      01-16-2020, 11:56 AM   #1
Black911S
Drives: 2007 BMW Z4M Coupe - Imola Red
Z4M calipers -> M3 E46
Can someone confirm if I can pull the OEM calipers from a Z4M and install them on a E46 M3 (2001 w/ non zcp/csl brakes)?
At the same time I'd be swapping out the rotors to CSL ones on the M3.
Thanks
      01-17-2020, 08:59 AM   #2
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Thanks
Yes, same calipers and carriers. Just remember that the rear brake lines are different lengths.
      01-17-2020, 09:43 AM   #3
Terraphantm
Drives: E46 M3 Coupe
Front calipers are the same. Carriers are the same as the ZCP/CSL (i.e sized for the 345mm rotors). To use non-CSL/ZCP rotors, you need to retain the stock M3 carriers.
Rear calipers and carriers are different (pistons are 46mm instead of 42mm). They will fit the M3, but would move the brake bias significantly rearward (and thus would not be recommended without the front 345mm rotors)
      01-17-2020, 11:02 AM   #4
Black911S
So for the rear brake lines I can reuse the existing M3 lines or transfer the rear lines from the Z4M to the M3 (or neither option)?
thanks
      01-17-2020, 11:37 AM   #5
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
The rear ZCP/CSL E46 M3 calipers also use the same 46mm piston as the Z4M. In short, the Z4M brake system is identical to a ZCP/CSL E46 M3.
I agree, if you're going to use the Z4M front calipers, be sure to pair them with the Z4M/ZCP/CSL rear calipers.
Yes, you can reuse the M3 rear brake lines.
      01-17-2020, 01:42 PM   #6
Black911S
got it. thanks!
      08-22-2022, 12:28 PM   #7
NLE
Drives: BMW M3 & Z4M
Are the rear carriers / brackets the same between the e46 m3 and z4m?
I have a set of e46 m3 rear brackets for the 996 calipers and I'm wondering if I can throw these onto the rear of the z4m.
      09-03-2022, 02:53 PM   #8
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Don't forget that his brake master cylinder is 25/20 mm instead of the Z4 M (all M3's after september 2002 as well) that is 25/22 mm. Sure the rear piston size would be bigger with the Z4 M caliper but the brake master cylinder won't push enough brake fluid, can't say how much it would affect the brake bias though.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      09-03-2022, 02:54 PM   #9
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Carriers are the same but the calipers are not.
