      08-27-2013, 09:56 PM   #111
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I just ordered an Aeromotive 11140 (center inlet), and will get a sleeve kit for it. Wish me luck!
Where in the Z4M do you get access to the fuel pump? Is it hidden under the trunk carpet? If so, on which side?
      08-28-2013, 10:03 AM   #112
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Interested to hear your thoughts as well bud!
I think earlier in the thread, it was stated that you have to drop the rear cans etc to get to the tank underneath the car. Kinda miss my Integra in this sense... remove rear seat in 3 minutes, remove cover, replace pump.
An upgraded fuel pump sounds like a *really* good investment if there's nothing additional to do (ie. just replace pump, DME adapts, smiles ensue).
      08-28-2013, 11:23 AM   #113
gmd2003
gmd2003's Avatar
352
It's in the fuel tank . PITA
      08-28-2013, 12:06 PM   #114
Shipkiller
Shipkiller's Avatar
Drives: Me
I think the drive shaft has to leave along with some heat shielding.
      08-28-2013, 02:22 PM   #115
ZStig
279
Basically i gotta drop down everything in the rear? Fuck. Thats gonna eat into my tune budget. I'm gonna run about 10psi so fuel delivery on a 72k mile pump is gonna be crucial
      08-28-2013, 02:39 PM   #116
gmd2003
gmd2003's Avatar
352
Just the exhaust and the gas tank , but that's enough of a pain . Make sure you are almost out of gas of course .
George
      08-28-2013, 05:50 PM   #117
ZStig
279
I looked under the car, it looks like the gas tank is in 2 pieces. Or does it look different once you get the exhaust out?
      08-28-2013, 06:29 PM   #118
StickMon
StickMon's Avatar
Drives: 2006 MR
Saddle shaped.
      08-28-2013, 06:59 PM   #119
ZStig
279
yup thats definitely what I was tapping on.
      12-08-2013, 03:06 AM   #120
tikamak
Lebanon
58
Guys, what are the parts needed for this aeromotive pump ?
Can you please give me exact details, i'm thinking of upgrading too.
      12-08-2013, 08:01 PM   #121
ZStig
279
parts:
1.This pump kit + the 340 pump
http://www.radiumauto.com/Fuel-Pump-...-E46-P314.aspx
2.a new big o-ring that goes around the access panel to the fuel pump
3.a new OEM fuel pressure regulator is HIGHLY recommended, since it has a built in fuel filter, and you might as well get a clean one if you're gonna be pumping more fuel in. I was at 75k miles and mine was filthy
tips:
4.as little fuel left in the tank as possible, but enough to get the car re-booted
5. do NOT have to remove the fuel tank to do this job. all happens throught he round access panel which is under the car, near the driveshaft. Exhaust up to headers and driveshaft have to come out.
6. That kit allows you to get an almost tight fit on the pump into the housing, but there is no space to use the metal clamp to hold it on. Connecting the filter "sock" on the bottom prevents it from moving up and down.
7. the housing sits inside the fuel tank. You reach in through the access hole, and press on a tab on the bottom of it at the front, to release it and CAREFULLY lift it up.
8. don't screw up the fuel level stick and level when you're pulling it out or re-installing.
9. watch the HPF E46 M3 youtube install video, for an idea. Its different in our cars though, especially the access which is much tougher
then part 2 of video
I'll post pictures soon that kind of help
      12-09-2013, 02:35 AM   #122
tikamak
Lebanon
58
parts:
Is this the center inlet version of the aeromotive pump or do i have to specify that i need the center inlet version?
      12-09-2013, 08:23 AM   #123
ZStig
279
Good question. I bought the actual pumo on amazon, but it made the purchase more complex. Email that company
      12-09-2013, 01:22 PM   #124
gmd2003
gmd2003's Avatar
352
parts:
Yes it's the center inlet version . Great summary by Zstig !
George
      03-22-2014, 09:32 AM   #125
tikamak
Lebanon
58
George
HI George,
Some guy is saying that the stock fuel pump is a walbro 400. Is that true ?
I have a new stock fuel pump in the garage, how can i check what's the model of the stock fuel pump ?
http://forum.e46fanatics.com/showpos...9&postcount=35
      03-22-2014, 09:46 AM   #126
gmd2003
gmd2003's Avatar
352
George
HI George,
You won't be able to confirm that by looking at the BMW part number . I find that very hard to believe personally , but could it be possible , sure .
      03-22-2014, 10:32 AM   #127
Beedub
HI George,
contact walbro???? and update your findings please.
      03-22-2014, 11:44 AM   #128
tikamak
Lebanon
58
I snapped a few pics of the Fuel pump repair kit.
Here, you could see the fuel pump inside:
Here's the walbro 400lph pics:
This is a picture of the full repair kit:
It seems really interesting, that the fuel pump casing is actually inside the tank. Since if you look at the fuel lines routing, you could almost feel like this was designed to overcome high G corners where fuel starvation might occur since the way the fuel is drained from the fuel pump inlet area is pretty slow. Another reason is that it's installed in the bottom of the gas tank.
      03-22-2014, 11:51 AM   #129
tikamak
Lebanon
58
Another pic of the walbro:
      03-22-2014, 01:09 PM   #130
Beedub
It does actually look like the walbro tbh.......
      03-22-2014, 01:33 PM   #131
tikamak
Lebanon
58
Haha, maybe because it is one ?
No one ever had a problem with fuel flow with this pump if you check the supercharged people.
If anyone did, it's probably because it's an old unit and replacing it with a new one will make you feel the difference.
Now the question is: knowing that we have the walbro 400 pump, wouldn't an aeromotive 340 be a downgrade ?
      03-22-2014, 02:18 PM   #132
Beedub
we don't know for definitive that it is the walbro400 just because it looks the same and some dude on the internet says it is.......???? i will however concede it does appear to be identical to the walbro400 pics you posted even down the finite details... i believe the 340 can flow the same anyway and is a more reliable pump in general.... i would not call it a down grade...
also i agree the fuel setup is a nice design .. as id expect on and ///m car to be honest...
