      01-24-2015, 08:06 PM   #1
OkieZ4MC
OkieZ4MC's Avatar
Drives: 08 Z4M Coupe
Installation of UUC Short shift kit
Is installation of the uuc short shift kit something that a do-it-yourselfer can do? I change break pads and other routine operations. Just don't know what is involved with the shifter upgrade.
      01-24-2015, 09:41 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
There has been a lot of info posted about the uuc.
http://www.zpost.com/forums/googlese...827j2258945j15
If you look for the DIY thread on the auto solutions ssk install, you will find a lot of the basic installation info you need.
      01-25-2015, 07:27 AM   #3
fdagen
Drives: 2006 Z4M Roadster
It's not hard, but it is a lot of work. You have to drop the section 1 and x pipe, then remove the heat shield. You will be getting pretty intimate with your car. You have to dismantle quite a bit to get to it, and the dssr has not been plug and play for most.
      01-26-2015, 09:43 AM   #4
OkieZ4MC
OkieZ4MC's Avatar
Thanks for the reply. Not sure I want that level of intimacy with my M.
      01-27-2015, 04:34 PM   #5
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
It's not too bad except taking out satans death child. Or whatever it was called in the DIY. Removing and retaining ring and replacing the pin took forever. I was under the car for hours over a couple days.
