      10-07-2022, 03:26 PM   #1
sikedsyko
Drives: 2005 Z4
ABS Bleed without INPA
Does anyone have experience with methods to bleed the ABS module on an M54 Z4 without using INPA? I'm trying to diagnose a spongy brake pedal, but I've tried multiple installations of INPA and can't seem to get it to connect to the car. I also have Bavarian Technic, but for some reason they don't support ABS bleeds on the E85.
There's some scan tools that say they can do it but don't provide specific model feature matrixes to tell if its possible.
Can I just jump 12v into the right pins? Would be a pain, but should work.
      10-08-2022, 08:53 AM   #2
wdb
dances with roads
wdb's Avatar
4732
I just bled the brakes normally after I had my ABS unit rebuilt.
      10-08-2022, 01:20 PM   #3
GuidoK
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
You can break really hard so that the ABS pump engages.
That at least actuates the valves.
But if you're really diagnosing, I'd just get an INPA/ISTA setup.
      10-09-2022, 12:57 PM   #4
Clearancediver
Drives: 2004 Z4
The pre face lift cars have a different pin out on the cable connector to the car.
Ensure that you buy a cable that allows it to be switched between pre face lift and post face lift.
Two pins need to be switched around on the pref ace lift cable vs post face lift. That's what the switch does on the cable.
You could/likely have wrong cable setup.
Sent from my smart phone...
      10-10-2022, 01:52 PM   #5
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
I have never used INPA to bleed the brakes/ABS and have never had any problems with a spongy pedal. What method of bleeding do you use? I always use a vacuum pump to bleed, sometimes air can be tricky to get our of the calipers if you've rebuilt the calipers. At times I've had to bleed almost 0,5L out of a caliper before the pedal have the right kind of feeling.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      11-11-2022, 03:25 PM   #6
Clearancediver
Drives: 2004 Z4
If you touch/breach/disconnect the lines to/from the ABS module… you will need to use the INPA/ISTAD bleed feature.
      11-30-2022, 11:11 PM   #7
cbpip
cbpip's Avatar
151
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Foxwell NT530 BMW software loaded scanner will do rhe brake bleed as well as other functions for BMW.
      12-18-2022, 06:51 PM   #8
rsutoratosu
Drives: Z4 3.0i
Confirm, I have the same unit and saw the function in it
-Roranji
