      08-24-2013, 10:24 PM   #1
Ro_Ja Boy
Drives: Cars
19x9.5 +35 Fronts and 19x10.5 +35 Rears
Will these fit? Not worried about fender rolling. What tire size do you suggest?
Thanks in advance!
      08-24-2013, 10:34 PM   #2
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
you will be fine as lone as you get some camber going preferbely -2.0 or more.
255/265? not sure if you can fit 275 without rubbing the isnide
2007 BSM Z4M Coupe - 18" VOLK TE37 - 18" Apex ARC-8 - GC Track/Street
      08-26-2013, 10:19 AM   #3
Ro_Ja Boy
Drives: Cars
Appreciate the info. From looking at some other threads on the forum, it looks like the 275s should fit fine in the rear. I think I'm more worried about the fronts and running a 245.
      08-26-2013, 02:44 PM   #4
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
In my experience, the rear offset you have listed will not work. A 10.5" +22 sits relatively close to the inner fender liner. At +35, you should rub. My experience is with 18" wheels. TE-37s to be precise.
Please report back with your findings.
      08-26-2013, 04:12 PM   #5
Ro_Ja Boy
Drives: Cars
So you're saying a +35 would rub the inner fender liner and thus needing a spacer?
      08-28-2013, 03:04 PM   #6
nekky
Wagon life
nekky's Avatar
My feeling is yes.
      08-29-2013, 02:33 PM   #7
SlipNslide
Drives: E91 M Wagon
I agree with nekky. I've got +22 on 19x10.5 and I had to slightly trim the inner liner on the rear. This is with a 275 rear tire. You could probably, go as low as a +18 to +25 rear offset on a 10.5 rear.
      08-29-2013, 02:58 PM   #8
Ro_Ja Boy
Drives: Cars
So worst case with the rear offsets and a 275 I'd trim the rear lining (will plan to do that anyways) and run a 10-15mm spacer.
Thanks guys!
