      10-12-2014, 04:23 PM   #23
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Looks like a lot of non-M owners are lurkers... this thread is the #2 hit on Google when searching for "supercharged z4". I had some time today to compile some of my Z4's videos on my iPhone using iMovie.
Hopefully it will help anyone on the fence answer:
What will the car sound like?
How much power will it make?
How fast will it be?
What's the AFR like?
      10-12-2014, 04:33 PM   #24
Steeler
Steeler's Avatar
2429
Great stuff Josh
Did you change your pulley size when rebuilding the blower?
BTW this thread is #1 when I search google
      10-18-2014, 07:46 PM   #25
pokeybritches
2006 BMW Z4M  [8.50]
Originally Posted by dbarton62
Great stuff Josh
Awesome! No, I kept the original pulley because 928 Motorsports called me and told me they were concerned I would overspeed the blower. The biggest size they made was several sizes smaller. I didn't have the crank pulley diameter handy and was in the middle of something at work, so I held off. The car had been running very well prior to the rebuild, and I didn't want to have to start tinkering again.
      10-19-2014, 08:46 AM   #26
Steeler
Steeler's Avatar
2429
Josh, according to the calculator on the Vortech website we can spin the V3si to 52k rpm
With a stock crank pulley of 5.185 a shift point of 7500 rpm(we know an M54 won't do that) and a blower pulley of even 3.125 the impeller speed is only just over 44k rpm.
http://www.vortechsuperchargers.com/page.php?id=33511
BTW I went ahead and picked up a 3.33, 3.25 and a 3.125 pulley from a local tuner to try out.
I can confirm that the VF supplied pulleys are identical in bore, key way and depth of snout on both sides of the pulley to the Vortech pulleys.
      10-22-2014, 10:00 AM   #27
pokeybritches
2006 BMW Z4M  [8.50]
This is good info! I'm interested in how small you can go on the VF/Goodyear belt.
      10-22-2014, 11:19 AM   #28
Steeler
Steeler's Avatar
2429
Gotta feeling we are going to find out
      07-04-2017, 01:17 PM   #29
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
AND.....
      07-04-2017, 04:01 PM   #30
Steeler
Steeler's Avatar
2429
Originally Posted by 3GFX View Post
AND.....
Whatcha looking to find out?
Would take a book to write down all the trials and tribulations of adding boost over and over.
      11-16-2018, 01:14 PM   #31
3GFX
3GFX's Avatar
What is the stock VF setup for our cars?
- psi of stock kit
- crank pulley diameter (confirm please that M54B30 is 5.185")
- supercharger pulley diameter
I know that using this:
https://vortechsuperchargers.com/pag...eed-calculator
You can start to dive into alternate pulley setups.
- Is my understanding correct that the M54B30 should be able to hold 8psi reliably?
- Can the VF kit handle this as well with a smaller pulley?
- The impeller speed is given via Vortech but how do I go back to determining pressure?
      11-16-2018, 06:24 PM   #32
Steeler
Steeler's Avatar
2429
- psi of stock kit
First and foremost I would like to commend, recommend and thank Josh aka Pokeybritches for the time and effort he has put in so far helping me fine tune the ECU tuning on my engine.
His willingness to explain and illustrate the workings of our ECU and deliver the explained changes is exceptional
My engine is now responsive and more powerful than it has ever been and there is still so much more we can do.
The kit that VF ships claims 6.5# at max rpm. I believe the kit as delivered will deliver slightly more boost than that.
The pulley in the kit as delivered is a 3.6ish from memory although VF did ship me a 4.00 a year after I had recieved the kit citing they had sent the wrong pulley. Maybe they discovered the kit did deliver more than the advertised 6.5#.
Crank pulley is 5.5 on my M54B30. Not sure where I got the 5.185 from.
I am currently running a 2.62 pulley
I have regularly seen boost pressure on my gauge of 8psi at 4250rpm. I have taken rpm’s higher but cannot verify any boost #’s
The only engine internal mods I have made is to put in ARP head studs.
Not sure how you work impeller speed back to boost#.
I can tell you that the V3si if ran with a 2.62 pulley on an M54 with a 5.5 crank pulley at redline and 100% throttle would be 23# which equates to a boat load of rwhp.
Plans are in the works for a liquid to air intercooler which means even more boost.
Lastly I implore you to reach out to Josh. You will not regret it.
3GFX722.50
      11-16-2018, 11:05 PM   #33
pokeybritches
2006 BMW Z4M  [8.50]
Thanks for the kind words Dave!!
I've found a few interesting things with the MS45.0 and VF kit recently:
1. The MAF sensor scaling maxes out at 1024 kg/hr. This equates to 137% VE (5.4 psi on a 3 liter motor) at 6800 rpm under standard conditions. Any airflow beyond this amount is "off the charts" and not read by the ECU, which can lead to a dangerous lean condition.
2. I calculated the maximum boost level using the 3.6" pulley provided with my V3 SCi impeller.
- 6800 RPM redline
- 3.61 step up ratio
- 3.6" supercharger pulley
- 5.5" crank pulley
I found the impeller speed to be 37400 rpm. Using the compressor map available on Vortech's website (link), 37400 rpm corresponds to a pressure ratio of 1.55 (8 psi of boost). So, my VF kit in standard form put out 8 psi of boost at redline.
3. I pulled up my dyno from years ago on the original tune and pulley (picture attached). As you can see, the car was pig rich (10.0 AFR) until ~6300 rpm, where it started to lean out. At 6300 rpm, the impeller speed is 34650. Using the compressor map, that equates to a pressure ratio of 1.46 (6.8 psi). 1024 kg/hr (max reading of MAF sensor) at 6300 rpm equates to a VE of 121% (about 7 psi of boost). Conclusion – my original dyno backs up the theory that the MAF sensor is maxed out, even with a basic VF kit.
4. Axes values for ignition timing, fueling, and VANOS all max out at 700 mg/stk. While the MAF sensor's scaling is in units of kg/hr, the tables with a load axis (timing, fuel, VANOS, etc.) are all in mg/stk. A conversion is required, but it's not difficult, and it's dependent on rpm:
Mass Airflow (g/cyl) = #Cylinders * Mass Airflow (g/s) * 60 / (RPM*2)
When the MAF maxes out at 6300 rpm, the tables are already well beyond maxed out at 903 mg/stk. I'm working on rescaling the axes, which increases range at the expense of reduced resolution between cells. Max values for the axes are easy, but only significant data logging will determine the optimal sites (steps between max and min).
5. There are injector correction factors for each injector, and a global injection correction factor. I have seen some tunes that have these mixed up, which risks a single cylinder not receiving the fuel it needs and running extremely lean / detonating, and a wideband after the collector wouldn't necessarily pick it up because it averages the header bank's overall AFR. A 15% lean mixture in a single cylinder would only show as being 5% lean by a wideband installed after the primaries merge (2.5% lean after a y-pipe). A wideband installed on the other bank wouldn't pick up anything.
6. The MS45.0 uses narrowband primary O2 sensors, whereas the MS45.1 uses wideband primary O2's. This is a limitation for the MS45.0. It's possible to make big power on a dyno queen, but drivability and reliability will never be as good as a car with wideband O2 sensors. A narrowband sensor can only read AFR across a narrow band, right around stoichiometric (14.7). If the AFR deviates a few tenths above or below stoichiometric, the car only knows that the mixture is lean or rich, but not by how much.
The ECU's tables are in units of lambda. To move from lambda to AFR, multiply by the stoichiometric ratio of the fuel you're using (lambda 1.0 = 14.7 AFR on pump fuel).
There are four primary fueling tables in the MS45.0: closed loop, open loop, transition, and correction factors. Other fuel tables exist, like cold start and cranking, but they don't necessitate discussion here.
The closed loop tables are all lambda 1.0. This is what the ECU targets at cruise, and the ECU will use O2 sensor feedback to try and keep the mixture from cycling slightly lean to slightly rich. I could go into a long discussion about how this helps emissions (NOT efficiency) via outputting different types of toxic emissions when lean vs rich, that combine and produce CO2 and water in the catalytic converter… but I'll save it . The point is that with narrowband O2 sensors, lambda 1.0 is the only mixture you can target in closed loop mode.
In open loop mode, the ECU makes a calculation based on load and rpm, and it pulses the injectors to provide the appropriate amount of fuel without any feedback. So, you better be sure your injector scaling is correct, because the ECU is blindly guessing as to how much fuel it needs to dump. This is where an aftermarket wideband sensor and AFR monitoring becomes so important. The ECU has no way to know how close it is to its AFR target. This table is 2D, not 3D, meaning that it only considers RPM (and not load) with a 1x16 matrix (really a vector).
Another table is the transition or "full load threshold" table, which determines when the ECU moves from closed loop to open loop mode. This is also a 2D table, and it's based on throttle position (not accelerator pedal position).
The last table I'll talk about is a correction factor table, with load and rpm axes. This helps the ECU be more accurate with its fueling, but doesn't necessarily change its target AFR. I have seen it used in a roundabout way of increasing fueling for full load when the MAF sensor is maxed out. The table axes also peak at 700 mg/stk, so a basic VF kit is off the chart at high rpm.
Again, there are many other tables in the MS45.0, such as fueling tables for when VANOS is active vs. not, and so on. There are separate 91 RON and 98 RON tables.
What does this mean? The MS45.0 ECU either targets lambda 1.0, or a WOT mixture (based on rpm), and nothing in between. This transition isn't very noticeable on a stock car, but as boost increases, it can become more abrupt. Even more critically, ignition timing is based on load and rpm only, and doesn't take into account whether the ECU is in closed or open loop mode. It's possible to be in boost at part throttle. Advancing ignition timing when the ECU is targeting an AFR of 14.7 on a boosted engine is dangerous, especially in a high compression engine that was originally naturally aspirated (and thus more prone to detonation). From a reliability standpoint, the only things to do are reduce ignition timing to a safe value for both closed and open loop (limiting power), or set the WOT transition point to occur at a lower throttle input (affecting economy and power at part throttle). This is how it's possible to tune a car to make great power on the dyno but sacrifice reliability on the street.
7. Fortunately, the knock sensors seem to be pretty good at picking up early signs of detonation and retarding ignition timing.
I'm working with Dave to rescale the appropriate axes, and I'm working on a hardware solution to the MAF issue. By the way, I had the green VF fuel injectors tested, and they are 30 lb/hr at 100% duty cycle with 43.5 psi fuel pressure (BMW runs higher fuel pressure than this, around 50 psi IIRC). Variance was 4.3% at 20% duty cycle after cleaning, and 2.8% during static flow. They will be too small for my power goals, so I'll be working on an injector solution too.
      11-19-2018, 08:34 AM   #34
3GFX
3GFX's Avatar
Thank you both for the information.
Pokeybritches your goals sound way beyond mine, and dbarton62 yours might as well.
My goal is simple (I think).
- 400ish Crank
- Daily / Track. So power band should be clean.
What should my setup entail? Please guide...
      11-19-2018, 09:11 AM   #35
Steeler
Steeler's Avatar
2429
Pokey can guide but you have an open invitation to see my car. We can chat about all that is involved.
It is not a PnP by any means.
      11-19-2018, 11:13 AM   #36
3GFX
3GFX's Avatar
Bugger
      11-19-2018, 08:42 PM   #37
pokeybritches
2006 BMW Z4M  [8.50]
- 400ish Crank
I can advise on the tuning required (MAF scaling, axes scaling, and ignition injection), but you're up against a few hardware challenges:
1. Stock M54B30's have harmonics issues that cause the oil pump nut to back off and engine to fail. I can't imagine forced induction does anything except increase the likelihood of these issues occurring, so you'll want to bulletproof your engine first. ATI super damper and an oil pump solution are the minimum.
2. ARP head studs and MLS head gasket would be ideal.
3. You'll need some sort of intercooler - either a physical intercooler + piping (air-to-air or air-to-water) or water/meth injection. There are no off-the-shelf kits available, so it would be custom. I've considered developing a bolt-on kit if there's enough interest (10+ people).
4. These hardware challenges are in addition to the ones listed in my previous post (MAF is maxed out, injectors are nearing their limits). I'll update this thread once I do some data logging to confirm, but calculations on paper show the MAF is maxed at about 5-6 psi (depending on temperature).
If you want a street-only kit, you can probably get away with 10-12 psi on WMI, tune, and MAF. It's still possible for a tune that's dialed in to exceed the hardware capability of the engine at those boost levels.
      11-20-2018, 03:36 PM   #38
3GFX
3GFX's Avatar
My understanding then is that the stock as shipped VF kit already maxes out what the motor can do essentially?
...or the tune is not quite efficient?
      11-20-2018, 03:54 PM   #39
pokeybritches
2006 BMW Z4M  [8.50]
You'll need hardware changes to move beyond a standard VF kit. The motor is capable of quite a bit more power though.
      07-15-2023, 09:27 AM   #40
DiscoJax
DiscoJax's Avatar
Drives: 2005 BMW Z4 3.0i
E85 With VF Package - Need Some Help
Hey Guys
I know this is an old thread but I thought I would take a chance here. Last year i bought a 2005 E85 with 79k miles on it. It looked like it had the VF engineering package on it but because it had changed hands a couple of times, I didn't really know the tuning situation. So here's a bit more history:
1) Looks like the VF package was a used transplant from another car. Super charger had been rebuilt and blew up on me when I took it to 6k RPMs. Also has custom aluminum ducting. Stock MAF, headers and exhaust.
2) It has part of the VF branded tubing/hoses and the green injectors.
3) Vortech could not rebuild the SC so I purchased their newer V3 Si supercharger and kept the 3.25 pulley that was on there.
4) I worked through numerous typical repairs - new radiator, waterpump, vanos seals, DISA upgrade, O2 sensors, spark plugs, fuel pump and fuel pressure regulator.
5) Unrelated but I did swap out the gears to 3.46.
6) I did a remote tune with Frank Smith and it seems to run ok but I still get CELs for P2096 and Post Catalyst Fuel Trim System Too Lean Bank 1 and P0420/P0430.
7) Took it to a local BMW indie and he can't find anything wrong. Says the CATS are fine.
Overall I am pretty happy with the car other than the recurring CELS and the feeling that it is running rich. I don't know much about tuning or boost, I'm just trying to get my daily driver dialed in for spirited driving.
Sorry for the long post. Hopefully some of you guys can weigh in on next steps. I'm considering doing another remote tune with these guys who are little bit closer to home. https://www.chaoscalibrations.com/st...-Z4-p277028770
      07-15-2023, 02:58 PM   #41
Steeler
Steeler's Avatar
2429
Originally Posted by DiscoJax View Post
Hey Guys
Best thing you can do is reach out to pokeybritches
He can sort it for you.
