05-16-2016, 12:56 PM | #45 | |
Rep 428
1999 /// M3 Convertible Techno Violet |
05-16-2016, 03:02 PM | #46 | |
Rep 47
05-16-2016, 07:35 PM | #47 | |
Rep 428
06-06-2016, 11:00 AM | #48 | |
dances with roads
4738
Rep 4,099
I made other comments in this thread: http://www.zpost.com/forums/showthread.php?t=949497 I'm still researching alternative bulbs. Here's what I know so far:
06-06-2016, 11:16 AM | #49 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
http://www.zpost.com/forums/showthread.php?t=970661 http://www.zpost.com/forums/showpost...5&postcount=16 http://www.zpost.com/forums/showthread.php?t=724153 http://www.bimmerfest.com/forums/sho...49&postcount=8 http://www.zeleznik-klein.com/z4/fixit/drl/index.html http://www.bimmerfest.com/forums/sho...t=#post4774314 http://www.ebay.com/itm/400478812293...%3AMEBIDX%3AIT http://www.ebay.com/itm/6K-Xenon-Whi...tRgXMD&vxp=mtr It's on my to-do list. Salty
06-11-2016, 09:24 PM | #51 |
Rep 2,551
Dual LED AE $375 installed (not including shipping):
06-20-2016, 08:59 AM | #52 | |
Rep 47
06-25-2016, 04:43 PM | #53 |
Rep 2,551
06-25-2016, 07:39 PM | #54 |
Rep 79
06-25-2016, 09:03 PM | #55 |
Rep 2,551
06-30-2016, 07:43 PM | #56 |
Rep 1,031
This site is a wealth of knowledge. Thanks to you guys I bought the LED bulbs off ebay and gave it a go.
I was able to turn off the bulb out warning via turning off high beam monitoring using Carly BMW Android App. The pictures don't do it justice at all. It is whiter and brighter in person. Pardon my messy garage .. doing a bathroom reno.
06-30-2016, 08:48 PM | #57 |
Rep 11,668
Nicely done Mirko, that looks WAY better that the OE setup.
06-30-2016, 09:58 PM | #58 |
Rep 2,876
07-15-2016, 05:32 PM | #59 |
Rep 1,543
Can you post the contact info for the AE install? Car's in the shop for a week or so anyway. What's the turnaround time?
07-16-2016, 04:40 PM | #60 |
Rep 2,551
Since your info shows Canada, shipping will probably be expensive. You can calculate shipping both ways to zipcode 20833 and see if it's worth it to you. Turnaround is about 3 days not including shipping time. PM me if you want additional details.
08-08-2016, 12:08 PM | #61 | |
Rep 451
Has anybody else who's done this noticed how blue they appear? My bulbs are definitely white but look blue when installed... especially compared to the new AEs in my X3. edited... Just saw Amaryasira's led AE post, most have missed the section on getting a bulb with <5000... I'll double check mine and possibly reorder.
Instagram: @dasianoak
08-20-2016, 04:33 AM | #62 |
Rep 199
I noticed that both your turn indicator lights were on, even though only one side was changed to led. When I tried this, only the side with the led had the turn indicator on. Was this resolved through programming?
08-20-2016, 06:10 AM | #63 |
Rep 1,031
I didn't have any issues like that. I only coded the car after both bulbs were installed and both lights worked throughout.
Might be a bad connection somewhere or bulb issue you are having. does it go normal with both led bulbs installed?
08-20-2016, 11:44 PM | #64 |
Rep 199
I didn't try the other side coz having the turn signal on was a huge turn off already... could it be that the turn signal was on because I did not reinstall the back cover of the head lamp?
08-21-2016, 09:01 AM | #65 |
Rep 1,031
The turn signal's were only on in one of the pictures cause I turned the light switch to the first position. Otherwise my car is coded to show only the angle eyes as the day time running lights. In North America we are mandated to have the turn signals on when the lights are on. In Europe and I suspect Singapore you don't have to have them on. Did your turn signal lights turn on after installing the LED bulb or were they an option you could turn on before?
08-21-2016, 11:28 AM | #66 | |
Rep 2,876
My guess as why the parking lights were on after installing LED has to do with coding. BMW's code may turn on the parking light of that side if it detects a bulb out on the angel eye of that side as a safety feature. You want something to light up on both sides of a car so it doesn't confuse people - that it's a car and not a motorcycle. Try coding out monitoring on the angel eye to see if this is still an issue? |
