Heck, it also sits out pretty far too. The 9" front has to have just the right offset, I'd say in the +32 to +35 range is ideal based on my wheel setup. The +43 will be 5 mm further inward, so closer to the strut tube, but this is a better offset to fix through the use of a spacer. More often it seems to me that too little offset is much harder to deal with than too much offset, within reason anyway. You can only run spacers so wide....but you can correct too much offset with spacer, not so many ways to correct a wheel with not enough...
Not sure about the 10.5 +30 rear, probably will be tight depending on rubber. My 10" +27 with 285/35 tire sits pretty far out.
IMO, and it's just that - an opinion, the easiest, sure way to go for a great fit, no worries about rubbing, many tire choices is with an 8.5" front, 9.5" wide rear wheel in your choice of 18" or 19" diameter. There's a wider range of offsets that will fit with no problems in these wheel widths - above these numbers, offsets become more and more critical, and also it seems like attention may need to be paid to alignment parameters too (eg., adding camber to get things to fit).
      12-02-2010, 10:51 AM   #64
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
Alright, thanks for the advice. Looking at another set now. Will these rears fit?
18x8.5" +38
18x10" +25
Nikki
      12-02-2010, 11:43 AM   #65
ZStig
279
should
      12-02-2010, 03:59 PM   #66
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
18x8.5" +38
18x10" +25
IMHO the fronts will look great with appropriately chosen rubber (i.e., not stretched or too fat for the wheel) The rears at +25 will sit 2mm further out than mine do. 2 mm may seem negligible, but I would say that mine are really at the limit of how far out the rear wheels should be on this car. If you went with a 275 width tire, it might be OK from a rubbing point of view, but, and again IMHO, a 285 is the tire of choice for an 19x10 wheel - the proportions and fit are just perfect for the wheel. A 275 will fit the wheel, but might look kind of stretched.....opinions.....
For reference, here's what mine look like:
With a 10" wheel in the back, the offset is pretty critical. This pic below was taken from behind the rear wheel, aiming up and forward to show the clearance. The shock is not the issue, it's the frame of the car/chassis that's the issue. Again, IMHO, with an 18x10 rear wheel, I think the perfect offset would be about +30 to +32, just to keep in inboard a few more millimeters than mine sit, but still with enough clearance to the chassis to avoid rubbing. Not sure if this type of offset is available, but if it were, it would fit great.
