05-19-2016, 05:00 PM | #1 |
Rep 870
Drives: 2006 BMW Z4M Roadster
General Question about your Z4M
Ever since I've owned my Z4MR, I've had the drivetrain clunk that is evidently fairly common. I've ruled out the dual mass flywheel explanation. My clunk or thud is further back than the transmission. I've done the BMW bulletin where the differential flange is greased. I thought that fixed it, but it was a placebo. On my list of possibilities are: differential bushings, rtab bushings or other suspension related thuds, center bearing, driveshaft, and guibo or however you spell it.
I have a few interesting things going on, and I wanted to see if any of you have this with your Z4M. 1. Going down a mountain or long steep hill in 6th gear, the car never gets runaway fast. In most cars I've had, this one mountain drop will cause you to go 90 MPH if you don't tap the brakes. In the Z4M, it never gets above 60. Is that normal? A condition of the gearing? Could it point to an issue with the differential? 2. 1st to 2nd is problematic. I'm not talking about the notchy shifting. Mine is smooth as butter after installing new engine and trans mounts and replacing the fluid. But, when I let the clutch out in 2nd, it sometimes wants to jack-rabbit, surge, pulse, or whatever you want to call it. I have driven manuals for years, so I don't think it is operator error. The CDV has been removed. This seems to be significantly worse when cold. 3. Not often, but every once in awhile, I feel jerkiness, almost like my wheels are slipping when starting in 1st. I'm not launching aggressively when this occurs. I've never noticed any DSC lights flashing. First gear is the only gear I've noticed this. I'm hoping it isn't the trans, but a bit worried. Any of you ever experience any of the above? Is #1 normal? The car only has 37K on it. Thanks, Salty
05-19-2016, 05:18 PM | #2 |
636
Rep 3,124
1. I've never gone as slow as 60 in 6th, but my car holds 80 with no breaking coming down the Cajon Pass, which is 6% grade for 4 solid miles. I always wrote it off to the high compression engine.
2. I've been driving stick for over 40 years, and still 1st to 2nd is harder to get right in the Z than anything else I've driven. I write it off to the car being very unforgiving due to the high torque to weight ratio. A lesser car will speed or slow the engine slightly using the kinetic energy of the mass of the car. In our cars, the engine dominates. 3. Greasy road? Doesn't take much to get a little slip. Mine chirps the tires on a gentle takeoff just crossing the painted crosswalk lines. A little slip like that won't set off the DSC.
05-19-2016, 05:21 PM | #3 | |
Rep 870
Thanks, man! Salty
05-19-2016, 05:27 PM | #4 |
636
Rep 3,124
That I don't get. Plenty of racket from the dual mass flywheel if I push the clutch in with the slightest positive or negative load.
Especially in 1st gear pulling into a driveway or parking space. I give it the slightest little gas before hitting the clutch to try and get neutral loading.
05-19-2016, 06:39 PM | #5 |
Rep 355
I get no clunking from my clutch.
1)have you done any brake work?My 06MR only has 24K and it had a sticking front caliper when i bought it.(from a dealer,no less)
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
05-19-2016, 10:44 PM | #6 | |
Rep 870
Salty
05-20-2016, 10:10 AM | #8 |
Rep 623
My 3.0i on a grade will just go, no matter the gear. It is like it has no drag, it will just take off. My Tundra will maintain and even downshift if on a grade.
Steve |
05-20-2016, 10:56 AM | #9 | |
Rep 12,565
Rogue trans bushing SSK shifter with taller knob Mason Engineering clutch pedal (which required me to put back original clutch stop) Trans fluid drop and fill every 40k with oem stuff And I generally rev higher and let the clutch out milli second slower from first to second |
05-20-2016, 01:27 PM | #10 | |
Rep 870
Is this what you're talking about? That's high on my list of suspects. That sounds about where the clunking is happening under the car. Did you replace it, yourself? Tough job? Salty
05-20-2016, 02:54 PM | #11 |
Rep 758
That's the part Vanne is referencing. That would be the first thing I'd check and the giubo (proper spelling and pronounced jew-bo) would be next.
Top Down 365
05-20-2016, 03:31 PM | #12 | |
Rep 870
Salty
05-20-2016, 05:39 PM | #13 | |
Mechanical Engineer
96
Rep 1,025
I also occasionally get thuds coming off the clutch quickly. I've always attributed it to the "m clunk" that many people report in the e46. If you change the driveshaft bearing and it goes away I'd be very interested in knowing. Also I'm curious how hard it is to change that bearing. I'm thinking you probably need to drop the whole exhaust and driveshaft, and maybe the diff. |
05-21-2016, 01:57 AM | #14 |
703
Sounds normal to me. The first - second is like a secret handshake in this car. Its totally unlike any other manual. My approach has been to keep the revs up by not letting off the throttle-keeping them at 3-4k (or whatever speed req'd to match where revs will land in 2nd). Almost like a heel toe upshift. And yes way more pronounced when cold.
As for the clunk i always shift to 1st let out the clutch a tad then go to reverse. Thats where i notice it most and this other secret handshake seems to work for me. Car doesn't run away either on a grade--high compression engine there. Note: this is the same on both Z4Ms we have which is why I ascribe it as normal. |
05-21-2016, 08:21 AM | #15 | |
Rep 870
I've read so many threads on this, and there seems to be a number of things it can be, and a variety of sounds. Some have chatter and forward clunks (clutch normal), some have metallic clicks/clacks (diff flange splines - technical bulletin fix), some have dull thuds (diff bushings, suspension bushings, ball joints, center bearing, giubo). Some people have Z4's that have never had a single clunk/thud. Salty
05-21-2016, 08:58 AM | #16 | |
Rep 870
Like you, I rev match quite often, and that does seem to make for smooth shifts when I get it perfect. Thanks all for the feedback. I know it's an old subject that gets tossed around from time to time. It's one of those things like the vanos rattle -- it's hard to know what is normal and what requires attention. Salty
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete Last edited by SaltyNC; 05-21-2016 at 01:43 PM.. |
05-21-2016, 02:05 PM | #18 | |
Rep 870
Salty
05-21-2016, 08:11 PM | #19 |
Rep 11,667
^ It sounds like you're coming off the throttle a little too soon.
05-21-2016, 08:47 PM | #20 |
Rep 2,866
Does the clunk sound like this?
05-22-2016, 08:03 PM | #22 |
Rep 870
