      05-03-2016, 02:02 PM   #1
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
PSS Fitment
Is anyone running Michelin PSS in this size on a Z4M without rubbing? I'm debating 245/275 VS 235/265. Will eventually lower car slightly and probably go with coilovers.
275/30/19 on 9.5 ET 22
245/35/19 on 8.5 ET 35
Thanks!
Salty
      05-03-2016, 03:25 PM   #2
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Drives: 635/1815, X3M Comp
Just to share my own experience:
I used to have 245/275 [9.0 x 19 ET31 F, 10.0 x 19 ET25 R] on stock suspension.
245F rubbed lightly on full lock in the inner wheel well.
275R no rub
I've had to downsize to 235/265 [8.5 x 19 ET32 R, 9.5 x 19 ET28 R] with KW CS coilovers.
235F still experience light rubbing on bumpy roads;
265R no rub
I think you should be fine stock; Fitment with coilovers should be ok too but that will mostly depend on the coilovers you get.
      05-03-2016, 04:48 PM   #3
SaltyNC
SaltyNC's Avatar
370
I used to have 245/275 [9.0 x 19 ET31 R, 10.0 x 19 ET25 R] on stock suspension.
275R no rub
265R no rub
Thanks, Mtx! I'm going with H&R coilovers. The car now has 36K, so it is probably time for new shocks, so instead, I'll just go H&R coilovers (shoutout to @finnegan for the suggestion). I have a roadster and don't plan to have it on any kind of racetrack/autox. I just want to slightly lower the car and have a comfortable suspension.
The 265/235 are backordered right now, but I think I'll just wait it out until they are back in stock.
Thanks again!
Salty
      05-04-2016, 11:24 PM   #4
SaltyNC
SaltyNC's Avatar
370
For those of you running 19x10 ET 25 on the rears with 265/30 Michelin PSS tires, do you think I could get away with running 19x10 ET 20 with 265/30 PSS. Five more millimeters to the outside edge than your current setup?
I tried my best to get accurate measurements, but it is tough measuring a curved fender well. I measured from the INSIDE of the fender to the WIDEST part of the sidewall, and I've got basically no extra space, but of course on the Contis I have, the sidewall is curved, so there is more room near the outside edge of the tire. Maybe I would have 7mm or so of extra space allowing for the smaller tread width to sidewall. I get about 12mm extra space to the OUTSIDE edge of the fender to the widest part of the sidewall. Sound about right to you guys?
265/30/19 PSS Tire to Stock
19x10 ET 20 +15MM Possible Rubbing on lowered car
19x10 ET 25 +10MM Best Fitment. No rubbing on lowered car.
19x9.5 ET 22 +13MM Possible slight rubbing with aggressive driving on lowered car. Maybe would clear barely?
275/30/19 PSS Tire to Stock
19x10 ET 20 +20MM Beyond Outer Fender
19x10 ET 25 +15MM Possible Rubbing on lowered car.
19x9.5 ET 22 +18MM Beyond Outer Fender.
Does this sound right?
The rear wheel I'm considering comes in 19x9.5 ET 22 or 19x10 ET 20. I'd rather have the 10" wheel if I can get away with it with a 265 tire. I don't want to go lower width than a 265 on a 10" tire.
I found this old post from dubsesd where he was running 19x9.5 ET 23 with 275 tires, and it's lowered, but I don't know what brand of tire he was running back then or if he used negative camber to achieve it.
http://www.zpost.com/forums/showthread.php?t=636922
Using this calculator shows that a 19x9.5 ET 23 wheel on 275/30 tire that fit for Dubsesd's car is actually wider than a 19x10 ET 20 wheel on a 265/30 tire. So, I'm hopeful.
Man, this wheel and tire fitment is a chore. I feel like I'm back in school, and that's been a long time. I have searched and searched and studied and used tire and wheel calcs, etc.
I imagine ya'll are probably sick of tire/wheel questions. Sorry. :-( I'm late to the party, I know.
Thanks for any help.
Salty
      05-05-2016, 12:04 AM   #5
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
This is a quick flyby, so I haven't dug into the data for you, but maybe this spreadsheet would offer some help?
      05-05-2016, 02:06 AM   #6
SaltyNC
SaltyNC's Avatar
370
Finnegan, that's super helpful. Thanks for posting the link. It looks like folks have 19x9.5 ET 22 running 275's with no rubbing, so in theory, a 19x10 ET 20 should work fine on 265's. I also saw a few entries with 19x10 ET 25 (probably the perfect offset) running 275, and the 19x10 ET 20 with 265's would have the same fender clearance according to this calculator:
http://www.rimsntires.com/specspro.jsp
My worry is the 19x10 ET 20 will look like it is sitting beyond the fender edge.
Salty
      05-05-2016, 11:07 AM   #7
SaltyNC
SaltyNC's Avatar
370
I was measuring in poor light last night. I went back and re-measured. Original post updated with corrected values. I tried using a plumb line. It's still hard to measure accurately.
I also found out that the wheel comes in 19x10 ET 35, so I could run a 10mm spacer and have perfect fitment. Would you go 19x10 ET 25 (with spacer) or 19x9.5 ET 22 no spacer? Is a 10mm spacer an issue?
Thanks to any of our resident wheel experts.
Salty
      05-05-2016, 01:16 PM   #8
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
Salty
Hey Salty,
I am by no means a wheel expert, here's a pic of my fitment of my rear tire setup: 19 X 9.5 et 25 on PSS 265/30/19. Not completely flush by any means but definitely safe. I'm dropped on Eibachs.
      05-05-2016, 07:51 PM   #9
SaltyNC
SaltyNC's Avatar
370
Originally Posted by DEG View Post
Hey Salty,
Thanks for sharing the photo, Deg. I was going back and forth, and with having the wheels and tires shipped to me, I couldn't take a chance on the 19x10 ET 20, even though I really wanted 10" rear wheels.
Oh well, I went with 19x9.5 on 275/30/19 PSS tires. We'll see how it works. Yours with the 25 offset look good.
In case anyone is curious, here is a 19x10 ET 20 with a 275/30/19 PSS Tire. He was getting some rubbing. In the photo, it looks like he's past the outer fender.
http://www.zpost.com/forums/showpost...&postcount=226
And here is an example of the fitment I went with, but with different wheels. Ya'll don't hate me, I went with CSLs (rep). Have always liked them and never owned a set. Maybe I'll get the wheel bug and start changing wheels every few months.
http://www.bimmerforums.com/forum/sh...d-width-alert)
If Inspiri was available here, I might have tried the 01 wheel if there was a good fitment.
Salty
      05-05-2016, 09:07 PM   #10
SaltyNC
SaltyNC's Avatar
370
Another example of a 19x9.5 on 275/30. Dubsesd was running 19x9.5 ET 23 here. My CSL look similar, but are 19x9.5 ET 22, so very similar fitment. What's a millimeter between friends. I also plan to drop the car about 1.5", so it should look the same in the fitment area. Can't wait to get them in and get them mounted.
http://www.zpost.com/forums/showpost...87&postcount=6
Salty
      05-05-2016, 10:54 PM   #11
Finnegan
Finnegan's Avatar
Salty
Decision!!! Win!
Can't wait to see them when you get them on!
      05-06-2016, 06:06 AM   #12
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
WHS+1
      05-06-2016, 09:25 AM   #13
Digs
Australia
133
Drives: Z4M Coupe
Excellent research Salty! Looks like you've got it sorted.
Look forward to seeing the results!
      05-06-2016, 01:09 PM   #14
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
A little late to the party but I'm running 10" rim and offset 25 with a 275 tire, no rubbing and my rear is lowered quite a bit.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black
F06 640iX - Tanzanite Blue/Amaro Brown
K66 ///M1000RR - Competition
