      08-25-2013, 10:28 PM   #991
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Originally Posted by Rated M Roadster View Post
Just ordered a second one from here; this time coated:
http://www.928motorsports.com/parts/6ribpulley.php
well I'll be a S.O.B, I was only looking at the Vortech site. Ess pulleys are milled down 2.7mm or 1/8" , I'm guessing yours aren't.
      08-25-2013, 10:34 PM   #992
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Milled down? In what way?
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      08-25-2013, 10:43 PM   #993
ZStig
279
the snout end of it, so that it sits closer to the supercharger
this is my bible: http://www.m3forum.net/m3forum/showthread.php?t=419360
      08-25-2013, 10:47 PM   #994
Rated M Roadster
160
Oh; I bought this spacer: http://www.928motorsports.com/parts/...spacer_kit.php
Then had it cut down to the same spacing of the original pulley.
      08-25-2013, 10:53 PM   #995
ZStig
279
cool. I'm gonna take off my pulley, measure the spacing, and then request the coating company to machine it to match. I assume the stock pulley is just cut down 1/8", but it would suck to be wrong and have wasted all that money
did you have to take the supercharger off to the the pulley off? How are you going to calculate the belt size for your new pulley?
      08-25-2013, 11:39 PM   #996
Rated M Roadster
160
I would wait to get the pulley before cutting the spacer; then you can measure it on the car and get the spacer cut locally. Needs to be fairly precise.
You just have to hold the pulley in place while you loosen the bolt; then it just slides off (if not, heat it up with a torch). The stock pulley on my kit was a 2.7", so I'll just use the same belt.
      08-25-2013, 11:42 PM   #997
ZStig
279
Thanks for the tips, I'm just waiting on feedback from one more source about what PSI to expect with the 5.11/2.87 combo
are you planning hitting 11psi on a stock fuel pump, or does your kit already come with fuel upgrades beyond bigger injectors?
      08-26-2013, 12:21 AM   #998
ZStig
279
I don't know why I'm over thinking this. 2.87" is a 3 step smaller pulley than 3.33" and should therefore be 3psi higher than 7. 1psi per each size decrease
      08-26-2013, 07:08 AM   #999
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Not necessarily. For my non-M it worked out closer to 0.5 psi.
      08-26-2013, 11:40 AM   #1000
tikamak
Lebanon
58
I have measured my VT2-500 kit with 8 psi pulley like beedub and i have 135 mm crank and 79 mm supercharger pulleys.
My car is putting down 457 wheel hp and 390 crank tq
      08-26-2013, 11:47 AM   #1001
ZStig
279
beedub is running a less aggressive 130mm crank and 82.55mm supercharger from what I've gathered.
      08-26-2013, 11:47 AM   #1002
ZStig
279
probably because of the lower engine compression
      08-26-2013, 11:59 AM   #1003
seank
enthusiast
seank's Avatar
48
And how is that a 500 kit with those numbers?
      08-26-2013, 12:16 PM   #1004
tikamak
Lebanon
58
Beats me, all i asked was for the 8psi pulley upgrade to be included.
I have a boost leak as well, my car is only seeing 0.45 bar which is 6.5 psi.
I need to get to 0.55 bar 8 psi.
My car has EURO headers + decatted S pipe + stock xpipe and el diablo muffler (open flow)
      08-26-2013, 12:24 PM   #1005
tikamak
Lebanon
58
      08-26-2013, 04:25 PM   #1006
pokeybritches
2006 BMW Z4M  [8.50]
Did you do a baseline dyno, kr have one from a stock S54 car on that dyno? What was the correction factor?
      08-26-2013, 06:39 PM   #1007
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Also curious...
      08-26-2013, 07:13 PM   #1008
seank
enthusiast
seank's Avatar
48
Impressive.
      08-26-2013, 07:26 PM   #1009
Rated M Roadster
160
Also curious...
Me too...
      08-26-2013, 11:10 PM   #1010
ZStig
279
alright. enough research! I ordered a 2.87" pulley, shipping straight to the pulley coating company. I hope it won't slip once its done. I'll probably replace my hydraulic belt tensioner just to be sure its not my belt size which is slacking right now.
I'll dyno before, and after. If the fuel isn't keeping up, I'm going to order an Aeromotive 340 stealth fuel pump. Maybe I should just do it now anyway, thats the next decision point... http://www.radiumauto.com/Fuel-Pump-...-E46-P314.aspx
      08-27-2013, 01:26 AM   #1011
tikamak
Lebanon
58
I didn't do a baseline dyno. also no idea on the correction factor.
But a stock US e46 M3 is 279 whp on this dyno.
      08-28-2013, 10:54 PM   #1012
ZStig
279
let me know how you like the coating. After I ordered my pulley and coating, I found out that there is a considerable number of people who experience dusting from the belt, indicating that the coating is really hurting the belt. Ideally I'd run a bigger crank pulley, but that is 2x the cost of a coated small pulley
Its too late for me now, everything is ordered.
