05-16-2016, 12:32 AM | #1 |
Rep 1,923
Does anybody has no cats at all?
So my car has no cats at all and the gas smell when I hit the gas is horrible to a point that all my shirts smell gas rly bad....we checked five times for leaks and there is none
I know that when you r parked, the smell will be bad.,but even on the highway? When I had e92 I never felt the smell in the car with Windows closed and Ac on
05-16-2016, 01:57 AM | #2 |
Mechanical Engineer
96
Rep 1,025
something is very wrong there. to get a strong smell in the cabin you must have a leak somewhere close to the cabin, maybe exhaust manifold?
05-16-2016, 06:26 AM | #3 |
Rep 12,565
I'm catless and the smell was noticeable at every light but never while driving. I eventually installed a high flow cat and that helped a lot. I suspect you have a leak as well. Did you use new gaskets during install?
05-16-2016, 09:22 AM | #4 |
Rep 2,782
Check for black streaks on your exhaust, especially at all the connections.
05-16-2016, 10:02 AM | #5 | |
Rep 2,866
05-16-2016, 10:13 AM | #6 |
Rep 912
There's a slight smell, but only sitting still and it's not any worse than my Stage2+ Jetta that was running catless.
Check to see there aren't other problems with your air fuel ratios. |
05-16-2016, 12:10 PM | #8 |
Rep 1,923
Thanks guys...now I know something is wrong.
I only use the car once or twice a month to go to track
05-26-2016, 03:17 PM | #9 |
Rep 1,923
found out the leak!!!..........my trunk doesnt have that rubber seal and my friend sat in the trunk while i drove the car and he said the smell was all coming from those little gaps......at least its an easy fix, but in this link, I beleive its number 3, but it doesnt say what it is or the part#....does anybody knows the part#?
http://www.realoem.com/bmw/enUS/show...diagId=41_1696 edit..just found it! 51763425290 thanks Last edited by AriuSen; 05-26-2016 at 03:39 PM.. |
