      04-13-2013, 04:09 PM   #111
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by Steenos View Post
Just skeptical about the power gains. Everything from what I'm hearing is awesome though. Thanks for the info.
haha you're very welcome. I was just as skeptical (if you read through my posts very carefully, you'll see that I was reluctant on allowing the butt dyno to speak at all during the evaluation process) in the beginning
Power!!!!
Gotta get a ride at Laguna with your skills behind the wheel + S/C. Good thing you have those brakes!
      04-13-2013, 10:24 PM   #112
pal
pal's Avatar
433
Drives: Z4 M Coupe
Nik from VF has done excellent work on VAG cars but seems to have had less success with e46 M3s. Are you getting the kit with a GIAC tune or the recent in-house VF tune?
      04-14-2013, 02:40 AM   #113
mfanatic325
///M-fanatic
Taiwan
193
Gonna be the in-house VF tune for the grey injectors, and not the orange-striped ones from the E46 M3. Rated M Roadster and I have been in close contact with VF in regards to the tune. Apparently it's pretty solid right now. I'm just trying to find time to get the kit installed, as I'm busy with school at the moment. I hope to have everything installed and ready to go by May 25th, my next track day
      05-11-2013, 09:20 AM   #114
z3speed4me
Need a replacement.
Drives: 4 wheels
Did you ever get results on the dyno with the headers and the AA tune?
~Ken~ {'99 M coupe : 1 of 35} - Built by Maximum PSI 623 whp 516 wtq; RIP 3.24.13
{'01 M coupe : 1 of 16} - Nick G Tune, CPI Stepped Headers, SS X-Pipe, TCK S/A ~294 whp 237 wtq
{'13 Golf R} - GIAC stg 1, VWR intake, magnaflow catback; LED Tails
      05-11-2013, 12:19 PM   #115
mfanatic325
///M-fanatic
Taiwan
193
Yes, the results are in other thread(s) I've posted. Search for threads that I've started and look for the ones that have "dyno" in the titles.
My max peak output was 310rwhp and 256rwtq.
That was with all bolt-ons + tune.
I have since reinstalled my OEM section 1 due to the unbearable rasp I was having with essentially straight pipes. So I probably lost a bit of power.
But now that my SC install is at 99% completion rate, I should be okay in terms of power output
