      07-20-2023, 11:32 AM   #1
schobyb
schobyb's Avatar
15
Drives: 06 Z4M Roadster; 2012 Cayenne
2006 BMW Z4MR  [0.00]
Replacement starter making an unusual sound
I picked my car (06 Z4MR) up from a shop this week after having a new starter put in. Now, when the starter is engaged, it makes a sound a lot like an air wrench. The shop told me, and from a bit of my own research, it does not look like there is any kind of shim or adjustment to be made. The car does start every time I try it. Is this just a bad starter? A bad install? I wasn't expecting there to be any sort of break in for a replacement starter. I am concerned about possible damage to the starter or flywheel if the fit is not exactly right. Has anyone had an experience like this? Any advice? Thank you.
Here are two video clips of starting the car.
Start 1
Start 2
      08-13-2023, 08:17 PM   #2
schobyb
schobyb's Avatar
15
Update: not sure what the cause is, but the issue is still present and I am planning to take it back to have a new starter put on.
      08-17-2023, 09:32 AM   #3
Clearancediver
Drives: 2004 Z4
Getting it replaced is the correct action. It sounds like the starting solinoid isn’t disengaging.
Sent from my smart phone...
Tags
starter, starter motor, starter noise
