      01-09-2014, 07:29 PM   #397
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Woots View Post
Where did u find the mpower sticker??
Here is one location....
http://www.acromann.com/product_info...q3jpa4lgfgh4k0
      01-10-2014, 07:47 AM   #398
Woots
Woots's Avatar
Drives: Z4///M Roadster
Thanks buddy!!
I'll see if they ship to uk
      01-10-2014, 09:52 AM   #399
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks buddy!!
If not, I'm sure someone here would help with forwarding
      01-12-2014, 09:52 AM   #400
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Devious21 View Post
Is yours satin or gloss finish?
      01-12-2014, 10:07 AM   #401
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
So jealous. I want one of these bad...
instagram: @ dubsesd
      01-13-2014, 02:11 AM   #402
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Satin
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R|
      03-04-2014, 06:15 PM   #403
C-los
Drives: 2013 M3
So I'm curious, is this essentially a CSL Replica with added cold air snorkel? What's the difference between this sexy unit and the OEM CSL Manifold?
Thanks!
      03-04-2014, 07:37 PM   #404
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
It's basically the same as the CSL airbox. Neither use the original MAF sensor. Several of us are using the RPI scoop, as the intake is almost touching and lines up with the radiator bulkhead. It comes with no decal, of course, but one can be easily added. The tune provided by Evolve is a bit different than the BMW tune. The air temp drops about 2 degrees F. vs. an aFe intake, and maybe as much as 5 degrees or more over the stock Z4M airbox. The intake sound is nearly identical.
Z4M's were never included in the CSL program, so not sure if a stock E46 CSL 'box can be adapted and if it can, what is involved in the tune. The Evolve system is pretty much drop-in. No codes. Hope this helps.
      04-14-2014, 05:07 PM   #405
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
So I love the airbox... I am well on my way to becoming deaf, but that's partly my fault for keeping the RPIs on as well...
I have noticed though, that I am no longer able to heel/toe with this tune, has anyone else noticed...?
It doesn't matter if its in normal or "sport" mode, but if I am on the brake, I can't blip the throttle.
any thoughts?
      05-05-2014, 06:12 PM   #406
sixspeed
Z4M CSL
sixspeed's Avatar
Drives: Alpine White Z4M Coupe
See my post earlier, I can back up this issue also. Brake application renders the throttle pedal useless. Have spoken to the Evolve guys though and believe they are looking into this now. Have you emailed/called them though? As Imran wasn't aware of this problem when I spoke to him, and I only reported this on Friday.
      05-05-2014, 11:50 PM   #407
StickMon
StickMon's Avatar
Drives: 2006 MR
So you were able to heel/toe before the mod?
I always thought the problem was this "feature".
      05-06-2014, 03:32 AM   #408
sixspeed
Z4M CSL
sixspeed's Avatar
I've done hundreds of laps of the Nurburgring in this car, more trackdays at other circuits than I care to remember, and I've definitely never had any issue with heel-and-toe before now.
      05-06-2014, 08:52 AM   #409
angelr
Drives: 07 aw/ir m coupe, 2013 S4
Is it ignoring pedal application altogether or does it seem lean and lazy but still does something?
      05-06-2014, 01:17 PM   #410
sixspeed
Z4M CSL
sixspeed's Avatar
It's ignoring it completely. Engine completely dies if you stay on the throttle and left foot brake (you can't hear the engine straining still or any induction note). Or if you dip the clutch and genuinely heal and toe, the revs just sit at idle. It's definitely disabling the throttle rather than just reducing input.
      08-10-2014, 02:26 PM   #411
asirvr4
Oman
38
Drives: '06 M Coupe VRS Blue
sixspeed,
are you still suffering with same problem?
      08-10-2014, 02:49 PM   #412
Beedub
why are evolve so quiet though??
i don't think they've eve quite got a handle on z4m tuning as i remember the issues from the first tunes they offered on a GB years ago... i really wanted them to tune my s/c z4m but was put off a little due to that reason...
whatever i say about ESS the tune and general running of the car is pretty much perfect, i can left foot brake and load the car with the throttle no probs, its not an issue on my s/c speed density tune or Maf-less tune as we call it.
      08-10-2014, 03:58 PM   #413
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
i don't think they've eve quite got a handle on z4m tuning as i remember the issues from the first tunes they offered on a GB years ago... ........
I feel the same way.....
They never really got it sorted & and never properly responded when questioned.
      08-10-2014, 04:11 PM   #414
Beedub
+ 1
      08-13-2014, 03:43 AM   #415
asirvr4
Oman
38
Evolve, how much for the airbox with necessary parts? (Without the tune)
      08-13-2014, 07:34 AM   #416
sabbanick
Drives: 08 SBM M coupe
Take off 900 bucks from cost
      01-08-2015, 01:34 PM   #417
SCZ4
Drives: F11 525d M Sport & Z4M
Was this brake issue ever resolved?
      01-08-2015, 03:01 PM   #418
fdagen
Drives: 2006 Z4M Roadster
Not that I know of. I received my tune around Sept 14. I would be happy to work with Evolve on it.
