02-12-2011, 01:00 AM | #45 |
Fast Everything
Rep 98
Then I shall call you Scully.
I did have fade, made that clear. Perhaps what you are trying to say is you can't believe the fade didn't get so crazy bad that unless you were high you'd have no choice but to come in before total failure happened. I assume that is the way it happens most of the time right? Just... not every time. I'm sure if the parts were anaylsed you'd get all your answers. Doubt that will happen though. But is it so hard to believe a destructing brake pad can cause truly massive heat soak in a short period of time? Nothing in that I find hard to believe.
2006 IBlue BMW Z4 MC - ESS VT2-525 Supercharged, JRZ RS1 suspension (500#F, 600#R) with Vorshlag plates, ST Trophy BBK with CL R6E pads, KKS gated exhaust, TMS sway bars, RE rear camber arms, VT engine mounts, Recaro Pole Position (driver), APR GT wing, Street: Volk G2s and Potenza, Track: Volk TE37SLs and BFG R1s.
12-09-2012, 04:02 PM | #47 |
Rep 12,565
Can't believe I missed this thread. Ordering all the components for a proper brake cooling kit and was researching old threads to find any relevant info. Luckily I've only dealt with fade issues 2x and each time it was the towards the last session of each day. Hopefully the brake ducting will help although my new concern is that it may lead to the rotors cracking prematurely.
12-09-2012, 04:34 PM | #48 | |
707
12-09-2012, 04:35 PM | #49 |
Rep 4,531
+1 it would be helpful information.
12-09-2012, 04:37 PM | #50 |
Rep 12,565
Will do, if hoses arrive by Friday and temps stay above 40 this Sat I'll be tackling the project then.
12-10-2012, 03:33 PM | #52 |
Rep 222
12-10-2012, 04:55 PM | #53 | |
707
What I don't think was posted was some type of measure of airflow to the rotors and effectiveness. Maybe that's something I just need to look a more updated version of the thread to find? Work in this area is appreciated! |
12-11-2012, 09:33 AM | #55 |
Rep 688
WOW! This has me very worried about the stock brakes on the car now. As bad as I hate to, I guess I need to start looking for a BBK on the fronts before the April HPDE and June in Austin. The thought of this happening in Austin on the back straight at COTA into turn 12 is not a good thought.
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor Last edited by TexasZed4MC; 12-11-2012 at 02:44 PM.. |
12-11-2012, 11:07 AM | #56 | |
Rep 924
@VMZ God was on your side for sure. So many things could have gone terribly wrong in that scenario.
So from this thread and my experience, yes, I think the stock brakes on our Z4Ms are sub-par for track enthusiasts. Sure you can get by with proper braking technique, but the speed ceiling on stock brakes is too low for most folks. I'll for sure be getting a BBK before hitting the track again.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts '09 X5 35d — Space Grey / Saddle Brown 20" Forgestar F14 / SCR Delete Last edited by RADRACR; 12-11-2012 at 11:12 AM.. |
12-11-2012, 11:40 AM | #57 | |
Rep 4,531
Mid-Ohio is around 3000 feet long on their straight, going downhill. COTA is around 3200-3500 feet long. I ran HP+ pads and even though they aren't even track pads I was fine. |
12-12-2012, 03:05 AM | #58 | |
Rep 222
I will doff my cap to anyone who can come up with a better way of routing ducting from a zone of high pressure/cold air at the front of the Z4M to the brakes. Obviously, I could have made fancier fittings but what I have made works well and was made out of bits and pieces that I had to hand. With regards to the flow rate, I wrote in the thread: " If you use the calculator here: http://www.1728.org/flowrate.htm you can estimate the flow rate of air at different speeds of the vehicle. If we assume the diameter of the brake ducting is 1.75" (being conservative) then at 50mph over 34 litres/sec of air passes into the centres of the brakes and at 80mph it is 55.47 litres/per second, all that air MUST have more cooling effect on the brakes than with no ducting. " When all is said and done, it's the constant flow of air through the ducting that is the effective part of this mod, and this is not diminished because there aren't any expensive fancy Carbon Fibre parts at both ends of that ducting Here are a couple of links to my brake "How Tos": http://www.z4-forum.com/forum/viewto...p?f=34&t=38775 http://www.z4-forum.com/forum/viewto...p?f=34&t=45293 Last edited by exdos; 12-12-2012 at 03:11 AM.. |
12-12-2012, 06:09 PM | #59 | |
Fast Everything
Rep 98
http://www.zpost.com/forums/showthread.php?t=410641
01-21-2013, 09:09 AM | #60 | |
Rep 12,565
http://www.zpost.com/forums/showthread.php?p=13344899 |
