09-02-2013, 09:32 AM | #2 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
Not me but I've seen plenty of e9x on track with steptronic and its fine. It's not the best platform for a dedicated track car but I see no issue with the occasional driver school.
09-03-2013, 05:44 PM | #3 |
Rep 115
Ha Thanks, looking around to see if I can find a 2.5l with smg, but so far its only been steptronic
09-03-2013, 07:05 PM | #4 |
Rep 12,559
I would take the reliability of a step over 1st gen smg anyday. Keep in mind some clubs (ironically CCA) won't allow a convertible on track. PCA and NASA are ok with it though.
09-03-2013, 11:12 PM | #5 |
1817
Rep 5,337
The biggest problem with steptronic is the heat that the automatic/torque converter generates. Since the transmission oil cooler share a core with the radiator, you'll likely see water temp anywhere between 10-20ºF higher than you would in an SMG or manual.
Luckily, the M54/N52 are quite reliable in terms of heat management. But I have seen various E9X 328i go into limp mode in high ambient temp situations at tracks with a lot of low speed turns. If you do end up with a steptronic equipped vehicle, I'd invest in a transmission oil cooler just in case. Otherwise, they are just as reliable, if not for the torque converter and the planetary gearing having a mind of their own.
05-01-2016, 04:58 PM | #6 |
Rep 59
Just posted a new thread with the same question before I found this one.
I would think the torque converter would lock up at higher speeds in sport mode to mitigate heat. Anybody know if the steptronic will hold a gear at max revs or upshift automatically while in manual sport mode? |
