      08-18-2012, 12:42 PM   #1
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Constant pressure valve leaking
Very slow leak. looks like a bitch to replace. Anyone here made this repair?
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      08-18-2012, 02:08 PM   #2
prodigal_m
Member
prodigal_m's Avatar
Drives: 2018 Estoril Blue/Black F31
I had mine changed in June (under warranty) but I think it only called for an hour labor if I remember correctly.
      08-18-2012, 07:41 PM   #3
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
I've done it on the E46M. It's just getting to it that is a pain. I used a large flathead bit socket and an extension onto a ratchet. It came right off. I recommend just swapping out the o-ring.
http://i1212.photobucket.com/albums/...y/IMG_0277.jpg
http://m3forum.net/m3forum/showthread.php?t=369406
Everyone should do this when swapping out headers because access without the headers makes this a 5 min job max.
      08-18-2012, 08:07 PM   #4
mousitch
Dark Sider
mousitch's Avatar
129
Thanks
Ordered a new o-ring. Doesn't look to bad. I have had the reinforcement plate off before.
      08-19-2012, 07:54 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks for the info.
I think mine is just starting to leak.
      08-19-2012, 12:45 PM   #6
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Thanks!
2006 Z4MC - #LL93158
      08-19-2012, 01:57 PM   #7
mousitch
Dark Sider
mousitch's Avatar
129
Good luck finding the 42653 Craftsman bit guys. Looks like there is one(I bought the other) set on Ebay. Sucks to have to buy the other 2 bits in the set but that's all I could find. Sears sold out online. Found one at a Sears about 30 miles away but the inventory was off when I arrived. Ugh. Ordered full set for $15 off Ebay. Ill send mine out as a loaner when I'm done, if you come up dry. Or just keep it till someone else needs it. Community bit.
Set
http://www.ebay.com/itm/SET-3-CRAFTS...item3cc9e0c0dd
http://secure.nhbragg.com/product/cr...socket-722137/
      08-20-2012, 01:15 PM   #8
Jumbosock
Jumbosock's Avatar
76
There are a few others that will probably work.
http://www.ebay.com/itm/ws/eBayISAPI...ectorid=229466
      08-25-2012, 01:39 PM   #9
mousitch
Dark Sider
mousitch's Avatar
129
Easy fix. Old o-ring was super hard. 35 minute repair.
      08-25-2012, 02:52 PM   #10
Beedub
more info pleased!!!! this seems that it will fail at some point!! can you please post your removal procedure, im glad its a 30 min fix!!!
      08-25-2012, 03:17 PM   #11
mousitch
Dark Sider
mousitch's Avatar
129
First off, DO IT AT YOUR OWN RISK. I AM NOT RESPONSIBLE FOR ANYTHING THAT MIGHT HAPPEN TO YOU OR YOUR VEHICLE. Now that's out if the way, let's proceed
Tools used: 1/2 breaker bar, long 3/8 ratchet, 8mm nutdriver, stubby screwdriver and a 42653 Craftsman screwdriver/socket screw tip. 16mm 1/2 socket and a 3/8 10mm socket. Rags, coffee can. Jack and jack stands
Raise front of car and place on strands. The higher the better. A lift would be nice.
Removed three 8mm nuts from the front plastic tray where it meets the reinforcement plate.
Removed small shield over tranny(4ea-10mm bolts). Then removed the eight bolts holding the reinforcement plate shield broke loose bolts 1/2 breaker bar and a 16mm socket.
Then I stuck my worklight up between the headers. If you look straight up in back side of engine and you will see a slotted nut. I used the screwdriver bit to break it loose and the stubby to remove. This is tight but it can be done. And I have some big hands.
Took off old o-ring , put on new oring and reverse the procedure. These are supposed to be one time use bolts but i reused the old ones.Torque reinforcement bolts 59Nm
Turn an additional 90º (with a tolerance of +/- 30º)
---->This does NOT mean an additional turn of 30 after the 90, it is just a tolerance range to prevent over tightening.
You will loose a small amount of oil so have a coffee can ready. Plus check your oil level after repair.
Google search has quite a few DIYs that are similar. I believe the shield on the e46 is slightly different
This video is pretty good at describing location.
I bought the new o-ring from here. Bought two just in case. These are improved o-rings.
      08-25-2012, 06:47 PM   #12
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Thanks! We'll do this when Ian and I Install our new Headers I believe he already ordered the O Rings.
      08-25-2012, 08:09 PM   #13
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yep
      08-26-2012, 02:32 AM   #14
Beedub
absolutly.... you'd be mad not to!!!
      08-26-2012, 12:52 PM   #15
GP20
What's the sympton of the CPV leak? Did you notice anything while driving? Or just noticed oil on your garage floor?
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      08-26-2012, 01:23 PM   #16
mousitch
Dark Sider
mousitch's Avatar
129
Just a drip every so often. Honestly it was a slow leak. I may have actually only saw three drips total in 3 months. But it was still leaking and I couldn't have that. If no leak its a good PM practice to go on and switch to the better o-ring IMHO. Of course this depends how comfortable you are with fixing something not yet broken.
      02-28-2013, 07:49 PM   #17
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
Mousitch,
any way you can PM me the gentleman on m3forums and get his paypal/email for me? I am unable to PM him or post anything in "for sale" thread since I have a brand new account there.
Thanks!
The Raspinator
      02-28-2013, 11:04 PM   #18
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
At what age or mileage are the stock O-rings starting to leak? I've got to remove the plate and do my motor mount bolts so I may as well do this too!
      03-01-2013, 12:20 AM   #19
mousitch
Dark Sider
mousitch's Avatar
129
Originally Posted by SCHMOUPE View Post
Mousitch,
Thanks!
Pm'd
      03-01-2013, 12:20 AM   #20
mousitch
Dark Sider
mousitch's Avatar
129
25000 miles I saw the drip. Very minor leak
      03-01-2013, 12:26 AM   #21
SCHMOUPE
SCHMOUPE's Avatar
Pm'd
Thank you sir!
The Raspinator
      03-01-2013, 09:34 PM   #22
abashoe
Drives: 2008 335xi
Can you PM me the info too. I want to pick up some viton rings
