01-05-2013, 10:48 PM | #1 |
Rep 82
Oil Level Question
Ok, I changed my oil and filter in my 2006 M Coupe and I very carefully put 5.5 Liters of Castrol 10w60 back into it. Started it and checked for leaks, no problem, shut it off and waited for a minute to check the level.
Drove it to the gas station and back, checked it again. 5.5 liters puts the oil level right at the low mark on my dipstick. Is this where I leave it?? My car does not use any oil between changes so that is not a concern but in my mind the car is low on oil at that level on the dipstick. Opinions??? |
01-06-2013, 06:49 AM | #2 |
Rep 11,668
Something is odd, it should be at least half way with 5.5
01-06-2013, 08:23 AM | #5 |
Rep 280
01-06-2013, 12:25 PM | #6 |
Rep 666
Castrol TWS 10W-60 is packaged in one liter containers not quarts.
S54 engine oil capacity and level chacking procedures found here: http://www.bimmerfest.com/forums/showthread.php?t=41599
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
01-06-2013, 02:33 PM | #7 |
Rep 2,554
My guess is the oil jugs were not completely full. Add some more oil to bring it up to the full mark.
01-06-2013, 02:45 PM | #8 |
M = Midlife Crisis
65
Rep 2,006
You mean the half (mark)
2006 Z4MC - #LL93158
01-06-2013, 03:31 PM | #9 |
Rep 2,554
01-06-2013, 05:25 PM | #10 |
M = Midlife Crisis
65
Rep 2,006
S54 level is half. Most BMW techs overfill our cars...
01-06-2013, 09:23 PM | #11 | |
Rep 82
I started checking the oil 45 seconds after shutdown and continued checking it until about 2 minutes and it is right at the bottom mark on the dipstick. The oil was brand new and all the bottles were filled to the same level. According to the manual there is 1.3 - 1.4 liters between the bottom and top marks on the dipstick so if I fill it to the top mark that would mean 6.5 - 7.0 liters. Seems to be a bit much. I know it has 5.5 liters in it so I guess I will just drive it at the low mark..... |
01-08-2013, 01:14 AM | #12 |
707
Rep 7,850
Unless you're checking the oil in incline I don't see why the oil level should be that low. Is there any chance that the temperature was really really cold, or things were a bit rushed, and there was a portion of oil left in each bottle that did not end up in the car? (Can't see how, but thinking out loud.)
In any case I might add another quarter bottle just bringing up a bit past the bottom fill line. IMO what matters is what can be measured with the dipstick. |
01-08-2013, 01:23 AM | #13 |
Rep 2,877
Drives: Anything
What do you measured after letting it sit overnight? Mine usually measured on the low side even after 15-20 minutes of shutdown. However, it always measured near the middle when it has been left sitting overnight.
01-08-2013, 06:18 AM | #15 |
Rep 11,668
That's why there is a sticker under the hood with the idle, then 60 second shutdown procedure.
01-08-2013, 03:36 PM | #16 | |
Rep 82
And I was checking the level with the car sitting in the garage, which is flat so there couldn't be any incline issue. It was around 55 degrees when I changed the oil so I doubt I left much in the container on the pour. It is just weird because I never had this issue with either of my E46 M3s. One other questions - I am not the original owner of the car - is there any aftermarket way to increase oil capacity?? The car has a lot of mods on it but other than the Dinan throttle bodies, Dinan software and a J&B liteweight flywheel, I haven't found any other engine mods, mostly only chassis/diff stuff. |
01-08-2013, 03:56 PM | #17 |
707
Rep 7,850
Upgraded (larger) oil cooler is the only one I can think of. That would add some capacity. Take a look, but I doubt it's going to be easy just looking w/o a comparison, gmd2003 has one.
After we've exhausted all the possibilities and run down things like temp, incline, start/stop procedure, etc., I still think what the dipstick says is ultimately what matters. |
01-08-2013, 09:41 PM | #18 | |
Car Geek
3708
Rep 3,621
01-09-2013, 09:06 AM | #19 | |
Rep 82
I checked the level with the motor cold and it is about 1/3 above the low mark. I will add a little and drive it. The car has never used any oil so it should be fine. I was mainly curious if anyone had experienced this before. |
01-09-2013, 04:55 PM | #20 |
M = Midlife Crisis
65
Rep 2,006
5.5L should bring it to ~ halfway between the markings on the dip stick.
01-09-2013, 08:50 PM | #21 | |
Car Geek
3708
Rep 3,621
01-10-2013, 10:57 AM | #22 | |
Rep 82
