      08-05-2013, 11:45 AM   #925
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
oh, and I'm going to hide the meth injection kit by using the windshield washer tank as the reservoir, and hiding the pump inside the bumper. Also plan to get it running on concentrated windshield washer fluid which is 30% methanol, and cheap enough to run daily. I guess within the next 3 weeks or so
      08-05-2013, 01:01 PM   #926
seank
enthusiast
seank's Avatar
48
Please take pics of the install for us. I look forward to seeing this.
      08-05-2013, 01:32 PM   #927
dorifto88
Drives: 88 Nissan Pathfinder
any ideas as to where you are going to go for the tune?
      08-05-2013, 05:20 PM   #928
ZStig
279
Probably a local dyno. I want something custom, not an off-the-shelf tune.
      08-05-2013, 07:38 PM   #929
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Windshield washer fluid varies in its methanol content. Some of the colder fluids are 50/50.
      08-05-2013, 07:52 PM   #930
ZStig
279
Very hard to find something rated below -20* which is around 30% meth content, especially in Florida
      08-05-2013, 10:29 PM   #931
ZStig
279
Here's what my cutouts sounds with no cats, at partial throttle. They're now blocked off though, as they're for sale.
      08-06-2013, 08:06 PM   #932
ZStig
279
very odd, apparently my "old" belt was a 6pk2300. My ESS parts list shows it using a 6pk2315 so that's what I put in. Logic would say that this is a 15mm longer belt right?
I did a bunch of pulls and I'm getting a clean 7 to 8psi in 2nd gear at 7900rpm, but only hitting a max of 6psi on top of third gear... Slow boost leak, belt slip, or the rubber around the fittings on the air lines going to the boost gauge are old and maybe leaking there.
The new Continental Contitech 6pk2315 doesn't feel any tighter either. I think I was seeing similar boost numbers on the old no-name belt today actually..
ugh.....
      08-06-2013, 11:33 PM   #933
seank
enthusiast
seank's Avatar
48
ugh.....
Mine says 2360. Now I am confused. I checked twice and it definitely says 6pk2360.
      08-07-2013, 06:58 AM   #934
Beedub
When I get home ill check the belt on my car ....
      08-07-2013, 09:01 AM   #935
Beedub
my belt says...
no belt slip at all...
      08-07-2013, 09:01 PM   #936
ZStig
279
Originally Posted by Beedub View Post
my belt says...
5mm smaller than mine
girls probably won't notice
I'm gonna double check my pulley sizes to make sure everything is correct, these recent vt2-525 threads are scaring me.
I think my AEM meth kit's pump AND controller are dead. I'll have a shop confirm it. for fucks sake, I have only used it for a few days in the last 2 years, and already replaced the controller box once. Hope it was less than 1 year ago, and under warranty. Aem says they'll give me a discount on a replacement if over 1 year
      08-07-2013, 09:31 PM   #937
ZStig
279
Finally some luck, I have 3 weeks of warranty left on AEM's meth controller box, I'll get a replacement free of charge. The pump is only like $67.
I'll be cleaning up my ghetto install too.
      08-07-2013, 09:38 PM   #938
seank
enthusiast
seank's Avatar
48
What I can't figure out is how my belt is 2360 (vs 2310 it's suppose to be) and they are going to send a larger crank pulley. How's that going to fit?
      08-07-2013, 11:26 PM   #939
pandusr
pandusr's Avatar
Italy
Drives: BMW Z4M Roadster ESS CFR 525
Probably you've never been able to take advantage of the kit. To increase the speed of the compressor you can:
-reduce the pulley on the compressor or increase the lower pulley.
... maybe you had posted/installed the belt correct with a wrong low puleghia.
Z4M E85/2006 || ESS CFR525 || AEM Water / Methanol Injection Kits || Supersprint Exhaust (catless,XPipe,rear exhaust race) || 4.10 || front brake AP Racing 6 piston kit (cp5575-1010) || K-Sport suspension with camber plates || Sparco Pro2000 seat || 6 pti Sparco belts -|| Hankook S1 EVO 1 (front 245/35 19 - rear 275/35 19) || OZ Racing Ultraleggera HLT 19"
      08-10-2013, 11:34 AM   #940
ZStig
279
Secondary air pump removed, Lang Racing blockoff plate. 4.25lbs saved from the front-end. No check engine light
      08-10-2013, 06:44 PM   #941
ZStig
279
Ok, I checked my measurements, and I have a 3.33" pulley (edge to edge since the ribs come up to same level), and 130mm crank pulley.
I think my hydraulic belt tensioner is tight enough, but my belt should be 5-10mm shorter to that there's less slack. Am I correct in assuming that a 2315 belt is exactly 5mm longer than a 2310 belt?
Either way, I'm ordering a 141mm Jaws crank pulley soon , so I'll need a different belt
      08-10-2013, 07:36 PM   #942
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
That will take you to exactly 570 spec (impeller speed wise; 48000rpm).
      08-11-2013, 12:18 AM   #943
ZStig
279
hope so!
      08-11-2013, 09:34 PM   #944
ZStig
279
I'm using Vortech's V-3 calculator, using engine speed of 8000. Are my numbers off? Honestly, I'm not sure what my peak boost is right now. I'm hitting 8 in second, but only 6.5 in 3rd...
      08-12-2013, 12:18 AM   #945
seank
enthusiast
seank's Avatar
48
Who is unk? Also, shouldn't the boost increase as you move down the chart?
      08-12-2013, 09:50 AM   #946
ZStig
279
Unk is some stats I found online. Yes, boost should increase, hence my confusion
Search this Thread:
Advanced Search
