02-19-2018, 04:42 PM | #1 |
salty cowboys fan
6159
Rep 3,408
Worst Rod Bearing?
Replacing rod bearings this weekend, check this one out lol
It’s missing a chunk ffs, I think another minute and kaboom!
she’s home! '22 M4 Comp xDrive
02-19-2018, 05:41 PM | #3 |
Rep 2,866
02-19-2018, 06:27 PM | #4 |
Rep 158
Drives: 07 Z4 M Coupe
Yikes.. How many miles were on those bearings?
02-19-2018, 08:08 PM | #5 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Wow. As above, do you have any details?
Mileage, frequency of oil changes, type of oil, pattern of use (e.g., waiting for oil temp to fully warm before hard acceleration), used oil analyses, etc.? Thanks in advance!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
02-19-2018, 08:52 PM | #6 |
salty cowboys fan
6159
Rep 3,408
Just hit 80k miles, mostly city driving.
Usually change oil every ~4-5k, no revving while cold etc. Always used Castrol TWS, except maybe 20k ago I used the blue bottle “M TwinPower” whatever oil. Only 1 track day. I did have an oil analysis done at 75k — lead was 30, copper was 3. Funny, because all 6 top bearings were down to copper I was worried that the journal would be toast but there’s no scratches or anything. Lucky I guess!
02-19-2018, 09:01 PM | #7 |
Rep 11,667
WOW!!
Lead at 30 is extreme and should definitely been cause to stop driving until getting them done.
02-19-2018, 09:29 PM | #9 | |
Rep 2,866
02-21-2018, 10:54 AM | #13 |
Rep 1,130
Damn that looks horrible. Are bearings something that need to be changed continuously throughout the car's life?
2014 BMW X5 Sdrive35i F15
02-21-2018, 12:15 PM | #14 |
Rep 2,866
On this (s54) engine, yes
02-21-2018, 12:36 PM | #15 |
salty cowboys fan
6159
Rep 3,408
I wish I knew, I tried to do 1 analysis prior but the sample never arrived at the lab after sending
02-21-2018, 12:48 PM | #16 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Now I'm going to have nightmares, tonight.
Salty
yousefnjr6159.00 |
02-21-2018, 12:52 PM | #17 |
Rep 870
Do you think that may be a mfg defect in the bearing shell? What else would cause a chunk to go missing like that? Maybe a piece of metal is missing from another part of your engine, and it passed through the bearing and chewed it up? Glad it didn't go boom.
Salty
02-21-2018, 04:06 PM | #18 | |
salty cowboys fan
6159
Rep 3,408
02-21-2018, 04:16 PM | #19 |
10866
Rep 4,895
Those bottom ones already classify as very bad.
Those top ones....they're extreme. Have you plastigauged the old bearings to see what actual bearing play was the result?
02-22-2018, 03:39 PM | #20 |
Rep 1,130
Well I didn't sign up for this when I bought the Z4 back in 2011!
I researched the info back then and the major topics were taking care of the valve adjustments and/or inspection I/II. I've been reading Salty's threads and others' about this issue. I'm thinking that these rod bearing problems just recently started happening more often as our cars are aging.
02-22-2018, 04:51 PM | #21 | |
salty cowboys fan
6159
Rep 3,408
02-22-2018, 04:55 PM | #22 | |
10866
Rep 4,895
It goes back even further, here in europe we have had the euro s50 since the early-mid 90's and that has the same problem (not strange as it's its predecessor and very similar in build and performance). Biggest problem back then (in the 90's) is that at that time there were no internet forums, so information on this was not spread around.
