02-27-2016, 04:50 AM | #1 |
Rep 453
Drives: 2007 Z4M Coupe
Air condition help
Wondering if anyone can help with my AC question. After a long search, I'm now a proud owner of a 2007 Z4m coupe. Last week I purchased it from a gentleman in Pennsylvania. I decided to drive it back to Detroit as amazingly the weather would be clear and in the 50's that day. On the way home I realized that I hadn't tested out the AC before purchase so I fired it on. To my horror I couldn't get anything but warm air. Knowing that AC problems could get expensive I was kicking myself for not testing it first. So after I got home I did my research and read that the car may have a system where the AC won't blow cold if the outside air temp is less than 59 deg. So the next day I lucked out and it was in the 60's so I fired up the A/C again and sure enough cold air came out, not freezing cold but definitely cold. Could someone confirm this is how the system is supposed to behave? I Would like the know for sure instead of waiting until the next time it gets above 60 deg.
02-27-2016, 07:54 AM | #2 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Congrats on your new Z4M! I think it does have a cutoff, but I was thinking it only had to be above freezing (>32 F) to work. I'll be driving mine today, and I'll test it before the temp reaches 59 and let you know what happens. Does the light come on for the AC when the temp is below 59? Salty
02-27-2016, 11:30 AM | #3 |
Rep 453
Thanks salty, appreciate it. Yep, light on the climate controls comes on when I turn the AC on. Pretty much looks like normal. All the modes work and the fan functions fine. AC compressor clutch engages as well when the AC button is pressed. Instrument cluster displays an accurate outside temp which I think means the ambient temperature sensor under the bumper is working fine. Everything looks like it should except I get warm air. I'm think I'm going to rent some gauges and check the high and low side pressures but figured I wait till it warms up first and see if anyone can confirm if that defeat exists. Hopefully the defeat is causing to warm air or I just need a recharge and leak detection.
02-27-2016, 05:49 PM | #4 | |
Rep 870
Hopefully it is OK. If I have on the heater and switch to vents, it can take awhile before the air temp changes. Did you post pics of your new Z4M? What color? Salty
02-28-2016, 12:11 PM | #6 | ||
Rep 453
02-28-2016, 12:12 PM | #7 | |
Rep 453
02-28-2016, 12:54 PM | #8 |
Rep 2,866
Congrats on the new ride...good times coming
Make sure you're not running auto climate as that may turn off the A/C if it detects low ambient temp. Also, you may want to try the "defroster" or "defogger" to see if you can get cold air out as the system does use the A/C as a dehumidifier. Sorry that I can't help you validate this as SoCal weather are mostly in the 70s |
03-01-2016, 01:51 AM | #9 |
1621
Rep 4,294
Anyone got stats in regards to how much oil and gas should be in there, I have to service mine (works great, but havent had it done before and now own the car for 3 years..)
Congrats OP, on your new car, pics when you can please |
05-27-2016, 12:16 PM | #10 |
Rep 453
Hey Vanne, a bit late on pics but here they are. The mods are coming along nicely.
05-27-2016, 03:38 PM | #11 |
Rep 847
Stunning ride!
I think the issue you may have heard of is when the ambient temp sensor gets disconnected (or damaged) and the car shows a default outside temp of -40 degrees. It happened to me and the AC didn't work until I got the sensor fixed. |
05-27-2016, 05:06 PM | #12 | |
Rep 870
Salty
05-27-2016, 07:11 PM | #13 |
Rep 204
I just did my AC this week and I think it was 1.3lbs. There is a sticker on the hood that says the specification.
05-28-2016, 12:27 AM | #14 |
Rep 453
Had them painted by a shop when he was painting my side skirts. The driver side was a bad color match so I'll have to do those over myself soon. My painter did mention that they took longer because they forgot to do the reflectors. I suspect they forgot to do the driver side and when they went back they used the wrong shade of titanium silver.
